Home » Modeling » TMF (Xtext) » Limiting cross-reference to a single file
Limiting cross-reference to a single file [message #1758920] Tue, 04 April 2017 11:30 Go to next message
Hi all, I'm using the below grammar at the moment:
Model:
	package=PackageDeclaration
	imports+=ImportDeclaration*
	types+=Type*
PackageDeclaration:
	'namespace' name=FQN
ImportDeclaration:
	'use' name=FQN
TypeType:
	Primitive | TypeRef
TypeRef:
	ref=[Type | FQN]
Type:
	FunctionType | ClassType | EnumType
FunctionType:
	'func' name=ID ':' returnType=TypeType LBRACE
	RBRACE
ClassType:
	'class' name=ID ('parent' superType=TypeRef)? ('inherits' templates+=TypeRef*)? LBRACE
	RBRACE
EnumType:
	'enum' name=ID LBRACE
		values+=ID*
	RBRACE
/* Terminals and strings. */
Primitive:
	name=('int' |
	'long' |
	'short' |
	'float' |
	'double' |
	'str' |
	'char' |
	'bool' |
	'obj' |
	'byte' |
	'nil')
FQN:
	ID ('.' ID)*
terminal LBRACE: '{' ;
terminal RBRACE: '}' ;
When I run this, I can happily create something like the following:
func TestFunction: RandomType {
But oh no! I get an error, because RandomType doesn't exist. Fair enough, so I'm easily able to define RandomType in the file. This is what I want to happen.
What actually happens, is that I can open up a completely different file, and define RandomType, and the other file will automatically remove the error, because it found a RandomType.
The problem is, my program is able to see across multiple files, which I don't want to happen, unless someone uses the ImportDeclaration function which I have also got in the grammar above. Is there a simple way I can limit the cross-referencing capabilities of Xtext?
Thanks for any and all help. Smile
[Updated on: Tue, 04 April 2017 11:31] by Moderator
Re: Limiting cross-reference to a single file [message #1758923 is a reply to message #1758920] Tue, 04 April 2017 11:56 Go to previous messageGo to next message
Can you please elaborate how qualified and non qualified names work in your dsl.
Why do you allow xxxx=[yyyy|FQN] at all and don't use xxxxx=[yyyyyy|ID]
Re: Limiting cross-reference to a single file [message #1758924 is a reply to message #1758923] Tue, 04 April 2017 12:02 Go to previous messageGo to next message
Ps maybe you need reshuffel your grammar to
To get implicit parent child imports
Model:
PackageDeclaration:
types+=Type*;
Re: Limiting cross-reference to a single file [message #1758932 is a reply to message #1758923] Tue, 04 April 2017 13:16 Go to previous messageGo to next message
To be honest I have no idea.
If you look at my other question here:
https://www.eclipse.org/forums/index.php/t/1085364/
I'm pretty much just trying to incorporate the supposed solution into the grammar.
Re: Limiting cross-reference to a single file [message #1758934 is a reply to message #1758923] Tue, 04 April 2017 13:18 Go to previous messageGo to next message
In the grammar at this moment in time, ID's are only used for naming the types (class, enum and function). The Qualified Names can be used for class parents, and class inherits.
The thing is though, the Qualified Names are created with ID's, so in reality, they work hand-in-hand.
Re: Limiting cross-reference to a single file [message #1758936 is a reply to message #1758934] Tue, 04 April 2017 13:22 Go to previous messageGo to next message
Can you please share for the other problem a complete sample model.
For this problem: can you ever have a qualified name for a thing that comes from the local file and if yes which are these elements
Can you please share a complete represenative sample model for having 2 files with local and foreign references as well
Re: Limiting cross-reference to a single file [message #1758941 is a reply to message #1758936] Tue, 04 April 2017 13:30 Go to previous messageGo to next message
Funnily enough sorry, the sample model is this model. I posted them as seperate questions as they refer to different issues entirely.
As for an example in practice, one might do the following:
File 1: first_file.ext
namespace random.folders    // see how this is a FQN?
use random.folders.second_file     // also a FQN
class ChildClass parent second_file.ParentClass {
    // ChildClass MUST be an ID, not a FQN,
    // however parent can be either an ID or a FQN.
    // By definition, the FQN's include ID's anyway.
    // There is no actual definition of ParentClass in this file,
    // so I would rather be referencing it like so, instead of just typing:
    //     "parent ParentClass". Because at the moment, it accepts that
    // as valid, which if you compare that to a regular language like Java,
    //   "ParentClass" does not exist in this file, so in reality, it SHOULDN't be correct.
    // the entire "parent" thing here, is a foreign reference.
File 2: second_file.ext
class ParentClass {
    // Again, "ParentClass" is an ID, not a FQN.
// Anything below here is just to represent LOCAL references.
class Test { }
class TestChild parent Test { } // Notice how the parent is technically an ID because its local?
The same thing goes for enums as it does for the class. Names are ID's, parents (which the enum doesnt have) are FQN's.
Hope your able to understand my lack of proper articulation. I appreciate your help.
[Updated on: Tue, 04 April 2017 13:34] by Moderator
Re: Limiting cross-reference to a single file [message #1758943 is a reply to message #1758936] Tue, 04 April 2017 13:39 Go to previous messageGo to next message
Heres a quick picture of what I'm talking about:
index.php/fa/28971/0/
Where 'a' is a class in another file.
This is wrong because its acting as if its local, but its foreign. The error should be the other way around.
'C' is also foreign, but shown as local, and produces no errors. :/
[Updated on: Tue, 04 April 2017 13:41] by Moderator
Re: Limiting cross-reference to a single file [message #1758944 is a reply to message #1758943] Tue, 04 April 2017 13:52 Go to previous messageGo to next message
i have a question,
why: namespace random.folders
but
how does your name provider look like?
[Updated on: Tue, 04 April 2017 13:53] by Moderator
Re: Limiting cross-reference to a single file [message #1758976 is a reply to message #1758944] Tue, 04 April 2017 20:37 Go to previous messageGo to next message
Refers to importing the file called "second_file" inside of the folder "random/folders".
Since "second_file" from folder "random/folders" has now been imported, you only have to reference things that come from it with "second_file".
Much like Java!
package random.folders
import random.folders.SecondFile
class Example extends SecondFile.ParentClass {}
class Example parent second_file.ParentClass {}
Of-course optionally, I'm also trying to be able to do this:
class Example extends random.folders.SecondFile.ParentClass {}
class Example parent random.folderssecond_file.ParentClass {}
It's a waste of time, but if we had two files say called 'Object', you want to be able to reference both of them.
You might also be a bit confused in the Java example, as to why there would be a class called SecondFile with a ParentClass in it.
In my language, the user only has to type
func RandomFunction: nil {}  // the filename is RandomFile
Which will be generated into Java as
class RandomFile {
        void RandomFunction {}
It's just because I want to "file-ify" the top-level class, so you can write methods at the top scope without first having to contain it in a class.
Thanks for your help Christian.
[Updated on: Tue, 04 April 2017 20:47] by Moderator
Re: Limiting cross-reference to a single file [message #1758979 is a reply to message #1758976] Tue, 04 April 2017 23:03 Go to previous messageGo to next message
Hmmm that looks like you need a mixture of importuri and importnamespace based scoping. Unfortunately I don't have the time to create an example for that but I remember so year ago the same was asked and there was a solution
i can just give you a starting tipp. if you change grammar to
ImportDeclaration:
	'use' importURI=STRING
and add this binding
	override bindIGlobalScopeProvider() {
		ImportUriGlobalScopeProvider
it works if you use imports like
use "platform:/resource/xxxxxx/random/folders/second_file.mydsl1"     // also a FQN
class ChildClass parent ParentClass {
if you adapt ImportUriResolver to turn your imports into the ones you want
then it will work for namespace imports as well.
additionally you need to adapt the nameprovider if you want to have the name "second_file.ParentClass"
public class StrangeNameProvider extends DefaultDeclarativeQualifiedNameProvider {
	QualifiedName qualifiedName(Model type) {
		return QualifiedName.create(type.eResource().getURI().trimFileExtension().lastSegment());
	override bindIQualifiedNameProvider() {
		StrangeNameProvider
[Updated on: Tue, 04 April 2017 23:44] by Moderator
Re: Limiting cross-reference to a single file [message #1758980 is a reply to message #1758979] Tue, 04 April 2017 23:36 Go to previous messageGo to next message
Yea, I thought so....
Is there a way I can fix the cross-file referencing though? So the file limits its knowledge to itself?
Re: Limiting cross-reference to a single file [message #1758981 is a reply to message #1758980] Tue, 04 April 2017 23:45 Go to previous messageGo to next message
see my update, that should be enhough to get started into the problem
Re: Limiting cross-reference to a single file [message #1758987 is a reply to message #1758981] Wed, 05 April 2017 01:23 Go to previous messageGo to next message
I'm sorry for being a pain Christian and I appreciate your help.
I don't really know the ins-and-outs of Xtext at all, and just assumed that the bindIGlobalScopeProvider() binding belongs in the DSLScopeProvider.xtend file.
If this is the case, I've done what you said but really, nothing has happened. I don't really understand any of it either. Confused
[Updated on: Wed, 05 April 2017 01:28] by Moderator
Re: Limiting cross-reference to a single file [message #1758988 is a reply to message #1758987] Wed, 05 April 2017 01:38 Go to previous messageGo to next message
how does your runtime module, your name provider, your grammar and your test model look like right now
Re: Limiting cross-reference to a single file [message #1759006 is a reply to message #1758988] Wed, 05 April 2017 04:17 Go to previous messageGo to next message
Completely bare minimum.
I have absolutely NOTHING, but the .xtext model file along with the .mwe2 and generated files, and that DSLScopeProvider file which I basically stuck the method you gave me straight into it.
Re: Limiting cross-reference to a single file [message #1759007 is a reply to message #1759006] Wed, 05 April 2017 04:32 Go to previous messageGo to next message
No, i mean:
please post your
-grammar
-MyDslRuntimeModule
-MyDslNameProvider
-Test model File
after applying my proposed changes
Re: Limiting cross-reference to a single file [message #1759012 is a reply to message #1759007] Wed, 05 April 2017 05:07 Go to previous messageGo to next message
Sorry Christian.... Confused
Grammar:
grammar org.thusix.omicron.Omicron with org.eclipse.xtext.common.Terminals
generate omicron "http://www.thusix.org/omicron/Omicron"
Model:
	types+=Type*
PackageDeclaration:
ImportDeclaration:
	'use' importURI=FQN
TypeType:
	Primitive | TypeRef
TypeRef:
	ref=[Type | FQN]
Type:
FunctionType:
		fields+=Field*
	RBRACE
ClassType:
		fields+=Field*
	RBRACE
EnumType:
		values+=ID*
	RBRACE
Field:
	VariableDeclaration
VariableDeclaration:
	type=TypeType name=ID
Primitive:
	name=('int' |
	'long' |
	'short' |
	'float' |
	'double' |
	'str' |
	'char' |
	'bool' |
	'obj' |
	'byte' |
	'nil')
FQN:
	ID ('.' ID)*
DSLRuntimeModule:
 * generated by Xtext 2.11.0
package org.thusix.omicron
 * Use this class to register components to be used at runtime / without the Equinox extension registry.
class OmicronRuntimeModule extends AbstractOmicronRuntimeModule {
DSLScopeProvider that makes reference to the NameProvider
package org.thusix.omicron.scoping
 * This class contains custom scoping description.
 * See https://www.eclipse.org/Xtext/documentation/303_runtime_concepts.html#scoping
 * on how and when to use it.
class OmicronScopeProvider extends AbstractOmicronScopeProvider {
	def bindIGlobalScopeProvider() {
		OmicronNameProvider
DSLNameProvider which is custom and not stock:
import org.eclipse.xtext.naming.DefaultDeclarativeQualifiedNameProvider
import org.eclipse.xtext.naming.QualifiedName
import org.thusix.omicron.omicron.Model
class OmicronNameProvider extends DefaultDeclarativeQualifiedNameProvider {
	def QualifiedName qualifiedName(Model type) {
Test Model File:
namespace test
use test.Testing
enum Suite {
	Spades Hearts Diamonds Clubs
func t: a {
class Deck parent C {
	int i
class RedDeck parent test.Testing.a {
Re: Limiting cross-reference to a single file [message #1759013 is a reply to message #1759012] Wed, 05 April 2017 05:14 Go to previous messageGo to next message
well you did not at all what i told you
class MyDslRuntimeModule extends AbstractMyDslRuntimeModule {
		StrangeNameProvider
ImportDeclaration:
if this work then we can continue with the next step
[Updated on: Wed, 05 April 2017 05:16] by Moderator
Re: Limiting cross-reference to a single file [message #1759021 is a reply to message #1759013] Wed, 05 April 2017 07:26 Go to previous messageGo to next message
Hey, I tried what you said before and as I previously wrote I didn't know where to put that override which you've clarified so I was able to fix it. Smile
I've done as you say and it works! Thankyou! The file will now throw an error because it can't find the specified type within itself!
The issue is though, those string imports are giving me errors. I'm assuming this is the next step Confused
index.php/fa/28978/0/
Re: Limiting cross-reference to a single file [message #1759022 is a reply to message #1759021] Wed, 05 April 2017 07:39 Go to previous messageGo to next message
No,
you are still doing different things
the modell shall look like
or
yours does not.
this works fine on my machine.
if this works on your machine as well we can do the second step
Re: Limiting cross-reference to a single file [message #1759024 is a reply to message #1759022] Wed, 05 April 2017 07:54 Go to previous messageGo to next message
Alright, here we go.
String encapsulation for import statement, normal qualified name for class.
Works beautifully. Thankyou very much.
index.php/fa/28980/0/
I'm more than happy having that error there, because I would like to use the file to reference which ParentClass I am talking about (Incase I have a local one too).
Re: Limiting cross-reference to a single file [message #1759026 is a reply to message #1759024] Wed, 05 April 2017 07:59 Go to previous messageGo to next message
=> step one is fine for you? if yes
change grammar back to:
ImportDeclaration:
	'use' importURI=FQN
use this binding
	def Class<? extends ImportUriResolver> bindImportUriResolver() {
		StrangeImportUriResolver
and implement the following class (just a stub so far that might not work in all cases)
public class StrangeImportUriResolver extends ImportUriResolver {
	@Inject
	FileExtensionProvider fileExtensionProvider;
	public String apply(EObject from) {
		// TODO make more robust / potentially work in standlone mode if needed
		// or classpath:/my/pack/xxxx.mydsl if needed as well
		String apply = super.apply(from);
		if (apply == null) {
			return apply;
		String result = "platform:/resource/" + from.eResource().getURI().segmentsList().get(1) + "/"
				+ apply.replaceAll("\\.", "/") + "." + fileExtensionProvider.getPrimaryFileExtension();
		System.out.println(result);
		return result;
Re: Limiting cross-reference to a single file [message #1759033 is a reply to message #1759026] Wed, 05 April 2017 08:14 Go to previous message
Beautiful! Thankyou VERY MUCH for your time, help and patience Christian! It works just as expected and I couldn't of asked for more! Shocked
My only question is: Is it possible to force the user to put the namespace of the class you want to use at the beginning?
Example, if we have the class "Testing.ParentClass" which the file has a namespace of "test", can we make them type "test.Testing.ParentClass"?
[Updated on: Wed, 05 April 2017 08:16] by Moderator
Previous Topic:Xtext multiple parameter to a method possibility
Next Topic:Scoping a feature call
Current Time: Thu Nov 13 10:15:46 EST 2025
Powered by FUDForum. Page generated in 0.07637 seconds
