Home » Modeling » TMF (Xtext) » using reserved keyword in grammar
using reserved keyword in grammar [message #1757939] Wed, 22 March 2017 02:41 Go to next message
Hi, I am having issues with my grammar whereby I need to consider keywords as valid name (due to some legacy code reason). After searching in some forums I come to conclusion that I need to use KEYWORDID where KEYWORDID contains ID rule and all possible keywords that can also be used as a name.
Example below: the third attribute: "date" is used as a name as well as a possible type.
entity SampleEntity {
	attribute user:string "User"
        attribute startDate:date "Start date"
	attribute date:string "Implementation Date"
However, when I start adding 'date' into KEYWORDID rule, xtext complains "Decision can match input such as "'date'" using multiple alternatives: 1, 2
As a result, alternative(s) 2 were disabled for that input"
Any suggestions how I can overcome this problem?
My sample grammar is as defined below:
grammar com.MyEntity with org.eclipse.xtext.common.Terminals
generate myentity "http://myentity.com/MyEntity"
/***** MAIN RULES *****/
EntityModel:
	'package' name=FullyQualifiedName
	imports+=(Import)*
	declarations+=(Declaration)*;
Declaration:
	Enum | Entity;
Import:
	'import entity' importedNamespace=FullyQualifiedName;
Enum:
	'enum' name=KEYWORDID '{'
	(enumTypes+=EnumTypes)*
EnumTypes:
	name=KEYWORDID ':' enumDescription=STRING;
Entity:
	'entity' name=KEYWORDID ('extends' superType=[Entity|FullyQualifiedName])? '{'
	(attributes+=Attribute)*
Attribute:
	'attribute' name=KEYWORDID (':' type=ArrayOrNonArrayDataType)?;
ArrayOrNonArrayDataType:
	nonArrayType=DataType | '[' arrayType=DataType ']';
DataType:
	declRef=[Declaration|FullyQualifiedName] | prim=PrimitiveType;
enum PrimitiveType:
	STRING='string' | INTEGER='int' | BOOLEAN='boolean' | DATE='date' | DATETIME='datetime' | DOUBLE='double';
/***** PREDEFINED DATATYPE AND ENUM*****/
FullyQualifiedName:
	KEYWORDID ('.' KEYWORDID)*;
terminal ID:
	('a'..'z' | 'A'..'Z' | '_') ('a'..'z' | 'A'..'Z' | '0'..'9' | '_')*;
KEYWORDID:
	ID | 'attribute' |
	'entity' |
	'enum' |
	'false' |
	'import' |
	'module' |
	'optional' |
	'true' | 'date';
[Updated on: Wed, 22 March 2017 02:46] by Moderator
Re: using reserved keyword in grammar [message #1757940 is a reply to message #1757939] Wed, 22 March 2017 02:54 Go to previous messageGo to next message
hi,
the problem is here:
DataType:
=> Date is a valid FullyQualifiedName and a valid PrimitiveType
you need to handle that e.g.
DataType:
	declRef=[Declaration|FullyQualifiedNameForDeclRef] | prim=PrimitiveType
FullyQualifiedNameForDeclRef:
	KEYWORDID_NONPRIMITIVE ('.' KEYWORDID)*
KEYWORDID_NONPRIMITIVE:
	ID | 'attribute' |
	'entity' |
	'enum' |
	'false' |
	'import' |
	'module' |
	'optional' |
	'true'
Re: using reserved keyword in grammar [message #1757941 is a reply to message #1757939] Wed, 22 March 2017 02:55 Go to previous messageGo to next message
just use the normal "ID" out-of-the-box.
To enter a keyword as ID you have to prefix it with a "^":
enum ^date
use the validation to protect from unwanted keywords
Re: using reserved keyword in grammar [message #1757942 is a reply to message #1757941] Wed, 22 March 2017 03:04 Go to previous message
Thanks a lot Christian! It works!
Previous Topic:Xtend Graph Transformation
Next Topic:Cross Reference to nested Elements
Current Time: Sun Jul 20 22:14:25 EDT 2025
Powered by FUDForum. Page generated in 0.02941 seconds
