Home » Modeling » Epsilon » adding new element F to Containmentreference(I am using EOL to change an emf model that an instance of emf metamodel)
adding new element F to Containmentreference [message #1755257] Wed, 01 March 2017 12:36 Go to next message
Hi ,
I am using the following code to add new element type task to D2 which is a processor . task is the Containmentreference between the processor and task that means parent of task is processor D2.
I got error says that Property 'eRef' not found in object processor [name=D2, multiplicity=1, speedfactor=1.0, scheduling=default, replication=1, quantum=0.0, ]
[ var vprocessor=Lqn!processor;
for (p in vprocessor){
p.name=getName(SrightId);//this operation returns name of processor D2
"D2 ".print()+p.name.println();
var target=Lqn!task;
var t:new Lqn!task;
t.name=getName(valueIdS);\\return task its name is F
for (g in target){
var parentSource=g.closure(x | x.eContainer()) ;
"parent of task ".print()+parentSource.first().eClass.name.println();
var eRef=t.closure(x | x.eContainmentFeature);
"Containmentreference".print()+eRef.println();
var type=parentSource.eClass.println();
p.eRef.name.add(t);
} ][/code]
Can you please help me .
Metamodel and instance of metamodel are attached
[Updated on: Wed, 01 March 2017 12:39] by Moderator
Re: adding new element F to Containmentreference [message #1755267 is a reply to message #1755257] Wed, 01 March 2017 15:48 Go to previous messageGo to next message
Hi Taghreed,
Class "processor" doesn't seem to have a property called "eRef" in your metamodel.
Dimitris
Re: adding new element F to Containmentreference [message #1755281 is a reply to message #1755267] Wed, 01 March 2017 21:08 Go to previous messageGo to next message
Hi Dimitris,
I am getting the property "task" containment Refererence which is in the metamodel in processor class and assigning it to the variable eRef.
Can you please advise me.
Taghreed
Re: adding new element F to Containmentreference [message #1755285 is a reply to message #1755281] Thu, 02 March 2017 02:12 Go to previous messageGo to next message
Hi Taghreed,
No class has a feature called "eContainmentFeature" in your metamodel. Why did you expect this to work?
Dimitris
Re: adding new element F to Containmentreference [message #1755358 is a reply to message #1755285] Thu, 02 March 2017 10:50 Go to previous messageGo to next message
Hi Dimitris,
I tried to test my metamodel with this code:
 var tasks = Lqn!task;
   for (p in tasks ){
     "parent".print()+ p.asSequence().closure(x | x.eContainer()).println();
       var eRef :Sequence =p.closure(x | x.eContainmentFeature);
       "eRef ".print()+ eRef.println;
Then i got this in the console:
parentSequence {processor [name=D1, multiplicity=1, speedfactor=1.0, scheduling=default, replication=1, quantum=0.0, ], lqnmodel [name=model To lqn, description=null, lqnSchemaVersion=1, lqnCoreSchemaVersion=1, xmldebug=false, ]}
eRef Sequence {EReference [name=task, ordered=true, unique=true, lowerBound=1, upperBound=-1, many=true, required=true, changeable=true, volatile=false, transient=false, defaultValueLiteral=null, defaultValue=null, unsettable=false, derived=false, containment=true, container=false, resolveProxies=true, ], EReference [name=eStructuralFeatures, ordered=true, unique=true, lowerBound=0, upperBound=-1, many=true, required=false, changeable=true, volatile=false, transient=false, defaultValueLiteral=null, defaultValue=null, unsettable=false, derived=false, containment=true, container=false, resolveProxies=false, ]}
parentSequence {processor [name=D2, multiplicity=1, speedfactor=1.0, scheduling=default, replication=1, quantum=0.0, ], lqnmodel [name=model To lqn, description=null, lqnSchemaVersion=1, lqnCoreSchemaVersion=1, xmldebug=false, ]}
for each processor (parent) there are tasks (children) and i tried to add new task to processor p=D2 by this code :
p.task.add(t); it did work but when i replaced task with a variable eRef it generated the error.
Taghreed
[Updated on: Thu, 02 March 2017 11:02] by Moderator
Re: adding new element F to Containmentreference [message #1755425 is a reply to message #1755358] Fri, 03 March 2017 04:04 Go to previous messageGo to next message
Hi Taghreed,
Could you please provide a minimal example [1] I can use to reproduce this?
Dimitris
[1] https://www.eclipse.org/epsilon/doc/articles/minimal-examples/
Re: adding new element F to Containmentreference [message #1755481 is a reply to message #1755425] Fri, 03 March 2017 11:24 Go to previous messageGo to next message
Hi Dimitris,
I am using Eclipse version 1.3.201602270002.
Steps to produce the proplem:
-Run queryEtl(1) run configuration
-open oldexampleLqn.model by its default editor
-You will see that task F was added to the root (Lqnmodel) not to its parent which is Processor D2.
I know that i need to use p.task.add(t) to add F to its parent (processor D2) but i need to use a variable that holds task instead of using p.task.add(t) like this . I identified task as belows:
var eRef=g.closure(x | x.eContainmentFeature); then adding task(F) to D2 by using this code p.eRef.add(t);
I wish that i explained the problem more clearly now.
Taghreed
[Updated on: Fri, 03 March 2017 11:29] by Moderator
Re: adding new element F to Containmentreference [message #1755485 is a reply to message #1755481] Fri, 03 March 2017 12:02 Go to previous messageGo to next message
Hi Taghreed,
As discussed earlier in this thread p.eRef.add(t) fails because class Processor does not have an "eRef" attribute/reference. Changing this line to p.task.add(t) seems to be doing the trick.
Dimitris
Re: adding new element F to Containmentreference [message #1755489 is a reply to message #1755485] Fri, 03 March 2017 12:32 Go to previous messageGo to next message
but eRef is just a variable i mean eRef=task that is a reference in the Lqn metamodel :
class processor {
attr String name;
attr int multiplicity=1;
attr float speedfactor=1;
attr PSchedulerType scheduling;
attr int replication=1;
attr float quantum=0;
val task[+] #host task;
Did u mean that i canot use a variable that holds the name of the reference ??to do the trick u need to use it as it is?
Taghreed
[Updated on: Fri, 03 March 2017 12:36] by Moderator
Re: adding new element F to Containmentreference [message #1755491 is a reply to message #1755489] Fri, 03 March 2017 13:21 Go to previous message
Exactly; eRef is a variable but your code was using it as a property name.
Dimitris
Previous Topic:ETL Examples
Next Topic:Getting ConcurrentModificationException in ETL
Current Time: Sun Jul 27 11:53:26 EDT 2025
Powered by FUDForum. Page generated in 0.06106 seconds
