Home » Eclipse Projects » Spatiotemporal Epidemiological Modeler (STEM) » Problem with Eclipse Launcher on Mac(Problems Launching STEM - and temporary workaround)
Problem with Eclipse Launcher on Mac [message #1753241] Thu, 02 February 2017 16:10
The problems launching STEM seem to be caused by a MacOS issue (after security update) with the version of the Equinox Launcher used by STEM. The bug is not in STEM itself. The fix may require a major build update but we are investigating.
Meanwhile Mac Users should use the following workaround.
1) Open a Terminal Window
2) Type Java -version and make sure yoru are running Java8
3) cd into the directory that includes the STEM executable (this is inside of the STEM.app container):
cd ...installfolder.../stem/STEM.app/Contents/MacOS
type ./STEM
STEM will launch and run fine.
As soon as we have a fix we will release a new build with working launcher but for now please use this command line proceedure from a terminal window to launch STEM on OSx
Previous Topic:STEM 3.0.0 Milestone 5 build is does not run on Mac
Next Topic:Digital Epidemiology
Current Time: Mon Jun 02 22:01:40 EDT 2025
Powered by FUDForum. Page generated in 0.23270 seconds
