Home » Eclipse Projects » Model Driven Health Tools » CCDA 2.1 Validation(How to get vocabulary errors as in Edge testing tool for ONC 2015)
CCDA 2.1 Validation [message #1755887] Wed, 08 March 2017 19:40 Go to next message
Is there a way to get vocabulary errors similar to Edge testing tool for ONC 2015. (https://ttpedge.sitenv.org/ttp/#/validators)
We use the following code to get general errors and warnings (C-CDA IG), but i was not sure how to get vocabulary errors and warnings. (C-CDA VOCAB).
ValidationResult result = new ValidationResult();
ClinicalDocument ccdDocument = CDAUtil.loadAs(new FileInputStream("C:\\ONE_03082017_CCDA.XML"), ConsolPackage.eINSTANCE.getContinuityOfCareDocument2(), result);
for (Diagnostic diagnostic : result.getWarningDiagnostics()) {
System.out.println(diagnostic.getMessage());
CDAUtil.validate(ccdDocument, new BasicValidationHandler() {
public void handleError(Diagnostic diagnostic) {
System.out.println("ERROR: " + diagnostic.getMessage());
public void handleWarning(Diagnostic diagnostic) {
System.out.println("WARNING: " + diagnostic.getMessage());
Could you help us regarding the usage of vocabulary errors in MDHT library.
Thank you
Re: CCDA 2.1 Validation [message #1755962 is a reply to message #1755887] Thu, 09 March 2017 10:20 Go to previous messageGo to next message
This is the ONC SITE project that handles both vocabulary validation and reference validation (used in for non-MDHT results in TTP (ETT/TTT) and sitenv) via varying SITE dependencies (found here https://github.com/siteadmin) that you are refering to:
https://github.com/siteadmin/referenceccdavalidator
If you want to integrate those you could use the referenceccdavalidator which relies on MDHT for the IG-based results. Or, you could use MDHT and the non-MDHT referenceccdavalidator dependencies to create your own tool.
If you are having issues getting the same IG-based (MDHT) results as SITE or TTP then I can help you with your source.
Dan
Re: CCDA 2.1 Validation [message #1771462 is a reply to message #1755962] Fri, 25 August 2017 05:49 Go to previous message
Hi Dan,
Where did you get the vocabulary artifacts and scenario files from, mentioned in readme.txt for vocabulary and content validations respectively
Previous Topic:Mapping additional Ethnic Group codes
Next Topic:Error while creating a new CDA model
Current Time: Sun Jul 20 16:44:03 EDT 2025
Powered by FUDForum. Page generated in 0.03640 seconds
