Home » Modeling » TMF (Xtext) » 2 OutputConfiguration's on Idea with Error(Error during auto build.: A slot with name 'SRC_GEN_ONCE' has not been configured.)
2 OutputConfiguration's on Idea with Error [message #1756002] Thu, 09 March 2017 16:20 Go to next message
I've configured a second OutputConfiguration in my Eclipse XText-Project with Idea-Plugin. In Eclipse it works as expected. But if i start Intellij the Exception
is thrown:
This is the Provider-Class:
class CustomOutputConfigurationProvider  extends OutputConfigurationProvider {
    public static final String GEN_ONCE_OUTPUT = "SRC_GEN_ONCE";
    override getOutputConfigurations() {
        val defaultOutput = new OutputConfiguration(IFileSystemAccess.DEFAULT_OUTPUT);
        defaultOutput.setDescription("Output Folder") ;
        defaultOutput.setOutputDirectory("./src-gen");
        defaultOutput.setOverrideExistingResources(true);
        defaultOutput.setCreateOutputDirectory(true);
        defaultOutput.setCleanUpDerivedResources(true);
        defaultOutput.setSetDerivedProperty(true);
        val readonlyOutput = new OutputConfiguration(GEN_ONCE_OUTPUT);
        readonlyOutput.setDescription("Read-only Output Folder");
        readonlyOutput.setOutputDirectory("./src-once");
        readonlyOutput.setOverrideExistingResources(false);
        readonlyOutput.setCreateOutputDirectory(true);
        readonlyOutput.setCleanUpDerivedResources(false);
        readonlyOutput.setSetDerivedProperty(false);
        return newHashSet(defaultOutput, readonlyOutput);
it ist bind in RuntimeModule and UiModule:
def Class<? extends IOutputConfigurationProvider> bindIOutputConfigurationProvider() {
        return CustomOutputConfigurationProvider
I'm new on XText in this version. I've worked with older version which has outlet's in mwe and no plugin.
Thanks for any ideas
Hartmut
Version:
Eclipse: Neon
IntelliJ: 163.13906.18
XText: 2.10.0
Re: 2 OutputConfiguration's on Idea with Error [message #1756093 is a reply to message #1756002] Fri, 10 March 2017 16:22 Go to previous messageGo to next message
DefaultIdeaModule binds a IContextualOutputConfigurationProvider (IdeaOutputConfigurationProvider)
you should have a look what org.eclipse.xtext.idea.build.IdeaOutputConfigurationProvider.getOutputConfigurations(Module) dos
=> i assue you need to subclass / customize this one in MyDslIdeaModule
Re: 2 OutputConfiguration's on Idea with Error [message #1756196 is a reply to message #1756093] Mon, 13 March 2017 14:26 Go to previous messageGo to next message
Hi Christian,
I've tried this (Code shows only a simple way, this should work for the first check), but if i set the readonlyOutput.setOverrideExistingResources(...) to false, no files in src-once will created. If i set both readOnly and default to override, the src-once-dir is filled as expected. But will overwriten on every change
class CustomContextualOutputConfigurationProvider extends IdeaOutputConfigurationProvider {
    def Set<OutputConfiguration> getOutConf() {
        val defaultOutputLoc = new OutputConfiguration(IFileSystemAccess.DEFAULT_OUTPUT);
        defaultOutputLoc.setDescription("Gen. Output Folder") ;
        defaultOutputLoc.setOutputDirectory("./src-gen");
        defaultOutputLoc.setOverrideExistingResources(true);
        defaultOutputLoc.setCreateOutputDirectory(true);
        defaultOutputLoc.setCleanUpDerivedResources(false);
        defaultOutputLoc.setSetDerivedProperty(false);
        return newHashSet(defaultOutputLoc,readonlyOutput)
    override Set<OutputConfiguration> getOutputConfigurations( Module module ){
       return getOutConf()
    override Set<OutputConfiguration> getOutputConfigurations( Resource context) {
       return getOutConf()
    override Set<OutputConfiguration> getOutputConfigurations(ResourceSet context)  {
        return getOutConf()
Any further Ideas?
Hartmut
Re: 2 OutputConfiguration's on Idea with Error [message #1756198 is a reply to message #1756196] Mon, 13 March 2017 14:50 Go to previous messageGo to next message
Sorry I have no idea
Did you do some debugging?
Re: 2 OutputConfiguration's on Idea with Error [message #1756201 is a reply to message #1756198] Mon, 13 March 2017 15:10 Go to previous message
I did the same in eclipse and everything is working well. I thing i'll use eclipse for first time.
Thx for your help!
Previous Topic:Method not found in enclosing type
Next Topic:XText grammar with lookbehind
Current Time: Sun Jul 20 23:16:53 EDT 2025
Powered by FUDForum. Page generated in 0.63272 seconds
