Home » Modeling » TMF (Xtext) » Input with multiple alternatives
Input with multiple alternatives [message #1755945] Thu, 09 March 2017 08:16 Go to next message
Hello guys.
I have the following problem in my grammar:
This rule overlaps the terminal rule ID, native from Xtext.
terminal FREESTRING:  (('\\')?('a'..'z'|'A'..'Z'|'0'..'9'|','))*;
As a result, my log shows:
Decision can match input such as "RULE_FREESTRING" using multiple alternatives: 1, 2
And now I need to use the ID rule in another rules, so then, the parser can't recognize the input as a ID, as follows:
Env: 'ENV' name=ID ':' value=NL '.';
I've tried to use syntatic predicates, but it does not work:
Env: ('ENV' => name=ID) ':' value=NL '.';
How can I solve this problem?
Thanks in advance!
[Updated on: Thu, 09 March 2017 12:39] by Moderator
Re: Input with multiple alternatives [message #1755947 is a reply to message #1755945] Thu, 09 March 2017 08:19 Go to previous messageGo to next message
you might have a look at the concepts of
- terminal fragments
- datatype rules
- validation
can you please share a minimal complete grammar + sample model
[Updated on: Thu, 09 March 2017 08:48] by Moderator
Re: Input with multiple alternatives [message #1755975 is a reply to message #1755947] Thu, 09 March 2017 12:49 Go to previous messageGo to next message
Hi, I'll share my entire grammar:
And a sample is:
The system SHALL save all the data;
ENV size: 16Gb.
ENV maxFiles: 32.
So, the problem is in the declaration of these "ENV" variables, the name of these variables is not recognized as ID, and I think that this occurs becose of the rule FREESTRING, wich overlaps the ID rule.
Thanks.
[Updated on: Thu, 09 March 2017 16:43] by Moderator
Re: Input with multiple alternatives [message #1755982 is a reply to message #1755975] Thu, 09 March 2017 14:10 Go to previous messageGo to next message
well if i write minimal i do that with a reason Sad
and what you try to do is the very hardest thing to do in xtext.
and there a lot very strange concepts in your grammar.
what separates a String primitive from the next one?
Requirements:
	requirements+=Requirement+;
Requirement:
	(root+=Sentence)+ ';' ;
Sentence:
	(root+=StringValue)+ & '.'?;
NL hidden(WS): FREESTRING ( FREESTRING)*;
StringValue:value=NL;
this problem is there even if you generalize FREESTRING and ID to a common superrule e.g. by loosenin ID
for me that looks very hard to solve without a custom lexer that is more intelligent and knows what is a FREESTRING and what is a ID
Re: Input with multiple alternatives [message #1755987 is a reply to message #1755982] Thu, 09 March 2017 14:33 Go to previous messageGo to next message
=> I'd first use ID only and solve the grammar problem
And then have a look at the Lexing problem
Re: Input with multiple alternatives [message #1755993 is a reply to message #1755987] Thu, 09 March 2017 15:17 Go to previous messageGo to next message
Hi, thanks for answer.
Yes, it's a very strange grammar, and I'm just implementing it, I did not created this language. All of this freedom in this grammar has complicated my work many times. Answering your question, what separates a primitive String from the next one is some key word (like SHALL), just it, so I have parts in Natural Language inside of this language (Relax Language).
Is a strange concept, but the language is in this way. And this is the way how I could get do it, I don't know if is the better one.
So, in this case, predicates will not work?
Re: Input with multiple alternatives [message #1755994 is a reply to message #1755993] Thu, 09 March 2017 15:19 Go to previous messageGo to next message
No I mean
Bla bla bla
One sentence or three sentences
Re: Input with multiple alternatives [message #1755995 is a reply to message #1755994] Thu, 09 March 2017 15:29 Go to previous messageGo to next message
Bla bla bla will be trated as one sentence.
Re: Input with multiple alternatives [message #1755996 is a reply to message #1755995] Thu, 09 March 2017 15:31 Go to previous messageGo to next message
So what separates two sentences?
Re: Input with multiple alternatives [message #1755998 is a reply to message #1755996] Thu, 09 March 2017 15:53 Go to previous messageGo to next message
The dot charactere "."
Sentence:
	(root+=General)+ & '.'?;
Re: Input with multiple alternatives [message #1755999 is a reply to message #1755998] Thu, 09 March 2017 15:54 Go to previous messageGo to next message
Why the &
Re: Input with multiple alternatives [message #1756000 is a reply to message #1755999] Thu, 09 March 2017 15:55 Go to previous messageGo to next message
And why is the dot optional
Re: Input with multiple alternatives [message #1756001 is a reply to message #1756000] Thu, 09 March 2017 16:10 Go to previous messageGo to next message
The & charactere was added, because without it, an error occurs:
5962 [main] ERROR mf.mwe2.launch.runtime.Mwe2Launcher - Problems running workflow br.edu.unipampa.lesa.relaxEditor.GenerateRelax:
[ERROR]: GeneratorException: (Element: -UNKNOWN-; Reported by: XtextGenerator)
Caused by: java.io.FileNotFoundException: /home/paulo/workspaces/dsl/br.edu.unipampa.lesa.relaxEditor/../br.edu.unipampa.lesa.relaxEditor/src-gen/br/edu/unipampa/lesa/relaxEditor/parser/antlr/internal/InternalRelaxLexer.java (Arquivo ou diretório não encontrado)
I do not know why it happend.
And dot is optional, because one requirement may contain just one sentence.
Re: Input with multiple alternatives [message #1756003 is a reply to message #1756001] Thu, 09 March 2017 16:27 Go to previous messageGo to next message
how should that be parseable?
after the Primitive there must be an until ?
Requirements:
	(requirements+=Requirement ';')+;
	Properties:
	property=Env|Mon|Dep|Rel
Env: ('ENV' => name=FREESTRING) ':' value=NL '.';
Mon: ('MON' => name=FREESTRING) ':' value=NL '.';
Rel: 'REL:' mon=[Mon]'-'env=[Env] '.';
Dep: 'DEP:' NL '.';
Requirement:
	(root+=General ('.' root+=General)* '.'?)  (properties+=Properties)*;
//declaramos tipos ainda nao existentes
terminal BOOLEAN returns ecore::EBoolean:'true'|'false';
//a primeira parte eh o escape
//Natural Language, trechos que serao em LN
//Essa eh a regra mae da gramatica, ja tratando a recursividade a esquerda
General:
	rest = Rest =>({UntilOperator.left=current}('UNTIL'|'until') right=General)*;
//aqui se encontram as demais regras da gramatica
Rest:
	rule = Primitive|ShallOperator|MayOperator|EventuallyOperator|BeforeOperator|AfterOperator|InOperator|AsCloseOperator|AsOperator
// tipos primitivos, como boleanos (previstos na gramatica original) e os trechos em LN
Primitive:
	BooleanValue | StringValue
//novamente os operadores primitivos
BooleanValue:value=BOOLEAN;
//aqui sao tratados todos os operandos (exceto o UNTIL)
ShallOperator:
	('SHALL'|'shall') elements=General;
MayOperator:
	("MAY"|'may') action1=General ('OR' 'MAY'|'or' 'may') action2=General;
EventuallyOperator:
	('EVENTUALLY'|'eventually') element=General;
BeforeOperator:
	('BEFORE'|'before') event=NL;// other=General;
AfterOperator:
	('AFTER'|'after') event=NL;// other=General;
InOperator:
	('IN'|'in') t=NL; //other=General;
//Frquencia ou Quantidade f or q
AsCloseOperator:
	('AS' 'CLOSE' 'AS' 'POSSIBLE' 'TO'|'as' 'close' 'as' 'possible' 'to') ForQ=NL //other=General
//quebramos todos os operadores AS
AsOperator:
	AsEarlyOperator|AsLateOperator|AsManyOperator|AsFewOperator;
AsEarlyOperator:
	('AS' 'EARLY' 'AS' 'POSSIBLE'|'as' 'early' 'as' 'possible') value=General;
AsLateOperator:
	('AS' 'LATE' 'AS' 'POSSIBLE'|'as' 'late' 'as' 'possible') value=General;
AsManyOperator:
	('AS' 'MANY'|'as' 'many') (element=NL)? ('AS' 'POSSIBLE'|'as' 'possible') value=General;
AsFewOperator:
	('AS' 'FEW'|'as' 'few') (element=NL)? ('AS' 'POSSIBLE'|'as' 'possible') value=General;
Re: Input with multiple alternatives [message #1756004 is a reply to message #1756003] Thu, 09 March 2017 16:29 Go to previous messageGo to next message
Which again. The question
What goes in which sentence
Re: Input with multiple alternatives [message #1756005 is a reply to message #1756004] Thu, 09 March 2017 16:40 Go to previous messageGo to next message
Ok, Christian thanks for your time, this is a strange grammar, and I really don't know how to implement all os these strange things in Xtext.
If you want to see the original grammar, here is https://www.eclipse.org/forums/index.php?t=getfile&id=27544&
Thanks anyway.
Re: Input with multiple alternatives [message #1756006 is a reply to message #1756005] Thu, 09 March 2017 17:12 Go to previous messageGo to next message
thus this original grammar have a name?
maybe you can try something like this
Requirements:
(requirements+=Requirement ';')+ (properties+=Properties)*;
Properties:
Dep: 'DEP:' x=NL '.';
Requirement:
(root+=General ('.' root+=General)* '.'?) ;
NL hidden(WS): FREESTRING+;
General:
rest = Rest =>({UntilOperator.left=current}('UNTIL'|'until') right=Rest)*;
Rest:
(=>primitives+=Primitive* (shall=ShallOperator|may=MayOperator)?)
Primitive:
StringValue:value=FREESTRING;
(('\\')? ('a'..'z' | 'A'..'Z' | '0'..'9' | ','))*;
ShallOperator:
=>('SHALL'|'shall') elements=General;
MayOperator:
=>("MAY"|'may') action1=General ('OR' 'MAY'|'or' 'may') action2=General;
Re: Input with multiple alternatives [message #1756007 is a reply to message #1756006] Thu, 09 March 2017 17:22 Go to previous message
Thanks, I'll try it.
This grammar defines the Relax Language, wich is a language for requirements specification for Self-Adaptive Systems, so the grammars and all of this, is not my domain area. It is a new language, without tool supporting, the authors just have defined the grammar and semantics. It is an academic work yet.
[Updated on: Thu, 09 March 2017 17:44] by Moderator
Previous Topic:Generate a final product for my DSL
Next Topic:Overloaded method determination
Current Time: Sun Aug 31 12:25:43 EDT 2025
Powered by FUDForum. Page generated in 0.47138 seconds
