Home » Eclipse Projects » Kura » install dp from the command line(it is possible but is there a better way?)
install dp from the command line [message #1758634] Thu, 30 March 2017 16:33 Go to next message
Hi all,
In order to install a dp from the command line I am doing the following:
1. unzip dp
2. in osgi> install file:/bundles/bundle.jar
3. in osgi> uninstall <oldbundleid>
4. in osgi> start <newbundleid>
5. copy dp into /opt/eclipse/kura/kura/packages
6. edit /opt/eclipse/kura/kura/dpa.properties
I know i could skip 1-4 and just bounce kura but that is expensive.
Is there a better way?
[Updated on: Wed, 06 June 2018 01:55] by Moderator
Re: install dp from the command line [message #1758703 is a reply to message #1758634] Fri, 31 March 2017 14:23 Go to previous message
Hi Paul,
I believe that is the only way without extending Kura. You could write a bundle that adds a custom command to the OSGi console. This is pretty easy to do [1]. This bundle could install/update/remove the DP similar to the Kura web UI (i.e. DeploymentAgentService).
[1] https://github.com/eclipse/kura/blob/develop/kura/org.eclipse.kura.core.log/src/main/java/org/eclipse/kura/core/log/LoggerCommandProvider.java
--Dave
Previous Topic:TI sensortag CC2650 kura example issue
Next Topic:de.dentrassi.kura.addons.milo in Kura RaspPi
Current Time: Wed Jul 30 17:14:33 EDT 2025
Powered by FUDForum. Page generated in 0.05052 seconds
