Keyboard shortcut to cut line [message #298649] |
Thu, 02 February 2006 00:44  |
Originally posted by: nomail.email.com
Is there a keyboard shortcut in Eclipse to cut a line?
Can I assign a key combination to do this?
Ctrl-D works well if you just want the line gone but it does not help if
you want to paste it somewhere else.
alt-arrows works ok if you are only moving a couple lines away in the same
editor but it is inconvenient most of the time
I got used to the speed of vi, this is the one feature I miss the most.
As a work-around is there a keyboard shortcut to select the current line
no matter where you are in it?
My current method is cumbersome:
1. press home key
2. Shift-End
3. Ctrl-X
There has to be a better way?
thank you.
FUDForum. Page generated in 0.02886 seconds
