Home » Newcomers » Newcomers » Number problem in editing(Typing in numbers does not work)
Number problem in editing [message #1756156] Mon, 13 March 2017 05:24
Hello. Whenever I need to scope a job, and I press on any number, 1, 2, 3, 4, et cetera, it automatically jumps to a different command each time, like a hyperkey command, and the numbers do not insert into the text. So I need to copy the number and paste it into the text, which is not a good solution.
Please help! Thank you!
Previous Topic:openOCD + GDB debugging with Eclipse Mars
Next Topic:IBM Mobilefirst Test Workbench 8.7 not able install in eclipse MARS2 - 4.5.2
Current Time: Sun Jul 20 23:46:54 EDT 2025
Powered by FUDForum. Page generated in 0.09770 seconds
