Home » Modeling » TMF (Xtext) » Import issues regarding qualified names
Import issues regarding qualified names [message #1759209] Fri, 07 April 2017 21:20 Go to next message
Hi Christian, (and anyone else available)
With my previous question asking about cross-referencing between files, it works brilliantly, but I have realised a flaw as a result of it.
Lets say I have two folders, one named "first" and one named "second"; they both have two files with the same name. How am I supposed to differentiate? Well I would add in the folder as part of the qualified name to differentiate:
use first.Test
use second.Test
class ChildOfFirst parent first.Test { }
class ChildOfSecond parent second.Test { }
The import code you gave me works fine if I only really use something out of one of these, but when I have two, how can I programmatically differentiate between the two? To be a pain, theres three ways I really need this to go:
  1. If a local type is defined:
    • It can be referenced simply by typing in the types name, example Class
    1. If ANY AMOUNT of external types are defined:
      • Define them by typing in the fully qualified name, example: test.Class
  2. If the local type is NOT defined:
    1. If ONE external type is defined:
    1. If MORE THAN ONE external type is defined:
Maybe I'm asking for too much Sad I don't know....
My DSL is as follows:
Model
grammar org.thusix.omicron.Omicron with org.eclipse.xtext.common.Terminals
generate omicron "http://www.thusix.org/omicron/Omicron"
Model:
	package=PackageDeclaration
	imports+=ImportDeclaration*
	declarations+=TopDeclaration*
PackageDeclaration:
	'package' name=FQN
ImportDeclaration:
	'use' importURI=FQN
TopDeclaration:
	Type | VariableDeclaration
TypeType:
	Primitive | TypeRef
TypeRef:
	ref=[Type | FQN]
Type:
	FunctionType | ClassType | StructType | EnumType
FunctionType:
	modifiers+=Modifier* 'func' name=ID '(' ')' ':' returnType=TypeType LBRACE
		fields+=Field*
	RBRACE
ClassType:
	modifiers+=TypeModifier* 'class' name=ID ('parent' superType=TypeRef)? ('inherits' templates+=TypeRef*)? LBRACE
		fields+=Field*
	RBRACE
StructType:
	modifiers+=TypeModifier* 'struct' name=ID LBRACE
		declares+=VariableDeclaration*
	RBRACE
EnumType:
	modifiers+=TypeModifier* 'enum' name=ID LBRACE
		values+=ID*
	RBRACE
Field:
	VariableDeclaration | Type
VariableDeclaration:
	modifiers+=Modifier* name=ID ':' type=TypeType
/* Statements */
/* Terminals and strings. */
TypeModifier:
	'public' |
	'final' |
	'abstract'
Modifier:
	TypeModifier |
	'protected' |
	'private' |
	'static'
Primitive:
	name=('int' |
	'long' |
	'short' |
	'float' |
	'double' |
	'str' |
	'char' |
	'bool' |
	'obj' |
	'byte' |
	'nil')
FQN:
	ID ('.' ID)*
terminal LBRACE: '{' ;
terminal RBRACE: '}' ;
Christian's Import Resolver:
package org.thusix.omicron.resolvers;
import com.google.inject.Inject
import org.eclipse.emf.ecore.EObject
import org.eclipse.xtext.resource.FileExtensionProvider
import org.eclipse.xtext.scoping.impl.ImportUriResolver
public class OmicronImportResolver extends ImportUriResolver {
	@Inject
	FileExtensionProvider fileExtensionProvider;
	override String apply(EObject from) {
		// TODO make more robust / potentially work in standlone mode if needed
		// or classpath:/my/pack/xxxx.mydsl if needed as well
		var apply = super.apply(from);
		if (apply === null) {
			return apply;
		var result = "platform:/resource/" + from.eResource().getURI().segmentsList().get(1) + "/"
				+ apply.replaceAll("\\.", "/") + "." + fileExtensionProvider.getPrimaryFileExtension();
		return result;
I'll include anything else you need if required.
Any help is much appreciated all.
[Updated on: Sat, 08 April 2017 02:37] by Moderator
Re: Using filenames in cross-references and fixing import issues [message #1759214 is a reply to message #1759209] Sat, 08 April 2017 01:20 Go to previous messageGo to next message
What is your actual question.
How to write a validation that prevents this case?
Re: Using filenames in cross-references and fixing import issues [message #1759215 is a reply to message #1759214] Sat, 08 April 2017 01:24 Go to previous messageGo to next message
And regarding the naming.
You can cross reference objects only so you could reference the roots of your Modell
You can adapt the name provider.
Of course this will only work if you import the file
But hey you don't want to import the file
Sorry I am totally confused by your rules of what to use and what to import etc
Re: Using filenames in cross-references and fixing import issues [message #1759216 is a reply to message #1759215] Sat, 08 April 2017 01:32 Go to previous messageGo to next message
And you you can do such things e.g. By I,plementing the scope provider
And create some aliasedebjectdescriptions where when wrapping /transforming
DelegateGetScope(ctx,ref) but implementing this will be pain
And I won't be able to do this for you
Re: Using filenames in cross-references and fixing import issues [message #1759217 is a reply to message #1759216] Sat, 08 April 2017 01:35 Go to previous messageGo to next message
The other idea would be to simply give the elements
Simple and qualified names and let the default behaviour do. the job for that
public class StrangeDefaultResourceDescriptionStrategy extends DefaultResourceDescriptionStrategy {
	public boolean createEObjectDescriptions(EObject eObject, IAcceptor<IEObjectDescription> acceptor) {
		if (eObject instanceof Type) {
			Type type = (Type)eObject;
			if (type.getName() != null) {
				acceptor.accept(EObjectDescription.create(QualifiedName.create(type.getName()), type));
		return super.createEObjectDescriptions(eObject, acceptor);
	def Class<? extends IDefaultResourceDescriptionStrategy> bindIDefaultResourceDescriptionStrategy() {
this has unforunately a first one wins rule.
what you dont like if i got you right
[Updated on: Sat, 08 April 2017 02:23] by Moderator
Re: Using filenames in cross-references and fixing import issues [message #1759218 is a reply to message #1759217] Sat, 08 April 2017 02:08 Go to previous messageGo to next message
Hey Christian,
yea it's a bit of a pain, and I wrote this quickly in the morning before work.
I might just adapt the whole model thing to cater for the first part of the question which really just gives users a bit more choice as well...
As for the second part, another way of wording it, is that I want to be able to first of all, be able to reference my imported types with fully qualified names including the package they are located in opposed to just their names, and I would secondly like to be forced to use fully qualified names only if there is more than one of them imported with the same name, or a local one exists.
Re: Using filenames in cross-references and fixing import issues [message #1759219 is a reply to message #1759217] Sat, 08 April 2017 02:22 Go to previous messageGo to next message
well you can adapt this as well but i dont know if you can live with the perfomance impacts
import java.util.ArrayList;
import java.util.Collections;
import java.util.Iterator;
import java.util.LinkedHashSet;
import java.util.List;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.EClass;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.xtext.naming.QualifiedName;
import org.eclipse.xtext.resource.IEObjectDescription;
import org.eclipse.xtext.resource.IResourceDescription;
import org.eclipse.xtext.resource.IResourceDescriptions;
import org.eclipse.xtext.resource.ISelectable;
import org.eclipse.xtext.scoping.IScope;
import org.eclipse.xtext.scoping.impl.ImportUriGlobalScopeProvider;
import org.eclipse.xtext.scoping.impl.MultimapBasedSelectable;
import org.eclipse.xtext.scoping.impl.SelectableBasedScope;
import com.google.common.base.Predicate;
import com.google.common.collect.Lists;
public class StrangeImportUriGlobalScopeProvider extends ImportUriGlobalScopeProvider {
	protected IScope getScope(Resource resource, boolean ignoreCase, EClass type, Predicate<IEObjectDescription> filter) {
		final LinkedHashSet<URI> uniqueImportURIs = getImportedUris(resource);
		IResourceDescriptions descriptions = getResourceDescriptions(resource, uniqueImportURIs);
		List<URI> urisAsList = Lists.newArrayList(uniqueImportURIs);
		Collections.reverse(urisAsList);
		IScope scope = IScope.NULLSCOPE;
		List<IEObjectDescription> descs = new ArrayList<>();
		for (URI uri : urisAsList) {
			IResourceDescription description = descriptions.getResourceDescription(uri);
			descs.addAll(Lists.newArrayList(description.getExportedObjects()));
		MultimapBasedSelectable selectable = new MultimapBasedSelectable(descs);
		return new SelectableBasedScope2(scope, selectable, filter, type, ignoreCase);
//		for (URI uri : urisAsList) {
//			scope = createLazyResourceScope(scope, uri, descriptions, type, filter, ignoreCase);
//		return scope;
	protected IScope createLazyResourceScope(IScope parent, final URI uri, final IResourceDescriptions descriptions,
			EClass type, final Predicate<IEObjectDescription> filter, boolean ignoreCase) {
		return SelectableBasedScope.createScope(parent, description, filter, type, ignoreCase);
	static class SelectableBasedScope2 extends SelectableBasedScope {
		public SelectableBasedScope2(IScope outer, ISelectable selectable, Predicate<IEObjectDescription> filter,
				EClass type, boolean ignoreCase) {
			super(outer, selectable, filter, type, ignoreCase);
		protected IEObjectDescription getSingleLocalElementByName(QualifiedName name) {
			Iterable<IEObjectDescription> result = getLocalElementsByName(name);
			Iterator<IEObjectDescription> iterator = result.iterator();
			if (iterator.hasNext()) {
				IEObjectDescription next = iterator.next();
					return null;
				return next;
			return null;
	override bindIGlobalScopeProvider() {
Re: Using filenames in cross-references and fixing import issues [message #1759220 is a reply to message #1759219] Sat, 08 April 2017 02:24 Go to previous messageGo to next message
can you have a look at my other two posts with code if they help you?
Re: Using filenames in cross-references and fixing import issues [message #1759221 is a reply to message #1759220] Sat, 08 April 2017 02:26 Go to previous messageGo to next message
p.s. local names win over global ones in both cases
Re: Using filenames in cross-references and fixing import issues [message #1759222 is a reply to message #1759220] Sat, 08 April 2017 02:28 Go to previous messageGo to next message
p.s: and i still dont understand the first part of your question. i really dont.
you "use" files, not classes.
Re: Using filenames in cross-references and fixing import issues [message #1759223 is a reply to message #1759222] Sat, 08 April 2017 02:35 Go to previous messageGo to next message
Thanks for the code, I'll set it all out now and see how it goes.
As for the first part of the question, just ignore it and pretend it never happened. I'll edit it out. Very Happy
Re: Using filenames in cross-references and fixing import issues [message #1759225 is a reply to message #1759223] Sat, 08 April 2017 03:05 Go to previous messageGo to next message
Alrighty that seems to have not done a thing sorry...
My runtime module is as follows:
 * generated by Xtext 2.11.0
import org.eclipse.xtext.resource.IDefaultResourceDescriptionStrategy
import org.thusix.omicron.resolvers.OmicronImportResolver
import org.thusix.omicron.resolvers.OmicronNameProvider
import org.thusix.omicron.resolvers.StrangeDefaultResourceDescriptionStrategy
import org.thusix.omicron.resolvers.StrangeImportUriGlobalScopeProvider
 * Use this class to register components to be used at runtime / without the Equinox extension registry.
class OmicronRuntimeModule extends AbstractOmicronRuntimeModule {
	override bindIQualifiedNameProvider() {
		OmicronNameProvider
	def Class<? extends ImportUriResolver> bindImportUriResolver() {
And it just won't find them at all.
I removed the first part of the question, but I can't even get it to work on my own so I really need your help!
You said earlier that you are confused by my mechanism of imports. In Java, you import classes. In the DSL, you can import files, and classes in those files. At the moment from what we currently have, I am only able to import a class inside of a file.
This is why I was asking how to get a filename to work as a cross-reference. My generator can cope just fine as long as it gets recognised as one in the code....
index.php/fa/29002/0/
[Updated on: Sat, 08 April 2017 03:06] by Moderator
Re: Using filenames in cross-references and fixing import issues [message #1759226 is a reply to message #1759225] Sat, 08 April 2017 03:22 Go to previous messageGo to next message
you can reference the model
xxx=[Model|FQN]
but this wont work since you need a use "xxxx.yyyy.Model" as well.
this is what makes me understand zero of your requirements Sad
and i dont understand your screenshot.
it should be
use src.Deck. why do you have test.Deck?
Re: Using filenames in cross-references and fixing import issues [message #1759227 is a reply to message #1759226] Sat, 08 April 2017 03:36 Go to previous messageGo to next message
p.s.:
if you dont care about files at all but about logical elements only
this would have to be done 100% differently.
but as i said: i dont understand how your
- physical package
- physical file name
- modeled package
- modeled file
- modeled class
play together and how names are built
Re: Using filenames in cross-references and fixing import issues [message #1759228 is a reply to message #1759226] Sat, 08 April 2017 03:37 Go to previous messageGo to next message
Pardon me, I use "test.Deck" because as I generate my Java source, that package declaration is what specifies the folder I place my files in.
The src-gen folder has a "test" package with both files in it.
Back in my previous questions, you were able to help me setup an import system that would trace through that package declaration system, not the literal file system, so regardless of where the files are located, I still want the package-system to be used.
Once I get the DSL going I'll obviously stick an error-checker in to force people to make the file system adhere to the package system. So for now, regardless of what the file system says, please assume that it is identical to that of the package one.
I've taken another screenshot with a bunch of examples of the current state, and some comments as to what is happening.
index.php/fa/29003/0/
PS: I'm slapping that [Type | Model] thing in now to see how it goes.
PPS: It works brilliant! Thankyou. First part of the problem solved. Now just this above import nonsense.
[Updated on: Sat, 08 April 2017 03:41] by Moderator
Re: Using filenames in cross-references and fixing import issues [message #1759229 is a reply to message #1759228] Sat, 08 April 2017 03:39 Go to previous messageGo to next message
can you share your example project
Re: Using filenames in cross-references and fixing import issues [message #1759230 is a reply to message #1759229] Sat, 08 April 2017 03:42 Go to previous messageGo to next message
and still the question
: if in model
package a.b.c
file Whatever
class D {}
the classes name is a.b.c.D? or a.b.c.Whatever.D
or you have to import it like
use a.b.c.Whatever
and reference it like a.b.c.D ???
then why not use it like in java?
Re: Using filenames in cross-references and fixing import issues [message #1759231 is a reply to message #1759229] Sat, 08 April 2017 03:45 Go to previous messageGo to next message
Are you talking about the project in the screenshots?
I've got it on Dropbox here.
Re: Using filenames in cross-references and fixing import issues [message #1759232 is a reply to message #1759230] Sat, 08 April 2017 03:50 Go to previous messageGo to next message
Nice example.
The class should be referenced like a.b.c.Whatever.D, in all scenarios.
When you import things, your not importing that D class, your going through Whatever, which is a file/class, and then to D.
If you want to import OR reference D and ignore Whatever, then do with the following:
use a.b.c.Whatever.D // bypasses Whatever and goes straight to D
class Other parent D {} // since theres no local references
class Other parent a.b.c.Whatever.D // full name
Re: Using filenames in cross-references and fixing import issues [message #1759234 is a reply to message #1759232] Sat, 08 April 2017 04:08 Go to previous messageGo to next message
maybe
public class StrangeNameProvider extends DefaultDeclarativeQualifiedNameProvider {
	QualifiedName qualifiedName(Model type) {
                // use complete file name
		String[] segments = type.eResource().getURI().trimFileExtension().segments();
		return QualifiedName.create(Arrays.copyOfRange(segments, 2, segments.length));
// make model be a type
Model returns Type: {Model}
take care of type types and model type available under simply/qualified name
		if (eObject instanceof ClassType) {
			ClassType type = (ClassType)eObject;
		} else if (eObject instanceof EnumType) {
			EnumType type = (EnumType)eObject;
		} else if (eObject instanceof StructType) {
			StructType type = (StructType)eObject;
		} else if (eObject instanceof FunctionType) {
			FunctionType type = (FunctionType)eObject;
		}  else if (eObject instanceof Model) {
			Model type = (Model)eObject;
			acceptor.accept(EObjectDescription.create(QualifiedName.create(type.eResource().getURI().trimFileExtension().lastSegment()), type));
Re: Using filenames in cross-references and fixing import issues [message #1759236 is a reply to message #1759234] Sat, 08 April 2017 04:32 Go to previous messageGo to next message
Christian you are so close!
I just want you to know that I feel terrible for relying on you for something this stupidly specific, and definitely appreciate all the help that you have given me, and I couldn't of done half of this without you!
It looks like a mess, but the real only issue is that the importer is now looking through every scope of the imported file.
Same Dropbox link too.
index.php/fa/29004/0/
Re: Using filenames in cross-references and fixing import issues [message #1759237 is a reply to message #1759236] Sat, 08 April 2017 04:38 Go to previous messageGo to next message
You know what, I think the easier way to put this is do exactly what Java does, except take the Model as a valid type, and only have the need to scope through packages without going back say two folders to stdlib, or even a classpath-source folder.
[Updated on: Sat, 08 April 2017 04:43] by Moderator
Re: Using filenames in cross-references and fixing import issues [message #1759242 is a reply to message #1759237] Sat, 08 April 2017 05:06 Go to previous messageGo to next message
well the number of customizations is going to explode.
i have my doubt there is anybody on the planet that can understand the requirements ....
and they get stranger again,
why cant you import nested classes under the simple name if it is unique ?!? ?????????
i have the feeling i should stop supporting you at this point Sad
that is too much WORK for me.
	override configureIScopeProviderDelegate(Binder binder) {
		binder.bind(IScopeProvider).annotatedWith(Names.named(AbstractDeclarativeScopeProvider.NAMED_DELEGATE)).to(StrangeImportedNamespaceAwareLocalScopeProvider);
public class StrangeImportedNamespaceAwareLocalScopeProvider extends ImportedNamespaceAwareLocalScopeProvider {
	@Inject
	SimpleNameProvider2 snp;
	protected ISelectable internalGetAllDescriptions(Resource resource) {
		Iterable<EObject> allContents = new Iterable<EObject>(){
			public Iterator<EObject> iterator() {
				return EcoreUtil.getAllContents(resource, false);
		Iterable<IEObjectDescription> allDescriptions = Scopes.scopedElementsFor(allContents, snp);
		return new MultimapBasedSelectable(allDescriptions);
	protected List<ImportNormalizer> getImportedNamespaceResolvers(EObject context, boolean ignoreCase) {
		List<ImportNormalizer> importedNamespaceResolvers = super.getImportedNamespaceResolvers(context, ignoreCase);
		if (context instanceof Model) {
			for (ImportDeclaration decl : ((Model) context).getImports()) {
				// relative import, might no do what you want
				// class AClass parent TestClass.NestedClass {}
				importedNamespaceResolvers.add(doCreateImportNormalizer(getQualifiedNameConverter().toQualifiedName(decl.getImportURI()), true, ignoreCase));
		return importedNamespaceResolvers;
	static class SimpleNameProvider2 extends SimpleNameProvider {
		public QualifiedName getFullyQualifiedName(EObject obj) {
			if (obj instanceof Model) {
				return QualifiedName.create(obj.eResource().getURI().trimFileExtension().lastSegment());
			return super.getFullyQualifiedName(obj);
maybe you should do a completely different approach and
- remove the customization of bindIGlobalScopeProvider
- remove the customization of bindImportUriResolver
- remove the customization of IDefaultResourceDescriptionStrategy
- remove the customization of configureIScopeProviderDelegate
- change the grammar to
ImportDeclaration:
	'use' mode=[Model|FQN]
and implement this one here:
class MyDslFinnScopeProvider extends AbstractMyDslFinnScopeProvider {
	override getScope(EObject context, EReference reference) {
		if (MyDslFinnPackage.Literals.TYPE_REF__REF === reference) {
			val List<IEObjectDescription> scope = new ArrayList
			// TODO traverse content up to model (EcoreUtil2.getContainerOfType)
			// collect all local types and the types referenced in the import.
			// calculate the visible elements and there name
			val EObject someObject = ....
			val QualifiedName name = QualifiedName.create("a","b","C","D")
			scope.add(EObjectDescription.create(name, someObject));
			return new SimpleScope(IScope.NULLSCOPE, scope)
		super.getScope(context, reference)
Re: Using filenames in cross-references and fixing import issues [message #1759244 is a reply to message #1759242] Sat, 08 April 2017 08:08 Go to previous messageGo to next message
Thanks for all your help Christian, I'm glad you've been able to support me for so long with such absurd requests. If you feel it is too much for you, please let me know! You come before me! Sad
I've been poking around for a while, and have come to an almost perfectly clear solution. If you look at the below picture:
index.php/fa/29008/0/
The middle section specifically, I can get the three of them to work, but the other three wont work. Thats fine, because I want you to take a look at the DSLNameProvider:
class OmicronNameProvider extends DefaultDeclarativeQualifiedNameProvider {
	def QualifiedName qualifiedName(Model type) {
		return QualifiedName.create(type.eResource().getURI().trimFileExtension().lastSegment());
	/*def QualifiedName qualifiedName(Model type) {
		var String[] segments = type.eResource().getURI().trimFileExtension().segments();
This picture, is taken using the top solution. Except! If I instead decide to use the bottom function, and comment out the top one, this happens:
index.php/fa/29006/0/
See how the errors flip between the two? I think I understand why this happens too, because it's validating one way as being correct but not the other. I was wondering if you know how to make it accept both of these functions, or somehow merge the two together? If we can get it to accept both, then thats literally all there is to it!
I also tinkered with the RuntimeModule, and here are the functions you gave me that seemed to work correctly. I'm sorry about before with all the crap with it... Confused
	// Lets me use the local file as a type both with and without the folder as a part of the name...
	// Requires imports to be added before they become available in the local scope.
	// Provides the name of the type. This includes the folder prefixes.
		OmicronNameProvider
	// Converts the import into a valid format.
		OmicronImportUriResolver
And a few modifications to StrangeImportedNamespaceAwareLocalScopeProvider which was very useful so thankyou!
import java.util.Arrays;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.emf.ecore.util.EcoreUtil;
import org.eclipse.xtext.naming.SimpleNameProvider;
import org.eclipse.xtext.scoping.Scopes;
import org.eclipse.xtext.scoping.impl.ImportedNamespaceAwareLocalScopeProvider;
import org.thusix.omicron.omicron.ImportDeclaration;
import org.thusix.omicron.omicron.Model;
import org.thusix.omicron.omicron.Type;
import com.google.inject.Inject;
	@Inject
		// Used for local qualified name usage with folder prefix at the beginning.
		EObject localWithFolders = null;
			if (obj instanceof ImportDeclaration) {
				localWithFolders = obj;
			if (obj instanceof Type && localWithFolders != null) {
				String[] segments = localWithFolders.eResource().getURI().trimFileExtension().segments();
[Updated on: Sat, 08 April 2017 08:12] by Moderator
Re: Using filenames in cross-references and fixing import issues [message #1759245 is a reply to message #1759244] Sat, 08 April 2017 08:43 Go to previous message
i customized StrangeImportUriGlobalScopeProvider and StrangeDefaultResourceDescriptionStrategy for a reason
the last one --> StrangeDefaultResourceDescriptionStrategy is the one that takes care that stuff is available on both names
StrangeImportedNamespaceAwareLocalScopeProvider does relative imports (based on the global names)
but i strogly recommend you to go the other approach (implement mydslscopeprovider)
that will give you complete freedom
[Updated on: Sat, 08 April 2017 08:46] by Moderator
Previous Topic:2 DSLs and 1 Ecore-Model
Next Topic:Cross Reference
Current Time: Sun Jul 27 06:42:40 EDT 2025
Powered by FUDForum. Page generated in 0.08795 seconds
