Home » Modeling » TMF (Xtext) » Xtext multiple parameter to a method possibility(Want to know is it possible to provide a production rule and a terminal rule as a possible parameter to a method together.)
icon7.gif  Xtext multiple parameter to a method possibility [message #1758074] Thu, 23 March 2017 05:53 Go to next message
Please find the xtext grammar sample attached. I have a following rule.
SomeFunction:
name=('addDays' | 'addWeeks' | 'addYears') '(' value=NUMBER ')';
terminal NUMBER returns ecore::ELong:
'-'?('0'..'9')+;
All other things are defined and working fine. What I want to change is that to add a production rule as a possible alternative in the parameters of SomeFunction , which is as follows -
SomeFunction:
name=('addDays' | 'addWeeks' | 'addYears') '(' value=(NUMBER | ProductionRule_A) ')';
I'm getting an error which is as follows - Cannot find type for 'NUMBER | ProductionRule_A'.
Please guide me whether it's possible to do so. IF not why. IF yes how can i do this.
Re: Xtext multiple parameter to a method possibility [message #1758099 is a reply to message #1758074] Thu, 23 March 2017 10:20 Go to previous messageGo to next message
is ProductionRule_A a parser rule. if so this makes no sense: a attribute cannot be ob a simple and a complex type at the same time.
maybe you want to
.... value=(NumberLiteral | ProductionRule_A)
NumberLiteral: number=NUMBER;
Re: Xtext multiple parameter to a method possibility [message #1758992 is a reply to message #1758099] Wed, 05 April 2017 02:06 Go to previous messageGo to next message
Yes ProductionRule_A is a parser rule. Is it possible/allowed to be used like this ?
Using your suggestion, it fails in the content assist, for e.g. when I'm about to complete the ProcutionRule_A , the model comes out to be null in my custom proposal provider class, in the completeXXXXX method. How to deal with that ?
Additionally i wanted to enquire or you can guide me to some resource that clearly states that whether or not we can/cannot use simple and complex type attributes in a method parameters list in Xtext using the grammar.
[Updated on: Wed, 05 April 2017 02:08] by Moderator
Re: Xtext multiple parameter to a method possibility [message #1758995 is a reply to message #1758992] Wed, 05 April 2017 02:47 Go to previous messageGo to next message
can you please give a complete hello world sample grammar with failing CA
Re: Xtext multiple parameter to a method possibility [message #1758999 is a reply to message #1758995] Wed, 05 April 2017 03:31 Go to previous messageGo to next message
Yes I'll just share it in my next reply
Re: Xtext multiple parameter to a method possibility [message #1759000 is a reply to message #1758995] Wed, 05 April 2017 03:31 Go to previous message
Previous Topic:Cross referencing pre-defined "terminals"
Next Topic:Limiting cross-reference to a single file
Current Time: Mon Jul 21 05:13:06 EDT 2025
Powered by FUDForum. Page generated in 0.28527 seconds
