Home » Modeling » Epsilon » commit in EOL(commit in EOL)
commit in EOL [message #1758000] Wed, 22 March 2017 12:58 Go to next message
I am writing EOL code including nested loop with nested if statements and inside the loop i am calling some update operations to add elements to a model and i am querying the model inside the loop and each time i got error even i can see the new element in the model,i am wondering if i can query the update(new element added to the model) during the loop or i have to query the update after exiting the loop?
Can i explicitly commit the changes during the execution or is there any trick to do that??
Thanks ,
Taghreed
Re: commit in EOL [message #1758001 is a reply to message #1758000] Wed, 22 March 2017 12:59 Go to previous messageGo to next message
Hi Taghreed,
You can call <model-name>.store() anywhere in your code.
Dimitris
Re: commit in EOL [message #1758012 is a reply to message #1758001] Wed, 22 March 2017 14:15 Go to previous messageGo to next message
Hi Dimitris,
Unfortunately it didn't work Sad
I don't know why,i am adding example1Trace .store() after call addTrace operation .
Below is part of the code
else{//else part when right is not defined
	                     var LeftElementName=getName(UmlIdLeft);
	                     if (isTraceExists(LeftElementName)=false){
	                         var UmlType=getType(UmlIdLeft);
	                         "yssssssssssssss".println();
	                         if (TransferredElements.includes(UmlType)){
	                         if (UmlType<>"ControlFlow"){
	                          "no Trace for this left because no right(old)".println();
							                          var DeviceParent=getDeviceForArtifact(LeftElementName).println();//first we need to add the parent
							                          "DeviceParent".print()+DeviceParent.println();
							                           addChild(Lqn!processor,DeviceParent.name,LeftElementName);//from mapping we are able to know that device is processor and parent for artifact
					                                   addTrace(LeftElementName,UmlType,"task");
					                                   example1Trace.store();
					                                   "pleaseeeeee".print()+isTraceExists(LeftElementName).println();
				                                       }else { for (flow in UML!ControlFlow) {
							                           if (flow.name=LeftElementName){
							                              if (guardForControlFlowToPrecedence(flow)=true){
							                              "create new elemet its type = control flow".println();
							                               addSyncall(flow.source,flow.target);
							                              [b] addTrace(LeftElementName,UmlType,"synchcall");
							                               example1Trace.store();[/b]
							                              }else if(controlflowProcessingforSyncCall(flow)=true){
							                                addSyncall(flow.source,flow.target.name);
							                               addTrace(LeftElementName,UmlType,"synchcall");}else if(controlflowProcessingforASyncCall(flow)="true"){
							                               addASyncall(flow.source,flow.target);
							                               [b]addTrace(LeftElementName,UmlType,"Asynchcall");
							                               example1Trace.store();[/b]}
[Updated on: Wed, 22 March 2017 14:18] by Moderator
Re: commit in EOL [message #1758034 is a reply to message #1758012] Wed, 22 March 2017 16:34 Go to previous messageGo to next message
Hi Taghreed,
In the absence of a minimal example I can use to reproduce this, there's little I can do to help I'm afraid.
Dimitris
Re: commit in EOL [message #1758039 is a reply to message #1758034] Wed, 22 March 2017 17:15 Go to previous messageGo to next message
Ok i will send a minimal example . I am updating example1Trace. as xml file in the run configuration for the EOL so can i still use store()??
[Updated on: Wed, 22 March 2017 17:16] by Moderator
Re: commit in EOL [message #1758040 is a reply to message #1758039] Wed, 22 March 2017 17:16 Go to previous messageGo to next message
Hi Taghreed,
Yes - that shouldn't be a problem.
Dimitris
Re: commit in EOL [message #1758049 is a reply to message #1758040] Wed, 22 March 2017 23:03 Go to previous messageGo to next message
Hi Dimitris,
I have attached minimal example to produce the problem .I am trying to update example1Trace by adding new trace and then I am trying to query example1Trace model by operation isTraceExists if the trace exists or not.
I expected that isTraceExists operation returns true after using example1Trace.store();
I am using Eclipse version 1.3.201602270002.
To produce the problem please run queryETL(1).lunch and then open example1Trace so you can see that it has been updated by the addTrace operation but isTraceExists operation returns false.
Taghreed.
Re: commit in EOL [message #1758086 is a reply to message #1758049] Thu, 23 March 2017 08:00 Go to previous messageGo to next message
Hi Taghreed,
I wasn't able to run your example as-is as a metamodel is missing. When I removed the metamodel-less model from the launch configuration, and set the content of queryETL.eol to "example1Trace.store();" the program ran without errors. I am not sure I understand the nature of the problem you're encountering.
Looking at your last few posts and at the example you shared I would like to encourage you to put additional effort in (1) explaining the precise nature of the problem you are facing and (2) making sure that the examples you share are self-contained and *genuinely* minimal. From my experience most Epsilon-related problems can be demonstrated with one model/metamodel and 4-5 lines of code.
Dimitris
[Updated on: Thu, 23 March 2017 08:02] by Moderator
Re: commit in EOL [message #1758146 is a reply to message #1758086] Thu, 23 March 2017 16:49 Go to previous messageGo to next message
Hi Dimitris,
I am really sorry for sending incomplete example. I have attached more clear and complete minimal example. This example doesn't generate any errors but it represents different behaviour from what I am expecting.
I am expecting that isTraceExists(ElementName) operation to return true after updating example1Trace model by executing the operation addTrace .
To see this unexpected behaviour please run queryETL(1).lunch file ,you will see that isTraceExists(ElementName) returns false even though addTrace operation updated example1Trace model successfully and I used example1Trace.store();
I hope that I have explained the problem in a more clear way.
Taghreed
[Updated on: Thu, 23 March 2017 17:08] by Moderator
Re: commit in EOL [message #1758346 is a reply to message #1758146] Mon, 27 March 2017 16:49 Go to previous messageGo to next message
Hi Taghreed,
Looking at your attached archive, it contains an Eclipse project ("lqnmodel") and then two sibling folders ("evolving Source Model" and "TraceabilityExample"). I'm not sure what I need to do with these folders (do I need to import them as separate projects? copy them into the attached project?). Also, I can see an ETL transformation in the archive ("TraceabilityFeb3.etl"). Do I need to run it? If not, then it shouldn't be part of the archive. I'm sorry if I'm being pedantic but I'd appreciate it if you could have another go at this and attach one Eclipse project that contains *only* the files I need to reproduce the problem you're encountering.
Dimitris
Re: commit in EOL [message #1758351 is a reply to message #1758346] Mon, 27 March 2017 22:03 Go to previous messageGo to next message
Hi Dimitris,
I do really apologize for the inconvenience i made:( i do not know what is going with me .I have attached two folders (i exported them from eclipse as it is).
TraceabilityExamples folder has:
metamodels which has Lqn2umlTarce metamodel
Evolving Source Model folder has:
Example1Trace.ecore a model an instance of Lqn2umlTarce metamodel
queryETL(1).launch
queryETL.eol
To reproduce the problem :
1-run queryETL(1).launch
2- isTraceExists(ElementName) will return false even though addTrace operation updated example1Trace model successfully and I used example1Trace.store();
I hope this time my example is complete and sorry again for the inconvenience .
Taghreed
[Updated on: Mon, 27 March 2017 22:04] by Moderator
Re: commit in EOL [message #1758362 is a reply to message #1758351] Tue, 28 March 2017 02:40 Go to previous messageGo to next message
Hi Taghreed,
In line 14, you should replace
for(s in links) {
with
for(s in example1Trace!t_links.all) {
In the future, it'd be great if you could attach exported Eclipse projects which can imported directly into a new workspace as opposed to plain folders. Moreover, the TraceabilityExample folder doesn't seem to be necessary for this example (and thus should have been omitted). Finally, you appear to be querying and modifying an XMI model using the plain XML driver. Is there any particular reason why you're not treating it as a regular EMF model?
Dimitris
Re: commit in EOL [message #1758427 is a reply to message #1758362] Tue, 28 March 2017 10:53 Go to previous message
Hi Dimitris,
Thanks very much for your patience and your help,i appreciated so much.Frankly no specific reason for querying and modifying the model as XMI ,Do you recommend to query the model as EMF model??
Taghreed
Previous Topic:EVL and Papyrus
Next Topic:problem with adding element to ordered set
Current Time: Tue Jul 22 21:46:30 EDT 2025
Powered by FUDForum. Page generated in 0.08969 seconds
