| Re: SVG display [message #1753627 is a reply to message #1753545] |
Wed, 08 February 2017 05:00  |
Hi Ismael,
the plugin provides a property view definition for symbols. It appears when you use the Papyrus internal profile and apply the TypeSymbolDefinition stereotype to an element.
It seems odd that you get the described exceptions when the plugin is not there. On my machine SVG shapes are still displayed and I do not have exceptions, if I deactivate it (by removing it from the run/debug-configuration) Did you change other things in your environment? (well, besides that if you did not have this plugin, you installed Papyrus in an uncommon way, use the sources or have a run-configuration with selected plugins only?)
FUDForum. Page generated in 0.07795 seconds
