Home » Modeling » TMF (Xtext) » Xtext formatting language(I can not add a blank line in my algorithms when formatting.)
Xtext formatting language [message #1755432] Fri, 03 March 2017 05:43 Go to next message
In the main plugin of my Algorithmic DSL I added an om.infoly.eclipse.textxt.algo.formatting2 package using API version 2.8.
This works fine except that when I want to add a white line between my Eclipse modules display me errors by telling me:
module.prepend[newLine] => Ok but no white line
module.prepend[newLines=2] => Conflicting values for 'newLineMin': '1' and '2'.
The whole code being long I give only one example:
def dispatch void format(Module module, extension IFormattableDocument document) {
// TODO: format HiddenRegions around keywords, attributes, cross references, etc.
// module.prepend[newLines=2]
switch (module) {
ModuleFunction : {
module.module.format
module.typeReturn.format;
module.last.format
ModuleProcedure : {
module.name.format;
module.parameters.format;
module.constantes.format;
module.variables.format;
interior( // Paramètres
module.regionFor.keyword("(").prepend[noSpace].append[oneSpace],
module.regionFor.keyword(")").prepend[oneSpace].append[oneSpace] ,
[oneSpace]
module.regionFor.keyword(":").surround[oneSpace]
interior( // Body
module.regionFor.keyword("Début").surround[newLine],
module.regionFor.keyword("Fin").surround[newLine],
[indent]
for (Statement statement : module.statements ) {
statement.format
Re: Xtext formatting language [message #1755437 is a reply to message #1755432] Fri, 03 March 2017 05:56 Go to previous messageGo to next message
can you share a minimal grammar and sample model as well?
Re: Xtext formatting language [message #1755509 is a reply to message #1755437] Sat, 04 March 2017 03:26 Go to previous messageGo to next message
You will find enclosed the complete project (but I have to remove separate packages because of the maximum size of the zip).
Thank you for telling me what you think.
Yves LEDUC
Re: Xtext formatting language [message #1755511 is a reply to message #1755509] Sat, 04 March 2017 03:52 Go to previous messageGo to next message
the conflict can be resolved
module.regionFor.keyword("Fin").prepend[newLine].append[newLines = 2],
Re: Xtext formatting language [message #1755514 is a reply to message #1755511] Sat, 04 March 2017 05:11 Go to previous messageGo to next message
Thanks it is OK
Re: Xtext formatting language [message #1755515 is a reply to message #1755511] Sat, 04 March 2017 05:18 Go to previous messageGo to next message
Displays a blank line as well as error messages in the Console view (see attached document).
  • Attachment: Console.TXT
    (Size: 66.53KB, Downloaded 166 times)
Re: Xtext formatting language [message #1755518 is a reply to message #1755515] Sat, 04 March 2017 05:27 Go to previous messageGo to next message
sure this is not yet another place of the same/similar problem? here is the model i test with
Programme x( ) : Booléen
Début
	Retourne FAUX
Fin
Début
	Retourne FAUX
Fin
Re: Xtext formatting language [message #1755864 is a reply to message #1755518] Wed, 08 March 2017 12:10 Go to previous messageGo to next message
Thank you
Now it is the formatting of the Constants that causes me a problem with the comma ',' which I want to format like this "," when it is like this for example ",". Here is the grammar element:
ConstsDecls: ('Constante:' | 'Const:') constantes=ConstDecls;
ConstDecls: consts+=ConstsDecl+; // Constantes de différents types
ConstsDecl: type=Type ':' ctes += ConstDecl (',' ctes += ConstDecl )* ';'? ; // Constantes d'un même type
ConstDecl: name=ConstName exts=ExtsName? init=DataInit ; // Constante identificateur et initialisation
ConstName: name=ValidID ;
With this code only the first comma is formatted and not the next.
def dispatch void format(ConstDecls constDecls, extension IFormattableDocument document) {
for (constsDecl : constDecls.consts ) { // Pour tous les types de Constante
var regpv = constsDecl.regionFor.keyword(";")
regpv.prepend[noSpace].append[oneSpace]
if ( constsDecl == constDecls.consts.last ) {
if (regpv != null ) // Si ';' fin dernière ligne on supprime
document.addReplacer(new InsertSemi(regpv, " "))
constsDecl.append[newLines = 2] // 2 si c'est la dernière
else {
if ( constsDecl.regionFor.keyword(";") == null ) // Pas de ; => Passage à la ligne
constsDecl.append[newLine] // 1 pour les autres
constsDecl.format
def dispatch void format(ConstsDecl constsDecl, extension IFormattableDocument document) {
var regdp = constsDecl.regionFor.keyword(":")
if ( constsDecl.regionFor.keyword(";") != null )
regdp.prepend[oneSpace].append[oneSpace]
else
regdp.prepend[space = "\t"].append[oneSpace]
var regvir = constsDecl.regionFor.keyword(",")
regvir.prepend[noSpace].append[oneSpace]
for (constDecl : constsDecl.ctes ) { // Pour toutes les constantes d'un même type
constDecl.format
def dispatch void format(ConstDecl constDecl, extension IFormattableDocument document) {
constDecl.init.format
def dispatch void format(DataInit dataInit, extension IFormattableDocument document) {
dataInit.regionFor.keyword("<-").surround[oneSpace]
Constante:Chaine:TITRE<-"Test Algorithme",INVITE1<-"Entrez trois nombres réels : ",INVITE2<-"Entrez un entier relatif : " ,RESULT1<-"Le résultat de rdt est : " ,RESULT2<-"La valeur absolue est : " Réel:PI<-3.14159; Entier: XXX<-100,YYY<-200 ;
For now it gives:
Constante:
Chaine : TITRE <- "Test Algorithme", INVITE1 <- "Entrez trois nombres réels : ",INVITE2 <- "Entrez un entier relatif : " ,RESULT1 <- "Le résultat de rdt est : " ,RESULT2 <- "La valeur absolue est : "
Réel : PI <- 3.14159; Entier : XXX <- 100, YYY <- 200
Can you tell me how to format all commas.
Re: Xtext formatting language [message #1755865 is a reply to message #1755518] Wed, 08 March 2017 12:10 Go to previous messageGo to next message
Thank you
else {
constsDecl.format
else
constDecl.format
For now it gives:
Constante:
Re: Xtext formatting language [message #1755872 is a reply to message #1755865] Wed, 08 March 2017 13:32 Go to previous messageGo to next message
am not sure if i get your problem / question since it seems trivial
		obj.regionFor.keywords(",").forEach[
Re: Xtext formatting language [message #1755901 is a reply to message #1755872] Thu, 09 March 2017 03:12 Go to previous message
Sorry the answer clogged my eyes.
else
constsDecl.regionFor.keywords(",").forEach[
constDecl | constDecl.prepend[noSpace].append[oneSpace] constDecl.format
it is OK :
Constante:
Chaine : TITRE<-"Test Algorithme", INVITE1<-"Entrez trois nombres réels : ", INVITE2<-"Entrez un entier relatif : ", RESULT1<-"Le résultat de rdt est : ", RESULT2<-"La valeur absolue est : "
Réel : PI<-3.14159
Entier : XXX<-100, YYY<-200
Sometimes it is easy to find the answer to a complex question and the answer to a simple question does not come right away.
Thanks for this trivial response
Yves LEDUC
Previous Topic:Two DSL, single project, Activator&injector issues
Next Topic:Generate a final product for my DSL
Current Time: Sat Aug 30 13:43:54 EDT 2025
Powered by FUDForum. Page generated in 0.05238 seconds
