Home » Eclipse Projects » Lyo » Version 3.0.0 of lyo ?(New release of lyo when)
Version 3.0.0 of lyo ? [message #1746330] Thu, 27 October 2016 02:56 Go to next message
I just want to know if there is a date where the 3.0.0 release. In maven repository the last release version is the 2.1.0 but when you clone the lyo repo the version is 3.0.0-SNAPSHOT. Because for Example in JazzFormAuthClient.java the function formlogin() is deprecated in 3.0.0-SNAPSHOT.
[Updated on: Fri, 28 October 2016 10:43] by Moderator
Re: Version 3.0.0 of lyo ? [message #1746522 is a reply to message #1746330] Mon, 31 October 2016 10:58 Go to previous messageGo to next message
There is currently no plans in place for Lyo 3.0. The Lyo client libs were updated recently to include a number minor fixes that have been done over the last couple of years, and that's why the client lib .zip has a version number difference, but the main project version number only has a minor increment.
JazzFormAuthClient.formLogin() was deprecated some time ago and it now just calls login(). Older code will still work, but newer code should just call login() instead of formLogin().
Re: Version 3.0.0 of lyo ? [message #1746523 is a reply to message #1746330] Mon, 31 October 2016 11:00 Go to previous messageGo to next message
Re: Version 3.0.0 of lyo ? [message #1746696 is a reply to message #1746523] Thu, 03 November 2016 06:57 Go to previous messageGo to next message
Thanks for your ansmwer. But as I know in maven usage it is not recommended to have a dependecy of kind snapshot. So If I want to use lyo in my project I can only use 2.1.0 version. Because this version is the last release I know. If I understand you said that to have the last version of lyo, the best is to download the last jar and include it in my project in "old" style without using maven ?
Re: Version 3.0.0 of lyo ? [message #1749601 is a reply to message #1746696] Thu, 08 December 2016 09:06 Go to previous messageGo to next message
We are working on a smaller release in the near future, could you please describe what parts are missing for you in 2.1.0 as compared to 3.0.0 snapshot?
Andrew
Re: Version 3.0.0 of lyo ? [message #1754962 is a reply to message #1746330] Fri, 24 February 2017 10:55 Go to previous messageGo to next message
Sorry for the very late answer. Embarrassed
I have no real need for the 3.0.0.
I just want to not use a snapshot instead of a release version.
Thanks.
Re: Version 3.0.0 of lyo ? [message #1755080 is a reply to message #1754962] Mon, 27 February 2017 15:51 Go to previous messageGo to next message
We are working on a 2.1.2 release (https://bugs.eclipse.org/bugs/show_bug.cgi?id=512051). Would you be interested to give it a try before the release?
Re: Version 3.0.0 of lyo ? [message #1759087 is a reply to message #1749601] Thu, 06 April 2017 03:36 Go to previous message
I am not on a project with Lyo for now but it will be back soon.
So do the release and I will use it after.
Thanks.
Previous Topic:OslcClient hangs while updating ChangeRequest
Next Topic:Implementation of AbstractResource lack some information
Current Time: Mon Jul 21 03:41:27 EDT 2025
Powered by FUDForum. Page generated in 0.31349 seconds
