Home » Eclipse Projects » Kura » ConfigurableComponent is not getting activated(I have created ConfigurableComponent Demo by floowing instruction given at http://eclipse.github.io/kura/doc/configurable_component.html. Bundle got added but service is not appearing on UI)
ConfigurableComponent is not getting activated [message #1754396] Fri, 17 February 2017 03:50 Go to next message
I have created configurable component using example given at eclipse.github.io/kura/doc/configurable_component. When I started local emulator on my raspberry pi in logs I can see bundle is registered. I opened localhost:8080/kura and I can see my bundle in list of all bundles with status "Active" but I cant see this service on left pane of kura local admin page under "SERVICES" pane. Please en-light me on same.
Re: ConfigurableComponent is not getting activated [message #1754451 is a reply to message #1754396] Fri, 17 February 2017 17:30 Go to previous messageGo to next message
Can you login to the OSGi console (telnet localhost 5002) and issue the 'ls' command? Please post the output of that command to the forum.
--Dave
Re: ConfigurableComponent is not getting activated [message #1769809 is a reply to message #1754451] Thu, 03 August 2017 10:32 Go to previous message
Hi Dave,
I m having exactly same problem what "samyak" has mentioned. Could you help me?
Previous Topic:Can Kura publish MQTT messages to eclipse Hono ?
Next Topic:Metatype configuration supported data types - tables/lists?
Current Time: Wed Jul 30 07:11:04 EDT 2025
Powered by FUDForum. Page generated in 0.03868 seconds
