Home » Modeling » Eclipse Layout Kernel » Problem with edge labels
Problem with edge labels [message #1755369] Thu, 02 March 2017 11:36 Go to next message
Hello, great project!
I tried to layout a class diagram but it seems to not consider the edge labels. Am I doing something wrong?
index.php/fa/28635/0/
index.php/fa/28636/0/
index.php/fa/28637/0/
  • Attachment: before.png
    (Size: 9.44KB, Downloaded 487 times)
  • Attachment: after.png
    (Size: 6.38KB, Downloaded 477 times)
  • Attachment: settings.png
    (Size: 21.12KB, Downloaded 629 times)
Re: Problem with edge labels [message #1755421 is a reply to message #1755369] Fri, 03 March 2017 03:38 Go to previous messageGo to next message
Hi Peter,
I believe I need more information. Smile For starters, which drawing framework do you use to draw / edit your diagrams? Have you implemented your own DiagramLayoutConnector?
Christoph Daniel
Re: Problem with edge labels [message #1755429 is a reply to message #1755421] Fri, 03 March 2017 05:09 Go to previous messageGo to next message
Hello Christoph,
sorry should have added that. I use Papyrus and this connector
http://git.eclipse.org/c/papyrus/org.eclipse.papyrus.git/plain/extraplugins/elk/org.eclipse.papyrus.infra.gmfdiag.elk/src/org/eclipse/papyrus/infra/gmfdiag/elk/
Edit:
I debugged a little bit. The issue seems that in the layered algorithm. The EndLabelProcessor does not iterate over the layerlessnodes.
Greetings Peter
[Updated on: Fri, 03 March 2017 10:04] by Moderator
Re: Problem with edge labels [message #1755755 is a reply to message #1755429] Tue, 07 March 2017 09:46 Go to previous messageGo to next message
Hi Peter,
at the time the EndLabelProcessor is executed there shouldn't be any layerless nodes.
Could you do me a favour and export the layout graphs? Our website has some information on how to enable debug files and where they will end up. Could you activate those, execute layout once, and post the files somewhere?
Christoph Daniel
Re: Problem with edge labels [message #1755797 is a reply to message #1755369] Wed, 08 March 2017 04:22 Go to previous messageGo to next message
There was a bug in the configuration of the processors in the release. It should be fixed on the current master.
https://github.com/eclipse/elk/pull/142
Re: Problem with edge labels [message #1755829 is a reply to message #1755797] Wed, 08 March 2017 08:51 Go to previous message
Oh, that's interesting. I only looked at the current master and couldn't see anything wrong with it, but had forgotten all about the pull request. That will be fixed in 0.2.1 once that is released (we haven't decided on a release date yet).
Previous Topic:Sort node order from left to right LayeredLayoutProvider
Next Topic:Turn off random layouting
Current Time: Mon Jul 21 00:08:26 EDT 2025
Powered by FUDForum. Page generated in 0.25995 seconds
