Re: Very slow git clone performance [message #1755411 is a reply to message #1755410] |
Fri, 03 March 2017 02:25   |
> Did you try to clone the same repository using native git command line ?
> Is this also slow ?
Basically, it is the same until the git bash as well as the console output of eclipse/oomph states 100% fetching. After that it takes a second for git bash and multiple minutes for oomph/eclipse to finish. Whatever is done after fetching all change sets. I do not know.
> Does the upstream repository have many refs ?
See my post: git rev-list --all --count = 1229
> Is the upstream repository gc'ed on a regular schedule ?
remote? It is a private GitHub repository. I do not know what github is automatically performing on it. I did not see any configuration option for that.
> Does the upstream repository have bitmap indexes (can be configured in gc configuration) ?
Sounds interesting, but I did not see any option for that on GitHub. But just to show you some more measures of the repository:
remote: Counting objects: 19343, done.
remote: Compressing objects: 100% (27/27), done.
remote: Total 19343 (delta 3), reused 0 (delta 0), pack-reused 19312
Receiving objects: 100% (19343/19343), 3.55 MiB | 105.00 KiB/s, done.
Resolving deltas: 100% (8095/8095), done.
I even not entirely convinced that a repack would fix this as the repository seems to be quite normal from the number of objects etc.
Re: Very slow git clone performance [message #1755990 is a reply to message #1754624] |
Thu, 09 March 2017 14:46  |
> Did you try to clone this repository using EGit in Eclipse ? Is that also slow ?
Yes, tried it. Is exactly as slow as within Oomph.
> The WindowCache is JGit's buffer cache used to avoid repeated IO to read the same data from pack files on disk.
> You may try to increase this cache size. Or alternatively switch on virtual memory mapping which delegates buffering pack file read access to the JVM's virtual memory mapping. This isn't on by default since Java doesn't provide a way to unmap files which have been mapped to virtual memory.
I tried increasing cache sizes as well as enable virtual memory mapping. No improvements here. What a pitty, that I cannot provide you the repository. But if I find some time, I may create a new repository with long paths just for testing purposes and to exclude it as a cause.
Currently, I am out of ideas. I will write some more lines, if I have investigated this behavior further.
FUDForum. Page generated in 0.11359 seconds
