Home » Archived » Eclipse Process Manager (Stardust) » Eclipse modeler, configuration variable escaping char remains(Issue regarding the use of simple variables in Camel application )
Eclipse modeler, configuration variable escaping char remains [message #1757904] Tue, 21 March 2017 11:23
I'm using the Eclipse modeler to model a process.
I use a Camel send/receive application attached to an activity to make an HTTP Rest get request.
Here is an extract of my camel route:
<setHeader headerName="Exchange.HTTP_PATH">
	<simple>/vinyls/${body[reference]}</simple>
</setHeader>
<to uri="http://localhost:8001" />
The camel simple variable "${body[reference]}" clashes with Stardust configuration variables. As explained on the documentation, this can be solved by escaping using the char "\" :
	<simple>/vinyls/\${body[reference]}</simple>
</setHeader>
My issue is the escaping char remains, producing a wrong URI:
http://localhost:8001:/vinyls/%5Csomething
%5C is the HTML encoded version of "\" char.
The only solution i found is editing the XPDL model using a text editor to remove the char before deploying the process. This is really annoying because it breaks the eclipse modeler validation when reload the file.
I'm pretty beginner to stardust so maybe i miss something.
Previous Topic:Documentation: multilingual/tanslations available?
Next Topic:Stardust - Weblogic and licenses
Current Time: Sun Jul 20 22:56:07 EDT 2025
Powered by FUDForum. Page generated in 0.03376 seconds
