Home » Modeling » TMF (Xtext) » Problems when referencing Ecore elements using an imported Ecore model
Problems when referencing Ecore elements using an imported Ecore model [message #1754821] Wed, 22 February 2017 13:47 Go to next message
in a new DSL I started to work on, I refer to Ecore elements in the DSL, something like
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
import "http://www.eclipse.org/xtext/xbase/Xbase" as xbase
generate myDsl "...my uri..."
Program:
	('metamodel' metamodels+=[ecore::EPackage|STRING])*
So far so good, everything works. Now I'd like to switch to a manually maintained ecore model. I performed the steps to switch to an imported ecore model (starting from the one that Xtext had previously generated).
As soon as I switch in the grammar:
import "...my uri..."
The grammar editor starts complaining with a warning for the import:
"The imported package refers to elements in the package registry
instead of using the instances from the workspace"
and for the assignment metamodels+=[ecore::EPackage|STRING]) I get an error:
"Cannot find compatible feature metamodels in sealed EClass
Program from imported package myuri:
The type 'EPackage' [org.eclipse.emf.ecore.EPackage] used in
the reference 'metamodels' is inconsistent. Probably this is
due to an unsupported kind of metamodel hierarchy."
However, the workflow mwe2 still runs (of course, I updated it so that it references my genmodel).
The warning (not the error) proposes a quickfix to "update the imported package". The quickfix transforms in my ecore the reference:
<eStructuralFeatures xsi:type="ecore:EReference" name="metamodels" unique="false"
        upperBound="-1" eType="ecore:EClass http://www.eclipse.org/emf/2002/Ecore#//EPackage"/>
into
        upperBound="-1" eType="ecore:EClass ../../../org.eclipse.emf.ecore/model/Ecore.ecore#//EPackage"/>
Now the editor is happy (no more errors nor warnings). However, now it is the mwe2 workflow that complains with the same error I used to have in the editor:
"Cannot find compatible feature metamodels in sealed EClass EdeltaProgram from imported package ...myuri...: The type 'EPackage' used in the reference 'metamodels' is inconsistent. Probably this is due to an unsupported kind of metamodel hierarchy. (ErrorCode: CannotCreateTypeInSealedMetamodel)"
is there anything I could do to make "everyone" happy?
Could this be related https://github.com/eclipse/xtext-core/issues/41?
thanks in advance
Lorenzo
Re: Problems when referencing Ecore elements using an imported Ecore model [message #1754822 is a reply to message #1754821] Wed, 22 February 2017 13:50 Go to previous messageGo to next message
yes this is what i took from that issue => you have to use the old style workflow
Re: Problems when referencing Ecore elements using an imported Ecore model [message #1754823 is a reply to message #1754822] Wed, 22 February 2017 14:04 Go to previous messageGo to next message
interestingly this xcore setup seems to work (i did not test if what comes out acutally runs
@GenModel(nsUri="http://www.example.com//zzz")
package zzz
import org.eclipse.emf.ecore.EPackage
class Model {
	refers EPackage[] metamodels
grammar org.xtext.example.mydsl8.MyDsl with org.eclipse.xtext.common.Terminals
import "zzz"
Model returns Model:
	{Model}
	'Model'
		('metamodels' '(' metamodels+=[ecore::EPackage|STRING] ( "," metamodels+=[ecore::EPackage|STRING])* ')' )?
		language = StandardLanguage {
			name = "org.xtext.example.mydsl8.MyDsl"
			fileExtensions = "mydsl8"
			referencedResource = "platform:/resource/org.eclipse.emf.ecore/model/Ecore.genmodel"
			referencedResource = "platform:/resource/zzz.xcore/model/zzz.xcore"
Re: Problems when referencing Ecore elements using an imported Ecore model [message #1754825 is a reply to message #1754822] Wed, 22 February 2017 14:10 Go to previous messageGo to next message
I had the same problems for the OCL and QVTd grammars.
Unless you really want to have Ecore as an open project, import it by its nsURI and NEVER reference relatively.
Conversely metamodels in your own projects refer to by platform:/resource... and ALWAYS reference relatively.
grammar org.eclipse.ocl.xtext.base.Base hidden(WS, ML_COMMENT, SL_COMMENT) //with org.eclipse.xtext.common.Terminals
import "platform:/resource/org.eclipse.ocl.pivot/model/Pivot.ecore" as pivot
import "platform:/resource/org.eclipse.ocl.xtext.base/model/BaseCS.ecore"
This isn't really what Xtext likes, but it is essential if the references in your models are to be compatible with other modelling tools. Xtext provides a project-specific preference that enables you to ignore the "package not imported through URI" warning.
Ed Willink
Re: Problems when referencing Ecore elements using an imported Ecore model [message #1754854 is a reply to message #1754825] Thu, 23 February 2017 04:13 Go to previous messageGo to next message
Ed, I'm not sure I understand what you're suggesting to do:
I modified my grammar as follows (I restored the original ecore, thus the ecore references are of the shape eType="ecore:EClass http://www.eclipse.org/emf/2002/Ecore#//EPackage"):
import "platform:/resource/org.eclipse.xtext.xbase/model/Xbase.ecore" as xbase
import "platform:/resource/org.eclipse.xtext.xbase/model/Xtype.ecore" as xtype
import "platform:/resource/org.eclipse.xtext.common.types/model/JavaVMTypes.ecore" as types
//generate mydsl "myuri"
import "platform:/resource/myproject/model/custom/MyDsl.ecore"
But the Xtext editor still complains for the assignments for the assignment metamodels+=[ecore::EPackage|STRING])
Re: Problems when referencing Ecore elements using an imported Ecore model [message #1754855 is a reply to message #1754854] Thu, 23 February 2017 04:17 Go to previous messageGo to next message
i assume you should use "platform:/resource/org.eclipse.emf.ecore/model/Ecore.ecore"
Re: Problems when referencing Ecore elements using an imported Ecore model [message #1754860 is a reply to message #1754855] Thu, 23 February 2017 04:48 Go to previous messageGo to next message
Christian Dietrich wrote on Thu, 23 February 2017 09:17
where? in the grammar or in the ecore?
That's not what Ed was suggesting though...
Re: Problems when referencing Ecore elements using an imported Ecore model [message #1754862 is a reply to message #1754860] Thu, 23 February 2017 05:01 Go to previous messageGo to next message
in the grammar.
Re: Problems when referencing Ecore elements using an imported Ecore model [message #1754867 is a reply to message #1754862] Thu, 23 February 2017 05:53 Go to previous messageGo to next message
OK, I added that in the grammar:
import "platform:/resource/org.eclipse.emf.ecore/model/Ecore.ecore" as ecore
The Xtext editor still complains with errors and now also mwe2 fails with the same problems, so both now fail consistently.
If I now modify the ecore manually using platform uris for ecore references, the editor is happy but now the mwe2 fails with a different error:
java.lang.IllegalStateException: Validation Error in edelta.Edelta: The rule 'STRING' is not valid for a cross reference since it does not return an EString. You'll have to wrap it in a data type rule.
at org.eclipse.xtext.xtext.generator.XtextGeneratorLanguage$1.add(XtextGeneratorLanguage.java:300)
If I redefine the terminal rule STRING in my grammar
terminal STRING:
			'"' ( '\\' . /* ('b'|'t'|'n'|'f'|'r'|'u'|'"'|"'"|'\\') */ | !('\\'|'"') )* '"'? |
			"'" ( '\\' . /* ('b'|'t'|'n'|'f'|'r'|'u'|'"'|"'"|'\\') */ | !('\\'|"'") )* "'"?;
Then mwe2 throws another exception:
java.lang.RuntimeException: Problems running workflow edelta.GenerateEdelta: Problem parsing 'file:/home/bettini/work/xtext/edelta/edelta.parent/edelta/../edelta/src/edelta/Edelta.xtext':
TransformationDiagnostic: null:92 Cannot inherit from terminal rule and return another type. (ErrorCode: InvalidSupertype)
I guess there's no easy way to deceive the EMF registry...
Re: Problems when referencing Ecore elements using an imported Ecore model [message #1754873 is a reply to message #1754867] Thu, 23 February 2017 07:06 Go to previous messageGo to next message
terminal STRING returns ecore::EString does not work?
Re: Problems when referencing Ecore elements using an imported Ecore model [message #1754874 is a reply to message #1754873] Thu, 23 February 2017 07:08 Go to previous messageGo to next message
and it again looks like the ecore from terminals is not the same as ecore from your xtext
=> maybe omit terminals and copy all the rules solves this
unfortunately i dont have enhough insight to work on this ugly bug and i dont get any support
Re: Problems when referencing Ecore elements using an imported Ecore model [message #1754875 is a reply to message #1754874] Thu, 23 February 2017 07:19 Go to previous messageGo to next message
By omitting terminals you mean not inheriting from Terminals grammar? If that is the case, I can't do that, since I inherit from Xbase...
This does not work
because Xtext still detects that you're trying to override the rule, see the error in my previous post, (with a different type since the two are incomparable because of the two instances of ecore)...
Re: Problems when referencing Ecore elements using an imported Ecore model [message #1754876 is a reply to message #1754875] Thu, 23 February 2017 07:28 Go to previous messageGo to next message
hmmm.
did you try to use xcore instead of ecore?
Re: Problems when referencing Ecore elements using an imported Ecore model [message #1754878 is a reply to message #1754876] Thu, 23 February 2017 07:47 Go to previous messageGo to next message
Using xcore usually drags in many more problems... :/ I'll also try to use xcore later.
I was thinking of playing with resource set initialization but XtextGeneratorLanguage does not expose resourceSetInitializer, so I can't do something like
  resourceSetInitializer = MyResourceSetInitializer
how should I use injection in this context (mwe2) to inject my resource set initializer?
Re: Problems when referencing Ecore elements using an imported Ecore model [message #1754880 is a reply to message #1754878] Thu, 23 February 2017 07:58 Go to previous messageGo to next message
OK, I can answer myself:
class CustomGeneratorModule extends DefaultGeneratorModule {
	def Class<? extends XtextGeneratorResourceSetInitializer> bindXtextGeneratorResourceSetInitializer() {
		CustomXtextGeneratorResourceSetInitializer
Workflow {
	component = XtextGenerator {
		configuration = CustomGeneratorModule {
			project = StandardProjectConfig {...
and (note the commented line):
@Log
class CustomXtextGeneratorResourceSetInitializer extends XtextGeneratorResourceSetInitializer {
	override initialize(ResourceSet resourceSet, List<String> referencedResources) {
		val delegate = new StandaloneSetup
		delegate.resourceSet = resourceSet
//		resourceSet.packageRegistry.put(EcorePackage.eNS_URI, EcorePackage.eINSTANCE)
		referencedResources.forEach[
			loadResource(resourceSet)
		registerGenModels(resourceSet)
		registerEPackages(resourceSet)
... everything else copied and pasted from the superclass since it's all private
This makes mwe2 finally work... (and tests are still green)
I don't know how this could be generalized for the bug...
I'll also try to revert the imports in the grammar with platform uris and see what happens
Re: Problems when referencing Ecore elements using an imported Ecore model [message #1754883 is a reply to message #1754880] Thu, 23 February 2017 08:50 Go to previous messageGo to next message
Moreover, in the grammar, you can simply use URIs for imports (as long as in the ecore you refer to ecore stuff with platform uris).
Re: Problems when referencing Ecore elements using an imported Ecore model [message #1754892 is a reply to message #1754855] Thu, 23 February 2017 11:02 Go to previous message
Christian Dietrich wrote on Thu, 23 February 2017 04:17
If Xtext tooling is the limit of your modeling aspirations, platform:/resource/org.eclipse.emf.ecore/model/Ecore.ecore may be convenient since you benefit from an Xtext-ism (? the Xtext index) whereby Xtext tooling doesn't actually use the Ecore.ecore that you say should be used.
However if you want to use your *.xtext model in another regular tool, in my case in an Xtext2LPG M2M, you need to use a correct reference; the nsURI.
I have no idea why the nsURI reference does not work for you, but without seeing all your tooling, who knows what magic you may have accidentally done.
Ed Willink
Previous Topic:Producing multiple objects from one rule
Next Topic:[SOLVED] Bring rule call and cross-reference under one feature
Current Time: Mon Nov 10 07:40:15 EST 2025
Powered by FUDForum. Page generated in 0.05343 seconds
