Home » Eclipse Projects » GEF » Migrating GEF 3 project
Migrating GEF 3 project [message #1753866] Fri, 10 February 2017 18:34 Go to next message
I'm migrating an e3 RCP project that made extensive use of GEF MVC. It was largely based off the old shapes example https://eclipse.org/articles/Article-GEF-diagram-editor/shape.html
Transitioning to e4 was a challenge, but we think it'll really be worth it and now have much of our core functionality working. However, GEF is proving to be a real struggle for us. As we understand it, GEF 3, will not work on e4 applications and we are ready to migrate to using GEF 4. We do not want to use the e4/e3 compatibility layer. It seems like we want to use Zest, but, honestly, the vast collection of components is baffling.
Are there any tutorials out there that do a walk through on a simple diagram editor like the old shapes example? Something that has a palette that lets you create nodes and then connect them with arcs?
Re: Migrating GEF 3 project [message #1753912 is a reply to message #1753866] Sun, 12 February 2017 04:23 Go to previous messageGo to next message
Hallo Ken,
the different components and their scope are documented in the reference documentation at https://github.com/eclipse/gef/wiki. While the documentation does not reflect the merger of MVC/MVC.FX (see http://nyssen.blogspot.de/2017/02/gef4-1-gef-5.html) yet, it should be a good starting point.
Besides, with respect to MVC, the logo example can pretty much be used as a reference, as we have tried to incorporate all directly supported 'features' there. In case you need to look into details, I would recommend to take a look at it.
Concerning tutorials, Frank Benoit has externally provided one MVC tutorial based on GEF4 at https://github.com/frankbenoit/gef4.mvc.tutorial. It could help you to get in touch with the concepts, while not being based on the current 5.0.0 code base. We have internally prepared an MVC Mindmap tutorial (based on 5.0.0 M5) that is not yet available, but should be published before Eclipse Converge (I will announce its availability here).
Best Regards,
Alexander
Re: Migrating GEF 3 project [message #1754827 is a reply to message #1753912] Wed, 22 February 2017 15:44 Go to previous messageGo to next message
Thank you for the reply! I've studied the gef4 MVC Logo example and I can see the similarities with gef3 MVC. One major difference is that it uses javafx. My existing RCP application was originally an eclipse 3.8 RCP app, which meant that its UI was created using SWT.
Is there a gef4 MVC example that does not use JavaFX? I'm not really excited about learning another toolkit without a good reason. I have tried to find an argument for why applications should migrate to javafx, but I have been unsuccessful. Do you know of one?
Re: Migrating GEF 3 project [message #1754856 is a reply to message #1754827] Thu, 23 February 2017 04:21 Go to previous messageGo to next message
Hi Ken,
there is no GEF4 1.x MVC example that does not use JavaFX. In fact, all GEF4 1.x / GEF 5 examples use JavaFX. Moreover, with GEF 5 we dropped the visualization-agnostic abstraction layer, so that GEF 5 MVC actually requires JavaFX.
There are many arguments for migrating to JavaFX. Just to name a few from the top of my head:
* HW accelerated graphics
* Scene graph API
* Animation support
* CSS styling support
* Media (audio, video) playback support
* Properties & Binding
* up-to-date technology (IMHO one of the best 2D rendering/GUI APIs available)
=> less boilerplate code
=> faster development
=> prettier graphics
Matthias
Re: Migrating GEF 3 project [message #1754923 is a reply to message #1754856] Fri, 24 February 2017 01:26 Go to previous messageGo to next message
I'm trying to dive in to adding GEF 4.1 to a plugin in my e4 RCP application. I've been looking at the org.eclipse.gef4.mvc.examples.logo.ui plugin (although I understand that is a 3.x plugin in order to work with the workbench). I added the org.eclipse.gef4.fx.swt plugin dependency to my plugin and the org.eclipse.gef4.fx.swt feature to my feature based product. When I hit add required, the product also added org.eclipse.gef4.common and org.eclipse.fx.runtime.min.feature.
To get started, I just wanted to display the canvas. I created a part and added this composite to it:
import javax.inject.Inject;
import org.eclipse.gef4.fx.swt.canvas.IFXCanvasFactory;
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Composite;
import javafx.embed.swt.FXCanvas;
public class AEGComposite extends Composite {
	@Inject
	private IFXCanvasFactory canvasFactory;
	private FXCanvas canvas = null;
	public AEGComposite(Composite parent, int style) {
		super(parent, style);
		setLayout(new FillLayout());
		canvas = canvasFactory.createCanvas(this, SWT.NONE);
This comes from the code in AbstractFXView. This compiles with no problem, but when I try to run the product, I get this error:
org.osgi.framework.BundleException: Could not resolve module: edu.illinois.mobius.atomic.advise [1275]
  Unresolved requirement: Require-Bundle: org.eclipse.gef4.fx.swt; bundle-version="1.0.1"
    -> Bundle-SymbolicName: org.eclipse.gef4.fx.swt; bundle-version="1.0.1.201609060946"
       org.eclipse.gef4.fx.swt [1279]
         Unresolved requirement: Require-Bundle: org.eclipse.gef4.common; bundle-version="[1.0.0,2.0.0)"
           -> Bundle-SymbolicName: org.eclipse.gef4.common; bundle-version="1.1.0.201609060946"
              org.eclipse.gef4.common [1278]
                Unresolved requirement: Import-Package: com.google.common.collect; version="[12.0.0,16.0.0)"
	at org.eclipse.osgi.container.Module.start(Module.java:444)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1620)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1599)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1571)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1514)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
I'm not sure where to find the package com.google.common.collect. How can I resolve this error?
Re: Migrating GEF 3 project [message #1754931 is a reply to message #1754923] Fri, 24 February 2017 03:22 Go to previous messageGo to next message
The package is provided by the com.google.guava bundle. It is contained in the GEF target.
Re: Migrating GEF 3 project [message #1756366 is a reply to message #1754931] Wed, 15 March 2017 18:03 Go to previous messageGo to next message
My RCP application is feature based. Do you know if there is a feature that contains com.google.guava?
Re: Migrating GEF 3 project [message #1759296 is a reply to message #1756366] Sun, 09 April 2017 22:23 Go to previous message
Can be had from Orbit, e.g.:
http://download.eclipse.org/tools/orbit/downloads/drops/R20170307180635/
Previous Topic:MULTIPLE GEF views in an editor
Next Topic:[GEF4-5] Resize children of Visible part of InfiniteCanvas
Current Time: Fri Jul 18 22:03:41 EDT 2025
Powered by FUDForum. Page generated in 1.24653 seconds
