| Expand/Collapse Node Refresh Issue [message #175903] |
Wed, 06 April 2005 15:55   |
Eclipse User  |
Originally posted by: jduley.mail.arc.nasa.gov
In my application (based on the schema editor example), nodes can be
expanded or collapsed.  When I trigger a collapse, the figure does not
update until I move the node to a different location.  The same issue
happens when I expand it back.  Something is happening during the move
operation that is refreshing the node so that the correct state is shown
on the view.  Any ideas as to why the node is not updated properly prior
to the move?  Also, the outline view does in fact respond properly to
the expand/collapse.  Thanks.
Jason
| Re: Expand/Collapse Node Refresh Issue [message #176011 is a reply to message #175903] |
Thu, 07 April 2005 09:48    |
Eclipse User  |
Jason,
When you move your EditPart - usually, you would call refreshVisuals(),
which in turn *changes the constraints* of your EditPart. As a result - the
Layout algorithm would redraw the figure by using the modifed constraints to
set the figures bounds.
Perhaps when you collapse / expand your node, you're missing the above
steps, maybe you're not firing a visual change.
Hope this helps,
Brian.
"Jason Duley" <jduley@mail.arc.nasa.gov> wrote in message
news:d31f3d$pgi$1@news.eclipse.org...
> to the move?  Also, the outline view does in fact respond properly to the
> Jason
| Re: Expand/Collapse Node Refresh Issue [message #176039 is a reply to message #175903] |
Thu, 07 April 2005 10:29   |
Eclipse User  |
You need to call revalidate().
> Jason
FUDForum. Page generated in 0.03358 seconds
