Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » New composite type
New composite type [message #1724539] Wed, 24 February 2016 08:34 Go to next message
Can someone plz tell me if there is a sane and easy way to add a new composite type made out of few FBRT blocks? Sane - without FBDK, java compilation and other not-so-nice things.
What i'm trying to do is to create a simple composite type made out of a CNV_MDL (BasicFB), an E_CYCLE and a PUBL_4.
Or is it easier (yet imho quite dirty) to make a number of subapplications without messing with type creation?
Re: New composite type [message #1724592 is a reply to message #1724539] Wed, 24 February 2016 15:33 Go to previous messageGo to next message
Unfortunately currently for both 4DIAC FORTE and FBRT you need to compile all types. The only option you could go is with subapps. I don't regard subapps as dirty option. There are certain use-cases where even composite FBs can not be used or are not appropriate (e.g, you need to distribute parts to different devices, you need to perform instance specific internal parameters).
The only drawback of this solution is that currently no tool really supports sub-applications as they should be supported. Any help on this topic is greatly appreciated.
Re: New composite type [message #1755595 is a reply to message #1724592] Mon, 06 March 2017 04:00 Go to previous messageGo to next message
What is the basic difference between Composite FB type and SubAppType? I think they are very similar to each other. It may be better to use the model SubApp for Composite FB and generate internal FBs in 4DIAC instead in FORTE.
Re: New composite type [message #1755657 is a reply to message #1755595] Mon, 06 March 2017 10:49 Go to previous message
The main difference is that the content off subapplications can be distributed to different devices. This allows to do different things then CFBs. CFBs are atomic and for a user not destinquischable from Basic or SIFBs. SubApps are transperent and you can look in side. Especiaylly with the untyped subapps this get very interesting for structuring applications.
Alois
Previous Topic:FORTE: OSCAT library
Next Topic:Analog IO Expansion Board
Current Time: Wed Jul 23 16:15:20 EDT 2025
Powered by FUDForum. Page generated in 0.05898 seconds
