Home » Eclipse Projects » WindowBuilder » Existing Eclipse project run on new version of Eclipse
icon2.gif  Existing Eclipse project run on new version of Eclipse [message #1754124] Tue, 14 February 2017 11:00 Go to next message
Existing Eclipse project details :
Eclipse platform (3.0 Mx to 3.3.1) OS 32 bit - SWT version 32 bit
1. How to run on -
Eclipse 4.6.2 on OS 64 bit
OR any latest version of Eclipse
2. Is it possible to run properly existing 32 bit SWT to 64bit SWT version ?
Re: Existing Eclipse project run on new version of Eclipse [message #1754142 is a reply to message #1754124] Tue, 14 February 2017 12:23 Go to previous messageGo to next message
1) you can just
- launch latest Eclipse
- let it create a new workspace
- import all old projects into the new workspace (File, Import, General, Existing Projects into Workspace)
2) if you didn't use any low-level 32-bit specific OS calls, then you should have no problem.
You will have to fix the launch, since most probably it contains a specific win 32 bit fragment.
In general, given the big gap between 3.3 and 4.6 APIs, you may have to fix several calls, but it depends a lot on the specific usage of the platform and other frameworks.
Vincenzo Caselli
Re: Existing Eclipse project run on new version of Eclipse [message #1754143 is a reply to message #1754124] Tue, 14 February 2017 12:23 Go to previous messageGo to next message
1) you can just
Vincenzo Caselli
Re: Existing Eclipse project run on new version of Eclipse [message #1754158 is a reply to message #1754143] Tue, 14 February 2017 15:03 Go to previous message
Thanks for your reply
- 1 done no output even can't open swt class file properly with GUI mode
Vincenzo Caselli wrote on Tue, 14 February 2017 17:23
1) you can just
Vincenzo Caselli
[Updated on: Tue, 14 February 2017 15:04] by Moderator
Previous Topic:Internal Error WindowBuilder encountered unexpected internal error.
Next Topic:Offer to help with project
Current Time: Sat Jun 14 02:16:08 EDT 2025
Powered by FUDForum. Page generated in 0.03763 seconds
