Home » Newcomers » Newcomers » Eclipse Startup Error
Eclipse Startup Error [message #525855] Wed, 07 April 2010 21:45 Go to next message
Eclipse worked fine last night, but when I tried to start it up today it brings up this error message.
I originally thought that it was the workspace that was configured improperly, but I deleted the workspace (moved it somewhere else) and it still doesn't work.
Any help?
http://img707.imageshack.us/img707/4416/ss20100407181208.png
Here's the log:
!SESSION 2010-04-07 17:58:37.208 -----------------------------------------------
eclipse.buildId=I20080617-2000
java.version=1.6.0_13
Command-line arguments:  -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 4 0 2010-04-07 17:58:37.457
!MESSAGE Startup error
!STACK 1
java.lang.NumberFormatException: For input string: ""
at java.lang.NumberFormatException.forInputString(Unknown Source)
at java.lang.Integer.parseInt(Unknown Source)
at org.eclipse.osgi.storagemanager.StorageManager.updateTable(StorageManager.java:512)
at org.eclipse.osgi.storagemanager.StorageManager.open(StorageManager.java:694)
at org.eclipse.osgi.internal.baseadaptor.BaseStorage.initFileManager(BaseStorage.java:208)
at org.eclipse.osgi.internal.baseadaptor.BaseStorage.initialize(BaseStorage.java:142)
at org.eclipse.osgi.baseadaptor.BaseAdaptor.initializeStorage(BaseAdaptor.java:124)
at org.eclipse.osgi.framework.internal.core.Framework.initialize(Framework.java:180)
at org.eclipse.osgi.framework.internal.core.Framework.<init>(Framework.java:152)
at org.eclipse.osgi.framework.internal.core.OSGi.createFramework(OSGi.java:90)
at org.eclipse.osgi.framework.internal.core.OSGi.<init>(OSGi.java:31)
at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(EclipseStarter.java:286)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:175)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
Re: Eclipse Startup Error [message #526000 is a reply to message #525855] Thu, 08 April 2010 10:03 Go to previous messageGo to next message
> still doesn't work.
Can you launch it with the -clean option?
/Paul
Re: Eclipse Startup Error [message #526013 is a reply to message #525855] Thu, 08 April 2010 10:31 Go to previous messageGo to next message
Nope, that's what I tried first.
I also tried adding
-data "C:/newworkspace"
to change the workspace if that was the issue, but I'm not sure I used the command correctly. Also I have Eclipse set to prompt for the workspace on startup anyways.
Re: Eclipse Startup Error [message #526098 is a reply to message #526013] Thu, 08 April 2010 12:40 Go to previous messageGo to next message
> I also tried adding
<groping in the dark> Under the Eclipse installation directory is a
folder named ...\configuration\.settings. If you move that folder to
some temporary location, will Eclipse start (it'll rebuild the folder
and at least one of the prefs files if it starts)? If yes, you can
experiment to see which prefs file is the culprit.
/Paul
Re: Eclipse Startup Error [message #1753325 is a reply to message #525855] Fri, 03 February 2017 15:43 Go to previous message
I have the same error.How did you resolve it?Could you please suggest me a way to resolve it?
Previous Topic:!ENTRY org.eclipse.osgi 4 0 2017-02-03 13:23:15.443 !MESSAGE Startup error !STACK 1 java.lang.Number
Next Topic:Which version of eclipse I have to install
Current Time: Fri Jul 18 04:46:18 EDT 2025
Powered by FUDForum. Page generated in 0.46597 seconds
