Home » Newcomers » Newcomers » hide (filter) comments
hide (filter) comments [message #175488] Thu, 19 October 2006 10:14 Go to next message
Originally posted by: hannes.ramsenthaler.anton-paar.com
Hi everyone!
I want to hide parts of my code viewed in eclipse.
For example:
/* ABC
comment
comment
comment
void main(void)
int i=0;
int j=1;
/* ABC comment1
comment2 */
i=j;
should be viewed like:
void main(void)
int i=0;
int j=1;
i=j;
Each comment starts with: "/* ABC"
end ends with: "*/" (a regex is possible for the filter)
I can't remove this comments permanetly in the source file cause other
programmers need them.
Is there a plug-in or someting like that, which solves my problem?
Re: hide (filter) comments [message #175503 is a reply to message #175488] Thu, 19 October 2006 10:23 Go to previous messageGo to next message
Originally posted by: wayne.beaton._NOSPAM_eclipse.org
hannes wrote:
> Hi everyone!
> For example:
> /* ABC
> comment
> comment
> comment
> void main(void)
> int i=0;
> int j=1;
> /* ABC comment1
> comment2 */
> i=j;
> void main(void)
> int i=0;
> int j=1;
> i=j;
In the Java editor, there are two strips on the left side (three if
you're showing line numbers). The rightmost strip is for folding (there
are little circles containing pluses and minuses). Put your cursor there
and from the pop-up menu, select "Folding > Collapse comments".
Good enough?
Wayne
Re: hide (filter) comments [message #175719 is a reply to message #175503] Fri, 20 October 2006 03:12 Go to previous message
> Good enough?
Im using the c/c++ editor,
and i don't want to collapse all comments - only those starting with "/*
ABC" throw "*/".
Do you know another solution?
Previous Topic:Tomcat localhost log file
Next Topic:com.sun.jimi/com.genetic/netscape.javascript.JSObject
Current Time: Sun Nov 02 01:52:29 EST 2025
Powered by FUDForum. Page generated in 0.07947 seconds
