Home » Language IDEs » PHP Development Tools (PDT) » Enforce default encoding - how to do it?
Enforce default encoding - how to do it? [message #16603] Sun, 22 April 2007 03:01 Go to next message
Originally posted by: no.spam.thanks.com
Hello everyone,
I had Eclipse configured to use UTF-8 as the default text file encoding on
my workspace. At that time, I created a PHP project which I'm working on -
I'm mentioning this because I'm not sure if it's a project's setting.
All my PHP files were being saved as UTF-8, which is not what I wanted. So
when I noticed it I configured ISO-8859-1 as the default text file encoding,
but when I create a new PHP file it's still UTF-8 and I have to manually
change the text file encoding on the file properties. That only happens with
..php files, the others files such as .js, .css and .html are being created
fine as ISO-8859-1.
So my question is: how do I configure it to use always the Eclipse default
text file encoding?
Francisco
Re: Enforce default encoding - how to do it? [message #16620 is a reply to message #16603] Mon, 23 April 2007 04:46 Go to previous messageGo to next message
Francisco Lopes schrieb:
> Hello everyone,
> fine as ISO-8859-1.
> text file encoding?
> Francisco
Hi Francisco,
take a look at this BugReport:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=174300
The Comments may clearify a bit.
Re: Enforce default encoding - how to do it? [message #16688 is a reply to message #16620] Tue, 24 April 2007 15:41 Go to previous messageGo to next message
Christian,
I didn't know it was a bug, thanks. :)
I guess we should cross-fingers and wait then...
Francisco
"Christian M
Re: Enforce default encoding - how to do it? [message #16702 is a reply to message #16688] Tue, 24 April 2007 18:20 Go to previous messageGo to next message
> Christian,
Perhaps it's intented bahaviour ... but to me it's a plain bug (since
PDT renders me unable to do a simple thing, wich i could do before ^^)
Will do ^^
> Francisco
Re: Enforce default encoding - how to do it? [message #17495 is a reply to message #16603] Wed, 25 April 2007 07:08 Go to previous messageGo to next message
Hi Francisco,
I was affected by this issue too. I've forced Eclipse to use ISO-8859-1
by changing the "Default encoding" setting under "General->Content
Types; Text->PHP Content Type".
I hope that this helps you.
Alejandro
Francisco Lopes escribió:
> Hello everyone,
> fine as ISO-8859-1.
> text file encoding?
> Francisco
Re: Enforce default encoding - how to do it? [message #17557 is a reply to message #16702] Thu, 26 April 2007 20:03 Go to previous messageGo to next message
Originally posted by: pavel.dvorak.work.gmail.com
I have similar problem. I want to set up default enoding as utf and
project encoding to windows-1250. I have set project encoding to
windows-1250 and nothing changes. Project files still open as utf. what
can i do?
Re: Enforce default encoding - how to do it? [message #17595 is a reply to message #17557] Fri, 27 April 2007 04:58 Go to previous messageGo to next message
> can i do?
As of now: Nothing except changing every single file manually.
An other Comment stated, that you might be able to ovverride the
"Content-Type-Enconding" by having subclipse-plugin active(?) on your
project and set the project's encoding through this.
But i didn't test it yet.
Re: Enforce default encoding - how to do it? [message #17608 is a reply to message #17595] Fri, 27 April 2007 05:53 Go to previous message
Christian Müller napsal(a):
>> what can i do?
can you explain how? i don't understand how to set it using subclipse
Previous Topic:Xdebug support for PDT 0.7 RC3
Next Topic:File -> New -> PHP [?]
Current Time: Fri Nov 07 15:25:36 EST 2025
Powered by FUDForum. Page generated in 0.03876 seconds
