| Problem using XtextServlet in SpringBoot Application [message #1719826] |
Tue, 12 January 2016 06:28  |
i am trying to integrate the XtextServlet in my SpringBoot application for the web integration of my DSL.
During my request to the server i get an error from the XtextServlet:
java.lang.IllegalStateException: STREAMED
at org.eclipse.jetty.server.Request.getReader(Request.java:979) ~[jetty-server-9.2.14.v20151106.jar:9.2.14.v20151106]
at javax.servlet.ServletRequestWrapper.getReader(ServletRequestWrapper.java:266) ~[javax.servlet-api-3.1.0.jar:3.1.0]
at org.eclipse.xtext.web.servlet.HttpServiceContext.initializeParameters(HttpServiceContext.java:91) ~[org.eclipse.xtext.web.servlet-2.9.0.jar:na]
at org.eclipse.xtext.web.servlet.HttpServiceContext.<init>(HttpServiceContext.java:43) ~[org.eclipse.xtext.web.servlet-2.9.0.jar:na]
at org.eclipse.xtext.web.servlet.XtextServlet.getService(XtextServlet.java:216) ~[org.eclipse.xtext.web.servlet-2.9.0.jar:na]
at org.eclipse.xtext.web.servlet.XtextServlet.doPut(XtextServlet.java:136) ~[org.eclipse.xtext.web.servlet-2.9.0.jar:na]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:710) ~[javax.servlet-api-3.1.0.jar:3.1.0]
at org.eclipse.xtext.web.servlet.XtextServlet.service(XtextServlet.java:60) ~[org.eclipse.xtext.web.servlet-2.9.0.jar:na]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790) ~[javax.servlet-api-3.1.0.jar:3.1.0]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:812) ~[jetty-servlet-9.2.14.v20151106.jar:9.2.14.v20151106]
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1669) ~[jetty-servlet-9.2.14.v20151106.jar:9.2.14.v20151106]
at org.eclipse.jetty.websocket.server.WebSocketUpgradeFilter.doFilter(WebSocketUpgradeFilter.java:224) ~[websocket-server-9.2.14.v20151106.jar:9.2.14.v20151106]
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1652) ~[jetty-servlet-9.2.14.v20151106.jar:9.2.14.v20151106]
at org.springframework.web.filter.RequestContextFilter.doFilterInternal(RequestContextFilter.java:99) ~[spring-web-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107) ~[spring-web-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.web.filter.HttpPutFormContentFilter.doFilterInternal(HttpPutFormContentFilter.java:84) ~[spring-web-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.web.filter.HiddenHttpMethodFilter.doFilterInternal(HiddenHttpMethodFilter.java:77) ~[spring-web-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:121) ~[spring-web-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:585) [jetty-servlet-9.2.14.v20151106.jar:9.2.14.v20151106]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [jetty-server-9.2.14.v20151106.jar:9.2.14.v20151106]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:577) [jetty-security-9.2.14.v20151106.jar:9.2.14.v20151106]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:223) [jetty-server-9.2.14.v20151106.jar:9.2.14.v20151106]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1127) [jetty-server-9.2.14.v20151106.jar:9.2.14.v20151106]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515) [jetty-servlet-9.2.14.v20151106.jar:9.2.14.v20151106]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) [jetty-server-9.2.14.v20151106.jar:9.2.14.v20151106]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1061) [jetty-server-9.2.14.v20151106.jar:9.2.14.v20151106]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [jetty-server-9.2.14.v20151106.jar:9.2.14.v20151106]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97) [jetty-server-9.2.14.v20151106.jar:9.2.14.v20151106]
at org.eclipse.jetty.server.Server.handle(Server.java:499) [jetty-server-9.2.14.v20151106.jar:9.2.14.v20151106]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:311) [jetty-server-9.2.14.v20151106.jar:9.2.14.v20151106]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:257) [jetty-server-9.2.14.v20151106.jar:9.2.14.v20151106]
at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:544) [jetty-io-9.2.14.v20151106.jar:9.2.14.v20151106]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635) [jetty-util-9.2.14.v20151106.jar:9.2.14.v20151106]
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555) [jetty-util-9.2.14.v20151106.jar:9.2.14.v20151106]
at java.lang.Thread.run(Thread.java:745) [na:1.8.0_60]
There is an error in java.io.BufferedReader getReader() - if getInputStream() method has been called on this request.
getInputStream() is called before from the DispatcherServlet from SpringBoot.
Do you have an idea how to avoid this error or a hint for a correct Spring Boot implementation?
Thanks in advance!
(xtext version 2.9.0)
[Updated on: Tue, 12 January 2016 20:13] by Moderator
FUDForum. Page generated in 0.04208 seconds
