Home » Modeling » TMF (Xtext) » [Xtext 2.11] Xcore(How to setup new MWE to use Xcore as imported model)
[Xtext 2.11] Xcore [message #1756322] Wed, 15 March 2017 07:29 Go to next message
Hello everyone
I've setup a Xtext project with an imported Ecore model. After experimenting with Xcore I've decided that I can edit my Ecore model much quicker using Xcore so I would like to tell my MWE to load my Xcore definition rather than the manually generated Ecore/Genmodel-files.
There is a Blog from Lorenzo Bettini which switches to Xcore but unfortunately his Blog uses the old MWE setup (pre Xtext 2.9).
Right this, this is what I have
Workflow {
	bean = StandaloneSetup {
		scanClassPath = true
        platformUri = "${runtimeProject}/.."
        registerEcoreFile = "platform:/resource/org.eclipse.xtext.xbase/model/Xbase.ecore"
        registerGenModelFile = "platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel"
        registerEcoreFile = "platform:/resource/org.eclipse.emf.ecore/model/Ecore.ecore"
        registerGenModelFile = "platform:/resource/org.eclipse.emf.ecore/model/Ecore.genmodel"
    	// switch to xcore
//        loadedResource = "platform:/resource/org.eclipse.emf.ecore.xcore.lib/model/XcoreLang.xcore"
//        loadedResource = "platform:/resource/${projectName}/model/Helloxcore.xcore"
        // remove when xcore
        registerGenModelFile = "platform:/resource/${runtimeProject}/model/edos.genmodel"
        registerEcoreFile = "platform:/resource/${runtimeProject}/model/edos.ecore"
...standard stuff...
loadedResource is not available anymore in the StandaloneSetup, so I've tried using the referencedResource within StandardLanguage
		language = StandardLanguage {
			name = "removedForForum"
			fileExtensions = "${file.extension}"
			referencedResource = "platform:/resource/org.eclipse.emf.ecore.xcore.lib/model/XcoreLang.xcore"
			referencedResource = "platform:/resource/${runtimeProject}/model/edos.xcore"
This doesnt work with
Caused by: org.xml.sax.SAXParseExceptionpublicId: platform:/resource/org.eclipse.emf.ecore.xcore.lib/model/XcoreLang.xcore; systemId: platform:/resource/org.eclipse.emf.ecore.xcore.lib/model/XcoreLang.xcore; lineNumber: 1; columnNumber: 1; Content ist nicht zulässig in Prolog.
	at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.createSAXParseException(ErrorHandlerWrapper.java:203)
	at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.fatalError(ErrorHandlerWrapper.java:177)
	at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:400)
	at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:327)
	at com.sun.org.apache.xerces.internal.impl.XMLScanner.reportFatalError(XMLScanner.java:1437)
	at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(XMLDocumentScannerImpl.java:999)
	at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:606)
	at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:510)
	at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:848)
	at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:777)
	at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:141)
	at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1213)
	at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:643)
	at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(SAXParserImpl.java:327)
	at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
	at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:261)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1518)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1297)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
So the question is: how can I register the Xcore-artifacts and my Xcore-definition with the new MWE configuration for Xtext 2.11?
[Updated on: Wed, 15 March 2017 07:31] by Moderator
Re: [Xtext 2.11] Xcore [message #1756323 is a reply to message #1756322] Wed, 15 March 2017 07:33 Go to previous messageGo to next message
I have written a blog about this https://blogs.itemis.com/en/using-xtext-with-xcore-and-gradle
Re: [Xtext 2.11] Xcore [message #1756325 is a reply to message #1756322] Wed, 15 March 2017 07:39 Go to previous messageGo to next message
did you add org.eclipse.emf.ecore.xcore to the deps of yourdsl?
i assume you can leave out referencedResource = "platform:/resource/org.eclipse.emf.ecore.xcore.lib/model/XcoreLang.xcore"
Re: [Xtext 2.11] Xcore [message #1756344 is a reply to message #1756325] Wed, 15 March 2017 11:55 Go to previous message
To both of you: many thanks Smile
Christians answer solved my problem with the xcore-reference. I only had the xcore.lib as dependency.
I am not yet done with Karstens blog but its very impressive...exactly what I need.
Previous Topic:ID and a more relaxed version living together
Next Topic:Content assist and unordered groups
Current Time: Fri Jul 25 19:56:44 EDT 2025
Powered by FUDForum. Page generated in 0.05126 seconds
