Network Tracing - Adding a new protocol [message #1755339] |
Thu, 02 March 2017 08:18  |
I'm developing a tracer which uses most of tracecompass plug-ins.
I need to add several protocols to the trace compass pcap component. After a brief search, I found [1], which looked like the info I needed. The only problem is that it requires modifying source code. Unless I understood this wrong, I find this task impossible, since I would have to import most of tracecompass sources (due to various dependencies) and somehow manage to build the whole project locally.
Basically, I need to find a way to support new protocols in the tracer tool, in the way wireshark's plug-ins work.
Any updates on the topic signaled in the last section of that tutorial in the developer guide, in the TODO section?
"Make adding protocol more "plugin-ish", via extension points for instance. This would make it easier to support new protocols, without modifying the source code."
Did somebody else found a way to add a protocol (something based on tcp or udp) and can help me which some advices/code snipets/tutorial?
With respect, Andrei
[1] http://archive.eclipse.org/tracecompass/doc/org.eclipse.tracecompass.doc.dev/Network-Tracing.html
FUDForum. Page generated in 0.03665 seconds
