Home » Language IDEs » C / C++ IDE (CDT) » Using CDT parser seperate from Eclipse(Using Index without Eclipse workspace and project)
Using CDT parser seperate from Eclipse [message #1753708] Thu, 09 February 2017 03:10 Go to next message
To analyze C++ source code which is in my server, I need to use CDT Parser apart from Eclipse.
Is there any good way for doing semantic analysis?
By using below code I succeeded syntactic analysis only.
IScannerInfo scanInfo = new ScannerInfo();
IParserLogService log = new DefaultLogService();
IncludeFileContentProvider fileCreator= IncludeFileContentProvider.getEmptyFilesProvider();
IIndex index = null;
int options = 8;
reader = FileContent.createForExternalFileLocation("fullPath");
GPPLanguage.getDefault().getASTTranslationUnit(reader, scanInfo, fileCreator, index, options, log)
I found out that the failure reason is index = null.
Because index object is managed by Eclipse WorkSpace, Project, creating index instance is so hard. (coupling)
Is there any good way to use Index without Eclipse workspace and project?
Re: Using CDT parser seperate from Eclipse [message #1754179 is a reply to message #1753708] Wed, 15 February 2017 00:05 Go to previous messageGo to next message
Self Reply
Doing c++ semantic analysis using CDT parser is possible. (without index)
By resolving binding it is possible.
The reason I can not resolve binding was I used IASTTranslationUnit.
By using ICPPASTTranslationUnit I can get binding object.
Re: Using CDT parser seperate from Eclipse [message #1815957 is a reply to message #1754179] Tue, 15 October 2019 21:56 Go to previous message
I want to know how to do that (semantic analysis without index)?
Previous Topic:CMake project uses default (Ninja) project generator causing build failure
Next Topic:How can I get all TranslationUnits if I have a CProject?
Current Time: Mon Jul 21 07:40:33 EDT 2025
Powered by FUDForum. Page generated in 0.04858 seconds
