Home » Modeling » TMF (Xtext) » Xtext tutorial unexpected result(File is not syntax highlighted)
Xtext tutorial unexpected result [message #1752928] Mon, 30 January 2017 16:17 Go to next message
index.php/fa/28267/0/Hello,
Just trying out the "15 Minutes tutorial" in Eclipse Neon and after splitting the files as described in "Second Iteration: Adding Packages and Imports" and then running the app, I'm getting the odd behavior where the third file "blogs.dmodel" is not being syntax highlighted -- whereas the other two are properly formatted. Screenshot enclosed. Thanks in advance for any help!
Re: Xtext tutorial unexpected result [message #1752983 is a reply to message #1752928] Tue, 31 January 2017 11:29 Go to previous messageGo to next message
are you sure you open all files in "yourdsl"-Editor? and regenated the grammar after change?
[Updated on: Tue, 31 January 2017 11:34] by Moderator
Re: Xtext tutorial unexpected result [message #1752984 is a reply to message #1752983] Tue, 31 January 2017 12:00 Go to previous message
Well I just tried again, closing and opening the file. At first it didn't work. Then I right-clicked to see what the default editor was that it was using. Then I double-clicked again and it worked (!).
So I guess I am good for now though I am suspicious it would happen again.
Thanks!
Previous Topic:Parsing *some* comments
Next Topic:Xtext and EMF4CPP
Current Time: Sat Jul 19 00:50:59 EDT 2025
Powered by FUDForum. Page generated in 0.03816 seconds
