Home » Eclipse Projects » JFace » SWTException: Invalid thread access when binding in non-UI thread
SWTException: Invalid thread access when binding in non-UI thread [message #12141] Mon, 08 June 2009 13:53 Go to next message
I'm binding two observables - SWT Text to a WritableValue. They are in
different realms and I'm doing the binidng in a non-UI thread.
DataBindingContext#bindValue throws and SWTException because it tries to add
a listener to a widget without executing the code in the display realm:
org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:3884)
at org.eclipse.swt.SWT.error(SWT.java:3799)
at org.eclipse.swt.SWT.error(SWT.java:3770)
at org.eclipse.swt.widgets.Widget.error(Widget.java:463)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:355)
at org.eclipse.swt.widgets.Widget.addListener(Widget.java:181)
at
org.eclipse.jface.internal.databinding.swt.SWTVetoableValueD ecorator.firstListenerAdded(SWTVetoableValueDecorator.java:6 9)
at
org.eclipse.core.databinding.observable.ChangeManager.addLis tener(ChangeManager.java:70)
at
org.eclipse.core.databinding.observable.value.DecoratingObse rvableValue.addValueChangeListener(DecoratingObservableValue .java:44)
at org.eclipse.core.databinding.ValueBinding.<init>(ValueBinding.java:73)
at
org.eclipse.core.databinding.DataBindingContext.bindValue(Da taBindingContext.java:155)
at
org.eclipse.core.databinding.DataBindingContext.bindValue(Da taBindingContext.java:121)
Shouldn't DataBindingContext respect the Realm for adding listeners?
-Will
Re: SWTException: Invalid thread access when binding in non-UI thread [message #14098 is a reply to message #12141] Wed, 10 June 2009 12:06 Go to previous messageGo to next message
Hi Will,
I think you are right, this looks like a bug. Can you please file one in
Bugzilla, against Eclipse/Platform/UI? Thanks!
Boris
"Will Horn" <will.horn@gmail.com> wrote in message
news:h0jj7l$au7$1@build.eclipse.org...
> add a listener to a widget without executing the code in the display
> realm:
> at
> at
> at
> at
> at
> -Will
Re: SWTException: Invalid thread access when binding in non-UI thread [message #17564 is a reply to message #14098] Fri, 26 June 2009 18:02 Go to previous message
"Boris Bokowski" <Boris_Bokowski@ca.ibm.com> wrote in message
news:h0ollk$fp4$1@build.eclipse.org...
Apologies for not following up sooner. Bug filed
(http://bugs.eclipse.org/281723) with testcase attached.
Will
Previous Topic:DataBindingContext for TableViewer in ViewPart
Next Topic:JFace Modeless Dialog
Current Time: Tue Sep 16 00:29:08 EDT 2025
Powered by FUDForum. Page generated in 0.02760 seconds
