Eclipselink error 3002 [message #1754707] |
Tue, 21 February 2017 12:14  |
I am doing a simple migration from Toplink 10g to native Eclipselink v2.6.4 by following the instructions to do so, namely using the renaming utility to update my package import statements and begin using eclipselink.jar (built in to Weblogic 12.2.1) instead of toplink.jar in my WEB-INF\lib folder.
Everything compiles ok but when I try to run my app I get the error below.
I tried using the old deployment mapping file as well as a new one generated from Eclipselink workbench by importing my old Toplink workbench project. Both cause the same error.
Note that I'm only doing a migration from Toplink to native Eclispelink. There is no JPA involved.
Any ideas on what`s wrong? It seems like it's trying to improperly use String instead of my actual class, but not sure.
Also, I know it says classNotFoundException but I haven't moved anything. The main difference is that Eclipselink is in the container now instead of Toplink in my web-inf\lib folder.
Exception [EclipseLink-3002] (Eclipse Persistence Services - 2.6.4.v20160829-44060b6): org.eclipse.persistence.exceptions.ConversionException
Exception Description: The object [ca.ncams.wisor.refdata.AccessTandem], of class [class java.lang.String], from mapping [org.eclipse.persistence.oxm.mappings.XMLDirectMapping[javaClass-->class/text()]] with descriptor [XMLDescriptor(org.eclipse.persistence.descriptors.ClassDescriptor --> [DatabaseTable(class-mapping-descriptor)])], could not be converted to [class java.lang.Class].
Internal Exception: java.lang.ClassNotFoundException: ca.ncams.wisor.refdata.AccessTandem
at org.eclipse.persistence.exceptions.ConversionException.couldNotBeConvertedToClass(ConversionException.java:98)
at org.eclipse.persistence.internal.helper.ConversionManager.convertObjectToClass(ConversionManager.java:451)
at org.eclipse.persistence.internal.helper.ConversionManager.convertObject(ConversionManager.java:146)
at org.eclipse.persistence.internal.oxm.XMLConversionManager.convertObject(XMLConversionManager.java:197)
at org.eclipse.persistence.internal.databaseaccess.DatasourcePlatform.convertObject(DatasourcePlatform.java:179)
at org.eclipse.persistence.oxm.mappings.XMLDirectMapping.getAttributeValue(XMLDirectMapping.java:301)
at org.eclipse.persistence.oxm.mappings.XMLDirectMapping.valueFromRow(XMLDirectMapping.java:364)
at org.eclipse.persistence.mappings.DatabaseMapping.readFromRowIntoObject(DatabaseMapping.java:1539)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildAttributesIntoObject(ObjectBuilder.java:462)
at org.eclipse.persistence.internal.oxm.XMLObjectBuilder.buildAttributesIntoObject(XMLObjectBuilder.java:378)
at org.eclipse.persistence.internal.oxm.XMLObjectBuilder.buildObject(XMLObjectBuilder.java:291)
at org.eclipse.persistence.oxm.mappings.XMLCompositeCollectionMapping.buildCompositeObject(XMLCompositeCollectionMapping.java:380)
at org.eclipse.persistence.oxm.mappings.XMLCompositeCollectionMapping.buildObjectFromNestedRow(XMLCompositeCollectionMapping.java:587)
at org.eclipse.persistence.oxm.mappings.XMLCompositeCollectionMapping.valueFromRow(XMLCompositeCollectionMapping.java:511)
at org.eclipse.persistence.internal.oxm.record.DOMUnmarshaller.xmlToObject(DOMUnmarshaller.java:469)
at org.eclipse.persistence.internal.oxm.record.DOMUnmarshaller.unmarshal(DOMUnmarshaller.java:267)
at org.eclipse.persistence.internal.oxm.record.DOMUnmarshaller.unmarshal(DOMUnmarshaller.java:246)
at org.eclipse.persistence.internal.oxm.XMLUnmarshaller.unmarshal(XMLUnmarshaller.java:530)
at org.eclipse.persistence.sessions.factories.XMLProjectReader.readObjectPersistenceRuntimeFormat(XMLProjectReader.java:293)
at org.eclipse.persistence.sessions.factories.XMLProjectReader.read(XMLProjectReader.java:186)
at org.eclipse.persistence.sessions.factories.XMLProjectReader.read(XMLProjectReader.java:242)
at org.eclipse.persistence.sessions.factories.XMLProjectReader.read(XMLProjectReader.java:100)
at ca.ncams.wisor.persistence.toplink.PersistenceManager.initializeTopLink(PersistenceManager.java:491)
at ca.ncams.wisor.persistence.toplink.PersistenceManager.<init>(PersistenceManager.java:83)
at ca.ncams.wisor.persistence.toplink.PersistenceManager.getInstance(PersistenceManager.java:96)
at ca.ncams.wisor.persistence.toplink.AutoRollbackFilter.doFilter(AutoRollbackFilter.java:57)
at ca.ncams.wisor.filter.FilterChainImpl.doFilter(FilterChainImpl.java:124)
at ca.ncams.wisor.presentation.filters.CatchAllFilter.doFilter(CatchAllFilter.java:60)
at ca.ncams.wisor.presentation.filters.NoCacheFilter.doFilter(NoCacheFilter.java:47)
at ca.ncams.wisor.filter.FilterJspBase.service(FilterJspBase.java:111)
at weblogic.servlet.internal.StubSecurityHelper$ServletServiceAction.run(StubSecurityHelper.java:286)
at weblogic.servlet.internal.StubSecurityHelper$ServletServiceAction.run(StubSecurityHelper.java:260)
at weblogic.servlet.internal.StubSecurityHelper.invokeServlet(StubSecurityHelper.java:137)
at weblogic.servlet.internal.ServletStubImpl.execute(ServletStubImpl.java:350)
at weblogic.servlet.internal.ServletStubImpl.onAddToMapException(ServletStubImpl.java:489)
at weblogic.servlet.internal.ServletStubImpl.execute(ServletStubImpl.java:376)
at weblogic.servlet.internal.ServletStubImpl.execute(ServletStubImpl.java:247)
at weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction.wrapRun(WebAppServletContext.java:3679)
at weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction.__run(WebAppServletContext.java:3649)
at weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction.run(WebAppServletContext.java)
at weblogic.security.acl.internal.AuthenticatedSubject.doAs(AuthenticatedSubject.java:326)
at weblogic.security.service.SecurityManager.runAsForUserCode(SecurityManager.java:197)
at weblogic.servlet.provider.WlsSecurityProvider.runAsForUserCode(WlsSecurityProvider.java:203)
at weblogic.servlet.provider.WlsSubjectHandle.run(WlsSubjectHandle.java:71)
at weblogic.servlet.internal.WebAppServletContext.doSecuredExecute(WebAppServletContext.java:2433)
at weblogic.servlet.internal.WebAppServletContext.securedExecute(WebAppServletContext.java:2281)
at weblogic.servlet.internal.WebAppServletContext.execute(WebAppServletContext.java:2259)
at weblogic.servlet.internal.ServletRequestImpl.runInternal(ServletRequestImpl.java:1691)
at weblogic.servlet.internal.ServletRequestImpl.run(ServletRequestImpl.java:1651)
at weblogic.servlet.provider.ContainerSupportProviderImpl$WlsRequestExecutor.run(ContainerSupportProviderImpl.java:270)
at weblogic.invocation.ComponentInvocationContextManager._runAs(ComponentInvocationContextManager.java:348)
at weblogic.invocation.ComponentInvocationContextManager.runAs(ComponentInvocationContextManager.java:333)
at weblogic.work.LivePartitionUtility.doRunWorkUnderContext(LivePartitionUtility.java:54)
at weblogic.work.PartitionUtility.runWorkUnderContext(PartitionUtility.java:41)
at weblogic.work.SelfTuningWorkManagerImpl.runWorkUnderContext(SelfTuningWorkManagerImpl.java:640)
at weblogic.work.ExecuteThread.execute(ExecuteThread.java:406)
at weblogic.work.ExecuteThread.run(ExecuteThread.java:346)
Caused by: java.lang.ClassNotFoundException: ca.ncams.wisor.refdata.AccessTandem
at java.net.URLClassLoader.findClass(URLClassLoader.java:381)
at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:331)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:348)
at org.eclipse.persistence.internal.helper.ConversionManager.convertObjectToClass(ConversionManager.java:448)
... 61 more
[Updated on: Wed, 22 February 2017 17:36] by Moderator
Re: Eclipselink error 3002 [message #1755694 is a reply to message #1754921] |
Mon, 06 March 2017 15:22  |
XMLProjectReader.read should be passed in the application's classloader. Try XMLProjectReader.read( config.getProperty( "TopLinkMappingFile" ), this.getClass().getClassLoader() ); this should work assuming the class can be loaded using the same loader that is loading the initializeTopLink class/method.
FUDForum. Page generated in 0.06822 seconds
