Re: Can't install [message #1758417 is a reply to message #1758395] |
Tue, 28 March 2017 09:47  |
So you don't seem to have proper access to the internet. Even if you (somehow) load the setup archive, you can't read any of the p2 repositories either:
[2017-03-28 20:10:49] ERROR: org.eclipse.equinox.p2.transport.ecf code=1002 Unable to read repository at http://download.eclipse.org/technology/epp/packages/neon/content.xml.
java.net.SocketException: Permission denied: connect
I'm not sure what kind of environment you're in, but it looks like a network problem. Mostly a firewall blocking the network or being behind a proxy with restricted access. Have you tried turning your firewall off (for testing)?
FUDForum. Page generated in 0.11829 seconds
