Home » Eclipse Projects » Eclipse Scout » How to connect two Scout Projects?(Especially: how can I combine the Desktops of two Scout Applications?)
icon7.gif  How to connect two Scout Projects? [message #1752636] Wed, 25 January 2017 11:54 Go to next message
Hi there,
I am working on a specific problem and got stuck at some point. I would be glad if someone could help me out with this one...
Introduction.
I have a Scout project (core application) and one (or more) Scout projects should extend this core (different products for different customers). The goal is that if I deploy one product, the customer gets this product plus the core, and analoguesly the second product should contain product 2 plus the core such that I can work on both products seperately, but only have to maintain one core which contains such features as the administration panel, etc. etc.
Additionally it would be cool to deploy also a third project, which contains product 1, product 2 and the core.
In a simple imaginary world, it could be that product 1 adds an outline to the core, and product 2 adds another outline. Both products can go standalone and the third project could contain all core outlines plus the outlines of product 1 and 2.
Right now, the structure (in the new Neon release) is such that the core project acts as the deliverer of all Scout related packages. The first product (extension project) therefore has the core as its parent (in the pom).
Also, I have configured the [webapp] dev ui.launch files on the product and the whole construct is runnable at least in dev-mode (yay!) - I havent tried to deploy the stuff yet.
Questions:
1. Is the pom structure as seen below ok?
2. How can I now tell the first product (prod1) to "inherit" the Desktop from the core and extend it? I have an idea to do this via an own client session on product 1 which has its own desktop which is derived from the core desktop. Is this the right way to do this?
Here is the dependency tree in detail:
core.pom
--parent:
----scout.maven_rt_plugin_config-master
--modules:
----core.shared/core.server/core.client/core.server.app.war/core.ui.html/core.ui.html.app.war
--dependencyManagement:
----dependencies:
------scout.rt
------core.client/core.shared/core.server/core.ui.html
core.client.pom
--parent:
----core
--dependencies:
---scout.rt.client/scout.rt.client.test/core.shared
core.server.pom
--parent:
----core
--dependencies:
---scout.rt.server/scout.rt.server.test/javax.servlet-api/core.shared
core.server.app.dev.pom
--parent:
----core
--packaging
----war
--dependencies:
---scout.dev.jetty/core.server
core.server.app.war.pom
--parent:
----core
--packaging
----war
--dependencies:
---core.server
core.shared.pom
--parent:
----core
--dependencies:
---scout.rt.shared/scout.rt.shared.test/jul-to-slf4j/ch.qos.logback-classic
core.ui.html.pom
--parent:
----core
--dependencies:
---scout.rt.ui.html/core.client/javax.servlet-api
core.ui.html.app.dev.pom
--parent:
----core
--dependencies:
---scout.dev.jetty/core.ui.html
--parent:
----core
--packaging:
----war
--dependencies:
core.ui.html.app.war.pom
--parent:
----core
--packaging:
----war
--dependencies:
---core.ui.html
prod1.pom
--parent:
----core
--modules:
----prod1.shared/prod1.server/prod1.client/prod1.server.app.war/prod1.ui.html/prod1.ui.html.app.war
----dependencies:
------prod1.client/prod1.shared/prod1.server/prod1.ui.html
prod1.client.pom
--parent:
----prod1
--dependencies:
---core.client/prod1.shared
prod1.server.pom
--parent:
----prod1
--dependencies:
---core.server/prod1.shared
prod1.server.app.dev.pom
--parent:
----prod1
--packaging:
--war
--dependencies:
---scout.dev.jetty/prod1.server
prod1.server.app.war.pom
--parent:
----prod1
--packaging:
--war
--dependencies:
---prod1.server
prod1.shared.pom
--parent:
----prod1
--dependencies:
---core.shared
prod1.ui.html.pom
--parent:
----prod1
--dependencies:
---core.ui.html/prod1.client
prod1.ui.html.app.dev.pom
--parent:
----prod1
--packaging:
----war
--dependencies:
---scout.dev.jetty/prod1.ui.html
prod1.ui.html.app.war.pom
--parent:
----prod1
--packaging:
----war
--dependencies:
---prod1.ui.html
Re: How to connect two Scout Projects? [message #1752687 is a reply to message #1752636] Thu, 26 January 2017 03:15 Go to previous messageGo to next message
Hello David
Your project structure looks good and should work very well.
To extend the Desktop you have multiple options.
The one you listed, which is a perfectly valid implementation: Using the @Replace annotation in the "product 1/2/3" to override the parent implementation of the IClientSession and create a different Desktop.
Or alternatively, you could do it slightly different:
Make a (possibly abstract) desktop in the core (which you likely already have) and annotate it with @Bean. In your client session in the core:
setDesktop(BEANS.get(AbstractMyCoreDesktop.class));
Then, in your products, you can just create subclasses of your abstract desktop and annotate them with @Replace. Unless you have any customization of the client session in your product, you wouldn't even need an additional implementation in product1/2/3.
Re: How to connect two Scout Projects? [message #1752737 is a reply to message #1752687] Thu, 26 January 2017 12:41 Go to previous message
Hi Patrick,
thank you very much for the valuable input. I struggled a bit because the @Replace annotation did not work at first. I managed to solve the issue and found the solution in the following post:
https://www.eclipse.org/forums/index.php?t=msg&th=1083599&goto=1751378&
Ivan Motsch wrote:
Only modules containing a META-INF/scout.xml are included in the bean inventory.
After adding this file, everything is working now! The construct in general is a wonderful solution for us Smile
Thanks again!
Previous Topic:[neon] How to replace org.osgi.service.prefs.Preferences
Next Topic:MYSQL database connection getting closed intermittently
Current Time: Mon Jul 28 17:48:26 EDT 2025
Powered by FUDForum. Page generated in 0.03810 seconds
