Home » Eclipse Projects » Kura » Java swing on Kura in OSGI(Java swing on Kura)
Re: Java swing on Kura in OSGI [message #1758452 is a reply to message #1758444] |
Tue, 28 March 2017 15:25   |
It is helpful to keep all your questions in one thread. I will use this thread to try and assist. First, I am far from a JavaFX expert and had trouble using Frames in the past, but the approach I have used is:
1. In activate, create a panel, something like:
jpanel = new JPanel();
jpanel.setSize(400, 400);
jpanel.setLayout(new GridLayout(3, 1));
headerLabel = new Label();
headerLabel.setAlignment(Label.CENTER);
statusLabel = new Label();
statusLabel.setAlignment(Label.CENTER);
statusLabel.setSize(350,100);
controlPanel = new Panel();
controlPanel.setLayout(new FlowLayout());
jpanel.add(headerLabel);
jpanel.add(controlPanel);
jpanel.add(statusLabel);
jpanel.setVisible(true);
2. Add the Frame:
controlPanel.add(new DemoFrame());
controlPanel.setVisible(true);
3. Example DemoFrame Class:
public class DemoFrame extends Canvas {
private static final long serialVersionUID = 3156965697737887068L;
private static final Logger s_logger = LoggerFactory.getLogger(DemoFrame.class);
public DemoFrame () {
setBackground (Color.GRAY);
setSize(300, 300);
public void paint(Graphics g) {
Graphics2D g2;
g2 = (Graphics2D) g;
g2.drawString ("It is a custom canvas area", 70, 70);
--Dave
Re: Java swing on Kura in OSGI [message #1758697 is a reply to message #1758573] |
Fri, 31 March 2017 13:43   |
here is the code I am using..
package org.eclipse.kura.example.hello_osgi;
import java.awt.FlowLayout;
import java.awt.GridLayout;
import java.awt.Label;
import java.awt.Panel;
import java.util.Date;
import java.util.Iterator;
import java.util.Map;
import java.util.Map.Entry;
import java.util.concurrent.Executors;
import java.util.concurrent.ScheduledExecutorService;
import java.util.concurrent.ScheduledFuture;
import java.util.concurrent.TimeUnit;
import javax.swing.JFrame;
import javax.swing.JPanel;
import org.eclipse.kura.cloud.CloudClient;
import org.eclipse.kura.cloud.CloudClientListener;
import org.eclipse.kura.cloud.CloudService;
import org.eclipse.kura.configuration.ConfigurableComponent;
import org.eclipse.kura.gpio.GPIOService;
import org.eclipse.kura.gpio.KuraGPIOPin;
import org.eclipse.kura.message.KuraPayload;
import org.osgi.service.component.ComponentContext;
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
import org.eclipse.kura.example.hello_osgi.DemoFrame;
public class HelloOsgi implements ConfigurableComponent,CloudClientListener{
//Worker thread
private final ScheduledExecutorService m_worker;
private ScheduledFuture<?> m_handle;
//GPIO service
private GPIOService m_GPIOService; //static modifier removed
//Cloud service
private CloudService m_cloudService;
private CloudClient m_cloudClient;
private Map<String, Object> m_properties;
// publishing properties
// Publishing Property Names
private static final String PUBLISH_RATE_PROP_NAME = "publish.rate";
private static final String PUBLISH_TOPIC_PROP_NAME = "publish.semanticTopic";
private static final String PUBLISH_QOS_PROP_NAME = "publish.qos";
private static final String PUBLISH_RETAIN_PROP_NAME = "publish.retain";
private static final Logger s_logger = LoggerFactory.getLogger(HelloOsgi.class);
private static final String APP_ID = "org.eclipse.kura.example.hello_osgi";
//constructor
public HelloOsgi() {
super();
this.m_worker = Executors.newSingleThreadScheduledExecutor();
* protected void activate(ComponentContext componentContext) {
s_logger.info("Bundle " + APP_ID + " has started!");
s_logger.debug(APP_ID + ": This is a debug message.");
//readLED();
protected void activate(ComponentContext componentContext, Map<String, Object> properties) {
try{
s_logger.info("Bundle " + APP_ID + " has started with config!");
this.m_properties = properties;
for (String s : properties.keySet()) {
s_logger.info("Activate - " + s + ": " + properties.get(s));
// Acquire a Cloud Application Client for this Application
s_logger.info("Getting CloudClient for {}...", APP_ID);
this.m_cloudClient = this.m_cloudService.newCloudClient(APP_ID);
this.m_cloudClient.addCloudClientListener(this);
//doUpdate();
/* Test Swing */
Runnable runnable = new Runnable() {
public void run() {
createAndShow();
catch(Exception e)
s_logger.info("activation issue...", e.toString());
s_logger.info("Activating Hello osgi... Done.");
public void updated(Map<String, Object> properties) {
// TODO Auto-generated method stub
s_logger.info("Updated properties...");
s_logger.info("Update - " + s + ": " + properties.get(s));
s_logger.info("Updated ExamplePublisher... Done.");
if(properties != null && !properties.isEmpty()) {
Iterator<Entry<String, Object>> it = properties.entrySet().iterator();
while(it.hasNext()) {
Entry<String, Object> entry = it.next();
s_logger.info("New property - " + entry.getKey() + " = " +
entry.getValue() + " of type " + entry.getValue().getClass().toString());
// try to kick off a new job
doUpdate();
protected void deactivate(ComponentContext componentContext) {
// shutting down the worker and cleaning up the properties
this.m_worker.shutdown();
// Releasing the CloudApplicationClient
s_logger.info("Releasing CloudApplicationClient for {}...", APP_ID);
this.m_cloudClient.release();
s_logger.debug("Deactivating ExamplePublisher... Done.");
s_logger.info("Bundle " + APP_ID + " has stopped!");
protected void setGPIOService(GPIOService gpioService){
this.m_GPIOService = gpioService;
protected void unsetGPIOService(GPIOService gpioService) {
this.m_GPIOService = null;
//cloud publisher service
public void setCloudService(CloudService cloudService) {
m_cloudService = cloudService;
public void unsetCloudService(CloudService cloudService) {
m_cloudService = null;
private void doUpdate() {
// cancel a current worker handle if one if active
if (this.m_handle != null) {
this.m_handle.cancel(true);
// schedule a new worker based on the properties of the service
int pubrate = (Integer) this.m_properties.get(PUBLISH_RATE_PROP_NAME);
this.m_handle = this.m_worker.scheduleAtFixedRate(new Runnable() {
// @Override
public void run() {
doPublish();
}, 0, pubrate, TimeUnit.MINUTES);
public void doPublish()
// fetch the publishing configuration from the publishing properties
String topic = (String) this.m_properties.get(PUBLISH_TOPIC_PROP_NAME);
Integer qos = (Integer) this.m_properties.get(PUBLISH_QOS_PROP_NAME);
Boolean retain = (Boolean) this.m_properties.get(PUBLISH_RETAIN_PROP_NAME);
// Allocate a new payload
KuraPayload payload = new KuraPayload();
// Timestamp the message
payload.setTimestamp(new Date());
// Add the temperature as a metric to the payload
payload.addMetric("temperature", 27.8);
// Publish the message
try {
s_logger.info("trying to Publish to Topic:", topic, payload);
m_cloudClient.publish(topic, payload,qos, retain);
s_logger.info("Published to {} message: {}", topic, payload);
catch (Exception e) {
s_logger.error("Cannot publish topic: "+topic, e);
public void onConnectionEstablished() {
public void onConnectionLost() {
public void onControlMessageArrived(String arg0, String arg1, KuraPayload arg2, int arg3, boolean arg4) {
public void onMessageArrived(String arg0, String arg1, KuraPayload arg2, int arg3, boolean arg4) {
public void onMessageConfirmed(int arg0, String arg1) {
public void onMessagePublished(int arg0, String arg1) {
/* test swing method */
static void createAndShow() {
s_logger.info("Entered createAndShow method");
JFrame frame = new JFrame("Hello World");
frame.setSize(640,480);
frame.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
frame.setVisible(true);
s_logger.info("swing code execued ffrom createAndShow method");
Re: Java swing on Kura in OSGI [message #1758724 is a reply to message #1758705] |
Sat, 01 April 2017 02:04   |
Thank you Dave, for your reply.. I did tthe invocation
SwingUtilities.invokeLater( runnable) and it also shows nothing...
then I tried SwingUtilities.invokeAndwait(runnable) ... also getting no display....
I finally change the code as suggested by you .....
import javax.swing.SwingUtilities;
//Worker thread
//GPIO service
//Cloud service
//constructor
super();
//readLED();
try{
//doUpdate();
/* Test Swing */
JPanel jpanel = new JPanel();
Label headerLabel = new Label();
Label statusLabel = new Label();
Panel controlPanel = new Panel();
catch(Exception e)
doUpdate();
public void readLED(){
try{
int counter =0; // for max number of times
//get LED pin
KuraGPIOPin led=m_GPIOService.getPinByTerminal(17);
if(!led.isOpen())
led.open();
if(led !=null)
s_logger.info("Direction " + led.getDirection());
s_logger.info("Triger " + led.getTrigger());
s_logger.info("Mode " + led.getMode());
s_logger.info("Value " + led.getValue());
led.setValue(false); // start LED as off
while(true)
s_logger.info("Trying to read & control LED as stated by Amar");
//read LED pin
if(led.getValue()==true) led.setValue(false);
Thread.sleep(2000);
if(led.getValue()==false) led.setValue(true);
// s_logger.info("");
Thread.sleep(2000);
boolean currentstate= led.getValue() ;
s_logger.info("LED state is:"+currentstate);
if(counter>=60)
break;
counter++;
}catch(Exception e)
s_logger.info("problem in reading led " + e.toString());
// @Override
public void run() {
doPublish();
try {
Not getting any clue...
Re: Java swing on Kura in OSGI [message #1758725 is a reply to message #1758724] |
Sat, 01 April 2017 02:20   |
Also I tried with a separate thread.....as in the below code ..but still no display .....
//Worker thread
//GPIO service
//Cloud service
//constructor
super();
//readLED();
try{
//doUpdate();
/* Test Swing */
SwingUtilities.invokeLater(new Runnable() {
public void run() {
catch(Exception e)
doUpdate();
try{
//get LED pin
if(!led.isOpen())
led.open();
if(led !=null)
while(true)
//read LED pin
Thread.sleep(2000);
Thread.sleep(2000);
if(counter>=60)
break;
counter++;
}catch(Exception e)
// @Override
public void run() {
doPublish();
try {
Re: Java swing on Kura in OSGI [message #1758726 is a reply to message #1758725] |
Sat, 01 April 2017 02:27   |
One pattern I am finding is that it seems Activate method is not returning ....as I never see the is line in my Kura.log file
try{
//doUpdate();
/* Test Swing */
public void run() {
catch(Exception e)
s_logger.info("Activating Hello osgi... Done."); // this line is not executing
Kura.log :
017-04-01 11:16:43,767 [Component Resolve Thread (Bundle 7)] INFO o.e.k.e.h.HelloOsgi - Activate - publish.semanticTopic: data
2017-04-01 11:16:43,768 [Component Resolve Thread (Bundle 7)] INFO o.e.k.e.h.HelloOsgi - Activate - kura.service.pid: org.eclipse.kura.example.hello_osgi.HelloOsgi
2017-04-01 11:16:43,768 [Component Resolve Thread (Bundle 7)] INFO o.e.k.e.h.HelloOsgi - Activate - param2.Salary: 15.5
2017-04-01 11:16:43,768 [Component Resolve Thread (Bundle 7)] INFO o.e.k.e.h.HelloOsgi - Activate - publish.rate: 1
2017-04-01 11:16:43,768 [Component Resolve Thread (Bundle 7)] INFO o.e.k.e.h.HelloOsgi - Activate - service.pid: org.eclipse.kura.example.hello_osgi.HelloOsgi
2017-04-01 11:16:43,769 [Component Resolve Thread (Bundle 7)] INFO o.e.k.e.h.HelloOsgi - Activate - component.id: 52
2017-04-01 11:16:43,769 [Component Resolve Thread (Bundle 7)] INFO o.e.k.e.h.HelloOsgi - Activate - param1.Name: Amarendra
2017-04-01 11:16:43,769 [Component Resolve Thread (Bundle 7)] INFO o.e.k.e.h.HelloOsgi - Activate - publish.qos: 0
2017-04-01 11:16:43,769 [Component Resolve Thread (Bundle 7)] INFO o.e.k.e.h.HelloOsgi - Activate - publish.retain: false
2017-04-01 11:16:43,770 [Component Resolve Thread (Bundle 7)] INFO o.e.k.e.h.HelloOsgi - Getting CloudClient for org.eclipse.kura.example.hello_osgi...
2017-04-01 11:16:43,886 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.DataServiceImpl - Storing message on topic :$EDC/#account-name/#client-id/MQTT/APPS, priority: 0
2017-04-01 11:16:43,892 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.DataServiceImpl - Stored message on topic :$EDC/#account-name/#client-id/MQTT/APPS, priority: 0
2017-04-01 11:16:43,897 [DataServiceImpl:Submit] INFO o.e.k.c.d.t.m.MqttDataTransport - Publishing message on topic: $EDC/retailIOT/B8:27:EB:52:3D:F6/MQTT/APPS with QoS: 0
2017-04-01 11:16:44,203 [MQTT Call: B8:27:EB:52:3D:F6] INFO o.e.k.c.c.CloudServiceImpl - Message arrived on topic: $EDC/retailIOT/B8:27:EB:52:3D:F6/MQTT/APPS
2017-04-01 11:16:44,204 [MQTT Call: B8:27:EB:52:3D:F6] INFO o.e.k.c.c.CloudServiceImpl - Ignoring feedback message from $EDC/retailIOT/B8:27:EB:52:3D:F6/MQTT/APPS
2017-04-01 11:19:26,497 [HouseKeeperTask] INFO o.e.k.c.d.s.HouseKeeperTask - HouseKeeperTask started.
2017-04-01 11:19:26,501 [HouseKeeperTask] INFO o.e.k.c.d.s.HouseKeeperTask - HouseKeeperTask: Check store...
2017-04-01 11:19:26,507 [HouseKeeperTask] INFO o.e.k.c.d.s.HouseKeeperTask - HouseKeeperTask: Delete confirmed messages...
2017-04-01 11:19:26,516 [HouseKeeperTask] INFO o.e.k.c.d.s.HouseKeeperTask - HouseKeeperTask ended.
Re: Java swing on Kura in OSGI [message #1758727 is a reply to message #1758725] |
Sat, 01 April 2017 02:28   |
try{
//doUpdate();
/* Test Swing */
public void run() {
catch(Exception e)
Kura.log :
Current Time: Thu Jul 31 03:56:33 EDT 2025
Powered by FUDForum. Page generated in 0.08807 seconds
