Home » Archived » Jubula » How to identify the color of a text (in Styled Text) (How to identify the color of a text (in Styled Text) )
How to identify the color of a text (in Styled Text) [message #1755895] Thu, 09 March 2017 01:26 Go to next message
i need to identify the color of an text in text editor,
example:
select * from my_table;
i want to validate the each and every word and their color as well.
Thanks in Advance....!!
Re: How to identify the color of a text (in Styled Text) [message #1756017 is a reply to message #1755895] Fri, 10 March 2017 02:23 Go to previous messageGo to next message
Hi Muthuk,
what toolkit are you using for your AUT?
Kevin
Re: How to identify the color of a text (in Styled Text) [message #1758157 is a reply to message #1756017] Fri, 24 March 2017 01:53 Go to previous messageGo to next message
RCP project tool Kit
Re: How to identify the color of a text (in Styled Text) [message #1758367 is a reply to message #1758157] Tue, 28 March 2017 03:31 Go to previous message
Hi Muthuk,
to test this you would have to write an extension for Jubula which would call the getSelectionForeground() method of StyledText and compares its return value to the expected value. To get the color of a specific part of the text you would most likely have to use one of the Ranges methods [1]. This should be fairly simple when using the Extension wizard. For more information about Jubula Extension development see [2] and [3].
Kevin
[1] http://help.eclipse.org/neon/index.jsp?topic=%2Forg.eclipse.platform.doc.isv%2Freference%2Fapi%2Forg%2Feclipse%2Fswt%2Fcustom%2FStyledText.html
[2] https://testing.bredex.de/files/content/software/documentation/developerManual/toolkitExtension/ch03.html
[3] https://testing.bredex.de/files/content/software/documentation/developerManual/extensionWizard/ch05.html
Previous Topic:Measure memory usage and/or memory leaks
Next Topic:Searching for AUT-Path-Parameter instead of AUT-Config
Current Time: Sat Jul 26 00:28:00 EDT 2025
Powered by FUDForum. Page generated in 0.05907 seconds
