Home » Eclipse Projects » Eclipse 4 » Using e4view still requires class to be IViewPart
Using e4view still requires class to be IViewPart [message #1755606] Mon, 06 March 2017 05:10 Go to next message
I read Contribute e4 Views into the IDE and tried to put this in my application.
My extension looks like this:
  <extension
         point="org.eclipse.ui.views">
      <e4view
            class="com.mycompany.myplugin.views.MyView"
            id="com.mycompany.myplugin.views.my"
            name="My view"
            restorable="true">
      </e4view>
   </extension>
My view part is as simple as it can get:
public class MyView {
    @PostConstruct
    public void createControl(Composite parent) {}
    @Focus
    public void setFocus() {}
However, I still get a ClassCastException that my "MyView" can't be cast to "IViewPart". I am using Neon.2 (4.6.2). Is this a bug or am I missing something?
For now, I still use DIViewPart from e4.compat instead.
Re: Using e4view still requires class to be IViewPart [message #1755607 is a reply to message #1755606] Mon, 06 March 2017 05:15 Go to previous messageGo to next message
Where do you get the exception? The stacktrace would be good to see.
Re: Using e4view still requires class to be IViewPart [message #1755608 is a reply to message #1755607] Mon, 06 March 2017 05:17 Go to previous messageGo to next message
Here is the stack trace:
java.lang.ClassCastException: com.mycompany.myplugin.views.MyView cannot be cast to org.eclipse.ui.IViewPart
	at org.eclipse.ui.internal.registry.ViewDescriptor.createView(ViewDescriptor.java:58)
	at org.eclipse.ui.internal.ViewReference.createPart(ViewReference.java:101)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPart(CompatibilityPart.java:278)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:316)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:966)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:931)
	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:151)
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:375)
	at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:294)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:105)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:74)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:56)
	at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:975)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:651)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$1.run(PartRenderingEngine.java:536)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:520)
	at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:70)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:757)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:728)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:722)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:706)
	at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1317)
	at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:103)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:669)
	at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:70)
	at org.eclipse.e4.ui.workbench.renderers.swt.SashRenderer.processContents(SashRenderer.java:142)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:665)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:49)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:82)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:63)
	at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:725)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1059)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:693)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1492)
Re: Using e4view still requires class to be IViewPart [message #1755610 is a reply to message #1755608] Mon, 06 March 2017 05:30 Go to previous messageGo to next message
Is the id maybe used twice?
Re: Using e4view still requires class to be IViewPart [message #1755611 is a reply to message #1755610] Mon, 06 March 2017 05:35 Go to previous message
No, it is not. I had some leftover navigatorContent definition in the plugin.xml because this once was a CNF view and I want to transform it into a view which is usable with E4, I removed this, but I still get the exception. As I stated, when I use DIViewPart and embed it as an E3 view, I don't get the exception.
EDIT: Just for kicks, I changed the view's id to "com.mycompany.myplugin.views.my1". Now, I get another exception - the view appears, but inside, I get a red error marker stating: "Could not create the view: com.mycompany.myplugin.views.my".
I grep'd through my whole code base but can't see anywhere the view is used twice.
EDIT 2: I now cleaned the runtime workspace and it suddenly works.
EDIT 3: It works now, but my menu contributions don't appear. When using the old "view" and DIViewPart, they DO appear.
[Updated on: Mon, 06 March 2017 05:48] by Moderator
Previous Topic:Reproduce IElementUpdater behaviour in E4
Next Topic:TranslationObjectSupplier seems to leak FieldRequestor?
Current Time: Sun Nov 09 22:17:58 EST 2025
Powered by FUDForum. Page generated in 0.03301 seconds
