Home » Eclipse Projects » Kura » Kura for Virtual Machine
Kura for Virtual Machine [message #1758155] Thu, 23 March 2017 22:13 Go to next message
Hello Everyone,
I'm just starting my experiment about eclipse kura. I installed the newest version of kura, kura 2.1.0 (raspberry stable package), on xubuntu 14.04. but i got error access
HTTP ERROR: 404
Problem accessing /kura. Reason:
ProxyServlet: /kura
Powered by Jetty://
Can someone help me to solve this problem ? i read some blog wrote that the problem because the web UI is not installed and recommended to install the web UI package of kura, but the newest version (1.4 or later) are included web UI already. So what was make this problem happen ?
Thanks.
Re: Kura for Virtual Machine [message #1758216 is a reply to message #1758155] Fri, 24 March 2017 14:19 Go to previous messageGo to next message
could you post the kura.log and kura-console.log files in /var/log?
That would help.
Matteo
Re: Kura for Virtual Machine [message #1758255 is a reply to message #1758216] Sat, 25 March 2017 22:15 Go to previous messageGo to next message
Thanks for replying Matteo, here is the kura.log
2017-03-24 08:30:23,271 [Start Level Event Dispatcher] INFO o.a.c.i.o.Activator - Camel activator starting
2017-03-24 08:30:23,393 [Start Level Event Dispatcher] INFO o.a.c.i.o.Activator - Camel activator started
2017-03-24 08:30:26,035 [Component Resolve Thread (Bundle 7)] INFO o.e.k.l.b.BluetoothServiceImpl - Activating Bluetooth Service...
2017-03-24 08:30:27,420 [Start Level Event Dispatcher] INFO o.e.j.s.Server - jetty-8.1.3.v20120522
2017-03-24 08:30:28,279 [Start Level Event Dispatcher] INFO o.e.j.s.AbstractConnector - Started SelectChannelConnector@0.0.0.0:80
2017-03-24 08:39:23,016 [System Bundle Shutdown] INFO o.e.j.s.h.ContextHandler - stopped o.e.j.s.ServletContextHandler{/,null}
2017-03-24 08:39:23,203 [System Bundle Shutdown] INFO o.a.c.i.o.Activator - Camel activator stopping
2017-03-24 08:39:23,211 [System Bundle Shutdown] INFO o.a.c.i.o.Activator - Camel activator stopped
2017-03-24 08:40:24,020 [Start Level Event Dispatcher] INFO o.a.c.i.o.Activator - Camel activator starting
2017-03-24 08:40:24,061 [Start Level Event Dispatcher] INFO o.a.c.i.o.Activator - Camel activator started
2017-03-24 08:40:25,336 [Component Resolve Thread (Bundle 7)] INFO o.e.k.l.b.BluetoothServiceImpl - Activating Bluetooth Service...
2017-03-24 08:40:26,119 [Start Level Event Dispatcher] INFO o.e.j.s.Server - jetty-8.1.3.v20120522
2017-03-24 08:40:26,493 [Start Level Event Dispatcher] INFO o.e.j.s.AbstractConnector - Started SelectChannelConnector@0.0.0.0:80
2017-03-26 08:54:16,293 [Start Level Event Dispatcher] INFO o.a.c.i.o.Activator - Camel activator starting
2017-03-26 08:54:16,348 [Start Level Event Dispatcher] INFO o.a.c.i.o.Activator - Camel activator started
2017-03-26 08:54:17,394 [Component Resolve Thread (Bundle 7)] INFO o.e.k.l.b.BluetoothServiceImpl - Activating Bluetooth Service...
2017-03-26 08:54:17,919 [Start Level Event Dispatcher] INFO o.e.j.s.Server - jetty-8.1.3.v20120522
2017-03-26 08:54:18,320 [Start Level Event Dispatcher] INFO o.e.j.s.AbstractConnector - Started SelectChannelConnector@0.0.0.0:80
And the kura-console.log is in the file i attached in this post.
Hope you can help. Thanks. Very Happy
  • Attachment: kura-console.log
    (Size: 2.02MB, Downloaded 107 times)
  • Attachment: kura.log
    (Size: 2.02KB, Downloaded 92 times)
Re: Kura for Virtual Machine [message #1758445 is a reply to message #1758255] Tue, 28 March 2017 14:26 Go to previous messageGo to next message
The errors are in kura-console.log. Kura requires a udev native library to start, which is failing to load properly. Is running Xubuntu a requirement? We only validate Kura against Raspbian (and soon Fedora) for the Raspberry Pi. Can you use one of these operating systems instead?
--Dave
Re: Kura for Virtual Machine [message #1758470 is a reply to message #1758445] Tue, 28 March 2017 22:35 Go to previous messageGo to next message
Hello Dave, Thanks for your replying,
I used xubuntu (ubuntu based OS) because in my experiment i dont use the physical device like raspberry or beaglebone. So I can't use Raspbian because it's not compatible to be installed in virtual machine. and i need help for implementing kura framework but in virtual machine. But if fedora really can be used to implement kura framework or maybe other way to simulating kura framework, i'll try to use it for my experiment. i read some people were using the kura emulator bundle to try and implementing kura framework and i still caonfused and dont know how to start to use kura emulator. because i am not find yet the tutorial for starting with kura emulator.
Thank you,
Re: Kura for Virtual Machine [message #1758514 is a reply to message #1758470] Wed, 29 March 2017 09:44 Go to previous messageGo to next message
If you want to try and use Xubuntu, it is likely just an issue in finding libudev. You can verify the library is on your system with:
find /. -iname "*libudev*"
There have been some issues around this that you can review here [1].
You can also have a look at this [2], which is a Kura emulator based on Docker.
[1] https://github.com/eclipse/kura/issues?utf8=%E2%9C%93&q=libudev
[2] https://github.com/ctron/kura-emulator
--Dave
[Updated on: Wed, 29 March 2017 10:04] by Moderator
Re: Kura for Virtual Machine [message #1758548 is a reply to message #1758514] Thu, 30 March 2017 00:07 Go to previous messageGo to next message
Thanks Dave for your replying and your help, I'll try and look for that docs.
Thank You.
Re: Kura for Virtual Machine [message #1758549 is a reply to message #1758548] Thu, 30 March 2017 01:10 Go to previous messageGo to next message
Hello Dave, I checked the existing of libudev on my system and I found this :
ubuntu1404@ubuntu1404-VirtualBox:~$ sudo find /. -iname "*libudev*"
[sudo] password for ubuntu1404:
/./lib/x86_64-linux-gnu/libudev.so.1.3.5
/./var/lib/dpkg/info/libudev1:amd64.list
/./var/lib/dpkg/info/libudev1:amd64.md5sums
/./var/lib/dpkg/info/libudev1:amd64.postinst
/./var/lib/dpkg/info/libudev1:amd64.symbols
/./var/lib/dpkg/info/libudev1:amd64.shlibs
/./var/lib/dpkg/info/libudev1:amd64.postrm
/./usr/share/doc/libudev1
is this mean that the problem was not from libudev ??
Thank You
Re: Kura for Virtual Machine [message #1758615 is a reply to message #1758549] Thu, 30 March 2017 11:18 Go to previous message
The problem is that Kura doesn't really recognize the environment it is running in. The org.eclipse.kura.linux.usb bundle, that is needed for Kura to start, loads the udev native library based on this manifest [1]. For the Raspberry Pi, it should be selecting one of the ARM based libraries. Instead, as seen in the kura-console.log, it is trying to use an x86 library:
java.lang.UnsatisfiedLinkError: /tmp/.kura/configuration/org.eclipse.osgi/bundles/62/1/.cp/lib/linux/x86_64/libEurotechLinuxUdev.so: libudev.so.0: cannot open shared object file: No such file or directory
Obviously this native library is not compatible with the libudev on your system. The only real way to correct this problem would be to build Kura with support for XUbuntu. I think if you are okay switching to Fedora, that would be the easiest path to success. The early release version of Kura for Fedora can be found here [2] with instructions on installing here [3].
[1] https://github.com/eclipse/kura/blob/KURA_2.1.0_RELEASE/kura/org.eclipse.kura.linux.usb/META-INF/MANIFEST.MF
[2] http://download.eclipse.org/kura/milestones/3.0.0/M1/?d
[3] https://github.com/eclipse/kura/tree/develop/kura/distrib/src/main/resources/fedora25
--Dave
Previous Topic:GUI swing on OSGI bundle in KURA
Next Topic:TI sensortag CC2650 kura example issue
Current Time: Thu Jul 31 03:14:53 EDT 2025
Powered by FUDForum. Page generated in 0.06681 seconds
