Home » Language IDEs » ServerTools (WTP) » Create Dynamic Web Project with Java Server Faces on WIldFly server?
Create Dynamic Web Project with Java Server Faces on WIldFly server? [message #1757913] Tue, 21 March 2017 15:05 Go to next message
I can create, deploy and run a simple project with a .jsp where I combine java and html.
However, I cannot wrap my head around using simple tags like <f:view>.
Whatever I do, the taglibs
<%@ taglib ...>
are flagged with "Can not find the tag library descriptor..." errors, and subsequent use of tags yield an "Unknown tag <f:view>" error.
I have found lots of old issues with tag libraries, which could be resolved by adding the right library to the project, but nothing more recent (running eclipse neon), so I guess I am overlooking something real basic. Any help is appreciated...
Re: Create Dynamic Web Project with Java Server Faces on WIldFly server? [message #1757916 is a reply to message #1757913] Tue, 21 March 2017 15:55 Go to previous messageGo to next message
The first question is whether your page runs anyway, with the project correctly targeting and compiling against WildFly (instead of something different like the built-in "J2EE Preview"). Then, if so, it comes to why the JSF library is not being found within Eclipse. So, does the page run?
Re: Create Dynamic Web Project with Java Server Faces on WIldFly server? [message #1757918 is a reply to message #1757916] Tue, 21 March 2017 16:02 Go to previous messageGo to next message
As I mentioned, I can run my project. It runs on server, outside eclipse.
That is, the project runs without tags added, just java and html.
[Updated on: Tue, 21 March 2017 16:04] by Moderator
Re: Create Dynamic Web Project with Java Server Faces on WIldFly server? [message #1757922 is a reply to message #1757918] Tue, 21 March 2017 16:49 Go to previous messageGo to next message
The interesting part, for this question, is what happens with the tags added.
Re: Create Dynamic Web Project with Java Server Faces on WIldFly server? [message #1757924 is a reply to message #1757922] Tue, 21 March 2017 17:14 Go to previous messageGo to next message
Nitin Dahyabhai wrote on Tue, 21 March 2017 20:49
It gives the errors mentioned above, the project cannot be built.
Re: Create Dynamic Web Project with Java Server Faces on WIldFly server? [message #1757931 is a reply to message #1757924] Tue, 21 March 2017 18:22 Go to previous messageGo to next message
Are you unable to launch it regardless? Is there any configuration you're supposed to do to enable JSF on WildFly?
Re: Create Dynamic Web Project with Java Server Faces on WIldFly server? [message #1758080 is a reply to message #1757931] Thu, 23 March 2017 07:01 Go to previous messageGo to next message
Nitin Dahyabhai wrote on Tue, 21 March 2017 22:22
I cannot compile, build or deploy the .jsp file; the server is running. I don't think Wildfly needs to be tweaked to enable JSF.
I can easily reproduce the problem:
1. Create Dynamic Web Project, targetting WIldfly 10.x runtime, enable JavaServer Faces facet
2. Add .jsp file (the default template gives you a <f:view> tag
3. Open the newly created .jsp file: the taglibs are marked as error.
I would appreciate if someone out there could try this one for me to check whether it works...
Re: Create Dynamic Web Project with Java Server Faces on WIldFly server? [message #1758123 is a reply to message #1758080] Thu, 23 March 2017 13:46 Go to previous messageGo to next message
I just found out that using Glassfish instead of Wildfly gives me exactly the same errors.
I guess the problem does not depend on the application server used.
Re: Create Dynamic Web Project with Java Server Faces on WIldFly server? [message #1758124 is a reply to message #1758123] Thu, 23 March 2017 13:48 Go to previous messageGo to next message
Could someone out there running Ubuntu check whether the above works, and let me know about versions of eclipse and server?
Re: Create Dynamic Web Project with Java Server Faces on WIldFly server? [message #1758275 is a reply to message #1758124] Sun, 26 March 2017 16:13 Go to previous message
Finally got this sorted out: I did a complete reinstall of eclipse and tools, and this finally started to make sense.
Looks like eclipse got screwed up in silence.
Previous Topic:Eclipse EE Neon No Server tab in Java Perspective
Next Topic:Questions on servers?
Current Time: Fri Nov 07 02:35:53 EST 2025
Powered by FUDForum. Page generated in 0.03514 seconds
