| Re: Session timeout issues [message #1757890 is a reply to message #1757882] |
Tue, 21 March 2017 07:30   |
The session-timeout specified in the web.xml is the HTTP session timeout managed by the web container. When no resources of the application are touched for the specified time, the HTTP session is invalidated by the container.
Because the Scout UI regularly polls for asynchronous events on the server (json?poll requests), the HTTP session is touched on each poll request and would never expire. Therefore, Scout checks internally if a request is a "real" user request or just a poll request. If no user request happened for scout.max.user.idle.time, the HTTP session is invalidated by Scout.
Regarding the timeout issue:
Having a separate JVM for each application should indeed not cause any trouble related to the singleton CookieManager.
The behavior you describe sounds really strange. If the browser is closed, all session cookies and the session storage should be cleared. Are you having the same issue, when you open the browser in "incognito mode"? Are you able to debug the UI server? If yes, try setting a breakpoint at org.eclipse.scout.rt.ui.html.json.JsonRequestHelper.createSessionTimeoutResponse() to find the cause of the repeated timeout messages. Unfortunately, we don't have a lot of experience with Websphere WAS, but we did not hear about such an issue yet. Maybe, there is another network component involved that caches user cookies?
Beat
FUDForum. Page generated in 0.06162 seconds
