Home » Newcomers » Newcomers » Random Crashes on Linux Mint 17.1(Has anyone else seen similar problems)
Random Crashes on Linux Mint 17.1 [message #1759328] Mon, 10 April 2017 11:21 Go to next message
Just downloaded the latest Neon release version and am having some issues running it on Linux Mint 17.1
This may be an Oracle Java issue, but I'm trying to isolate the problem.
I was able to install, and it is a fresh installation. No old version of Eclipse hanging around in a fresh directory.
Same with Oracle Java 8 SDK, that was a completely fresh install as well with any previous JDK / JRE completely removed from the system.
Sometimes Eclipse crashes on start up but usually with different errors being reported when starting in a terminal.
Sometimes Eclipse will start but then will crash and burn when trying to do even simple things in the IDE UI.
Other times it will run with no problems. I only seem to be having stability issues with Java / Eclipse on this system. All other software operates fine with no crashes, lock ups, etc.
So I was wondering if anyone else had noticed similar issues and, if so, how you corrected the problem?
Burt
Re: Random Crashes on Linux Mint 17.1 [message #1759342 is a reply to message #1759328] Mon, 10 April 2017 04:47 Go to previous messageGo to next message
Perhaps information from the "workspace/.metadata/.log will help us understand what's wrong. Do you really mean a VM crash or with a VM dump, or just the application terminating?
Re: Random Crashes on Linux Mint 17.1 [message #1759348 is a reply to message #1759328] Mon, 10 April 2017 13:41 Go to previous messageGo to next message
Here's one of the most recent chokes. As I mentioned sometimes it crashes before the IDE comes up. Other times the IDE comes up but just clicking on a menu item, or attempting to open a file will crash. And other times it will run for quite a while and I can build and test with no problems.
!SESSION 2017-04-10 10:52:24.107 -----------------------------------------------
eclipse.buildId=4.6.3.M20170301-0400
java.version=1.8.0_102
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os linux -ws gtk -arch x86_64 -product org.eclipse.epp.package.java.product
!ENTRY org.eclipse.core.resources 2 10035 2017-04-10 10:52:30.868
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!SESSION 2017-04-10 11:01:28.856 -----------------------------------------------
!ENTRY org.eclipse.equinox.event 4 0 2017-04-10 11:01:38.960
!MESSAGE FrameworkEvent ERROR
!STACK 0
java.lang.ClassCastException: org.eclipse.osgi.internal.serviceregistry.ServiceReferenceImpl cannot be cast to org.osgi.framework.ServiceEvent
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:1)
at org.osgi.util.tracker.AbstractTracked.untrack(AbstractTracked.java:341)
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:909)
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109)
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:915)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.unregister(ServiceRegistrationImpl.java:222)
at org.eclipse.e4.ui.services.internal.events.EventBroker.unsubscribe(EventBroker.java:206)
at org.eclipse.ui.internal.WorkbenchPartReference.unsubscribe(WorkbenchPartReference.java:205)
at org.eclipse.ui.internal.WorkbenchPartReference$3.handleEvent(WorkbenchPartReference.java:187)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:40)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:233)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:145)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:5414)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:211)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:36)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:201)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:94)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:60)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.basic.impl.PartImpl.setContext(PartImpl.java:431)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:626)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:757)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:728)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:722)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:706)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1324)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:103)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:669)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:70)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:665)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$1.run(PartRenderingEngine.java:536)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:520)
at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:70)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:975)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:651)
at org.eclipse.e4.ui.workbench.renderers.swt.SashRenderer.processContents(SashRenderer.java:142)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:49)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:82)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:63)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:725)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1059)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:693)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
at org.eclipse.equinox.launcher.Main.main(Main.java:1492)
Re: Random Crashes on Linux Mint 17.1 [message #1759349 is a reply to message #1759348] Mon, 10 April 2017 13:44 Go to previous messageGo to next message
And here's a partial .log file from a previous crash:
!SESSION 2017-04-10 08:37:51.113 -----------------------------------------------
eclipse.buildId=4.6.1.M20160907-1200
Framework arguments: -product org.eclipse.epp.package.cpp.product
Command-line arguments: -os linux -ws gtk -arch x86_64 -product org.eclipse.epp.package.cpp.product
!ENTRY org.eclipse.core.resources 2 10035 2017-04-10 08:37:55.822
!ENTRY org.eclipse.ui.navigator.resources 4 0 2017-04-10 08:38:22.870
!MESSAGE Could not acquire INavigatorContentService: Project Explorer not found.
!SESSION 2017-04-10 08:49:45.496 -----------------------------------------------
!ENTRY org.eclipse.core.resources 2 10035 2017-04-10 08:49:53.358
!ENTRY org.eclipse.core.resources 4 2 2017-04-10 08:49:56.564
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.core.resources".
!STACK 0
java.lang.ArrayIndexOutOfBoundsException: -982060656
at org.eclipse.jdt.internal.compiler.parser.Parser.consumeClassHeaderName1(Parser.java:2705)
at org.eclipse.jdt.internal.compiler.parser.Parser.consumeRule(Parser.java:6251)
at org.eclipse.jdt.internal.compiler.parser.Parser.parse(Parser.java:11141)
In this case it was a totally different event.
I'm going to try installing Oracle Java and Eclipse in a VM I have (32 bits) and see if that exhibits the same issues, then so I can try to get some work done I may try installing it on Win10 (32 bit) and see if I have the same issues there.
Burt
Re: Random Crashes on Linux Mint 17.1 [message #1759351 is a reply to message #1759349] Mon, 10 April 2017 14:27 Go to previous messageGo to next message
Burt, are you using the Eclipse Installer to set up Eclipse?
If not, please delete current installation and do it again with the installer. If there are many modules loaded after installation, you can save the the setup into a file using the File -> Export -> Install -> Installed Software Items to File.
After deleting current Eclipse and installing the new one, you can import the installation file (.p2f) and it restores the remaining installation.
Re: Random Crashes on Linux Mint 17.1 [message #1759361 is a reply to message #1759351] Mon, 10 April 2017 18:56 Go to previous messageGo to next message
I did use the installer, but just in case something got messed up I'll give it another go tomorrow.
Note that I downloaded the 32 bit version of Eclipse and installed it in a 32bit Ubuntu 16.04.2 system running in Virtual Box and so far (other being slower) I have NOT had any of the crashes I was seeing with the 64 bit installation, and right now I'm using the OpenJDK 8 instead of Oracle's Java for the 32 bit installation. I also installed the 32 bit version on an older machine that is running Ubuntu 15.10 again with OpenJDK 8 and Eclipse appears to run without crashing there as well, but it is still slow since that is an older machine with less RAM.
I'll give the 64 bit installation another fresh shot tomorrow and see if that makes any difference.
Burt
Re: Random Crashes on Linux Mint 17.1 [message #1759438 is a reply to message #1759361] Tue, 11 April 2017 13:15 Go to previous messageGo to next message
I'm running Eclipse neon.3 with plenty of plugins under Kubuntu 16.04 in VMWare Fusion 32 bit virtual machine with no problems whatsoever.
There were issues with GTK in earlier Kubuntus. The default GTK theme produced null pointers instead of neat dialog boxes. Some of the early 16.04's did not work under GTK3, so I made them work forcing the use of GTK2 in eclipse.ini.
-TV
Re: Random Crashes on Linux Mint 17.1 [message #1759543 is a reply to message #1759438] Wed, 12 April 2017 14:44 Go to previous messageGo to next message
Thanks. As I mentioned I have NO crashes with Eclipls neon.3 running under Ubuntu Mate 16.04.2 running in VirtualBox running on Linux Mint 17.1 64 bit. It is only when trying to install and run the 64 bit version of Neon that I have crashes.
I purged everything related to java yesterday and did a fresh install of the latest Java JDK 8 from Oracle. Then I did a fresh install of Eclipse Neon.3 and right out of the gate it crashes.
I used the installer to perform the installation and there were no errors reported but when I launched Eclipse it came up to the point of selecting the workspace, which I did and then after that it crashed and burned, and trying to restart Eclipse just gives a crash without getting to the workspace dialog, at least on the 3 tries to start I've done so far.
In the eclipse.ini file how did you specify to use gtk2 and not gtk3? I don't spot anything other than there is a launcher.gtk.linux.x86_64... being specified.
My eclipse.ini file:
-startup
plugins/org.eclipse.equinox.launcher_1.3.201.v20161025-1711.jar
--launcher.library
/home/bbick/.p2/pool/plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.401.v20161122-1740
-product
--launcher.defaultAction
openFile
-showsplash
org.eclipse.platform
--launcher.appendVmargs
-vm
/usr/lib/jvm/java-8-oracle/jre/bin
-vmargs
-Dosgi.requiredJavaVersion=1.8
-XX:+UseG1GC
-XX:+UseStringDeduplication
-Xms256m
-Xmx1024m
-Declipse.p2.max.threads=10
-Doomph.update.url=http://download.eclipse.org/oomph/updates/milestone/latest
-Doomph.redirection.index.redirection=index:/->http://git.eclipse.org/c/oomph/org.eclipse.oomph.git/plain/setups/
I've attached the hs_err_pid.log file for good measure if anyone can spot something that is useful there.
BTW the 4th try at launching Eclipse did get far enough to actually bring up the IDE. But I don't have a lot of faith that it will work reliably.
Burt
Re: Random Crashes on Linux Mint 17.1 [message #1764738 is a reply to message #1759543] Thu, 01 June 2017 21:25 Go to previous message
Did you ever find a solution to your problem?
I'm hitting something very similar - Eclipse locks and crashes immediately after the main window appears on RHEL 6.
In my case I don't even get a log or hs crash dump.
Previous Topic:Migrating Java Code on Eclipse into an HTML file
Next Topic:Beginers basic questions
Current Time: Sat Aug 30 13:21:17 EDT 2025
Powered by FUDForum. Page generated in 0.10866 seconds
