Home » Newcomers » Newcomers » Eclipse Installation - "Installation failed with an error"(Error, I need help)
icon9.gif  Eclipse Installation - "Installation failed with an error" [message #1755094] Tue, 28 February 2017 01:16 Go to next message
I can't install eclipse. If I try, it looks like this: http:// prntscr.com/eea9d8
The full error report is this: http:// pastebin.com/UJrhVnPY
These are my JAVA Versions: http:// prntscr.com/eea9su
Please guys, help me out! I dont know whats wrong!
Help me Sad
Re: Eclipse Installation - "Installation failed with an error" [message #1755163 is a reply to message #1755094] Tue, 28 February 2017 11:19 Go to previous messageGo to next message
What's in the Log? (The Show Log link on the red error area.) Do you have write access to D:\Programme? Was the installer able to create D:\Programme\Eclipse?
Re: Eclipse Installation - "Installation failed with an error" [message #1755180 is a reply to message #1755163] Tue, 28 February 2017 12:35 Go to previous messageGo to next message
Im not sure what you mean with "log", but thats the error report: http://pastebin.com/UJrhVnPY
Yes, I have write access to D: Drive.
My OS: Windows 10 64-bit btw
Re: Eclipse Installation - "Installation failed with an error" [message #1755207 is a reply to message #1755180] Wed, 01 March 2017 02:41 Go to previous messageGo to next message
Does the file C:\Users\Pascal\.p2\pool\plugins\org.eclipse.oomph.setup.ui.questionnaire_1.7.0.v20170104-1401.jar exist? Perhaps this was caused by a network problem. On Tuesdays the Eclipse download server tends to be overloaded.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=498116
Do you have the same problem if you try again today?
Re: Eclipse Installation - "Installation failed with an error" [message #1755253 is a reply to message #1755207] Wed, 01 March 2017 11:54 Go to previous messageGo to next message
Still the same Error. I tried it with JavaScript, it just doesnt work!
Re: Eclipse Installation - "Installation failed with an error" [message #1755258 is a reply to message #1755094] Wed, 01 March 2017 12:43 Go to previous messageGo to next message
Have you tried a path without a space in the name? And do you have full ownership of the drive including newly created directories? IIRC it's not always the same thing.
[Updated on: Wed, 01 March 2017 12:45] by Moderator
Re: Eclipse Installation - "Installation failed with an error" [message #1755263 is a reply to message #1755258] Wed, 01 March 2017 13:17 Go to previous message
Note that I asked "Does the file C:\Users\Pascal\.p2\pool\plugins\org.eclipse.oomph.setup.ui.questionnaire_1.7.0.v20170104-1401.jar exist? " I also asked "Was the installer able to create D:\Programme\Eclipse? " I.e., I'm curious how much of the target structure it was able to create. So showing what's in the file system at the target location would be helpful. If you don't answer all the questions that I ask for clarification, it gets very difficult to help.
It looks like you're using a somewhat older version of the installer that didn't not check the write permissions of the target folder, so I still suspect it's a write permissions problem. That's why it's important to know if anything was created at your target location.
Previous Topic:Using PhoneGap with ECLIPSE
Next Topic:AVD
Current Time: Sun Jul 27 15:37:18 EDT 2025
Powered by FUDForum. Page generated in 0.08445 seconds
