Home » Eclipse Projects » Oomph » Issue with evaluation of a variable within a variable
Issue with evaluation of a variable within a variable [message #1752430] Mon, 23 January 2017 12:16 Go to next message
I have a strange problem with the evaluation of a variable. The issue is that the "Installation folder name" does not get autocomplete to "scope.product.name" (since Eclipse Installer 1.5.0), value that exists in the setup file.
So, I manage to track it down in the setup file, and is actually related to the "install.root" variable value. This one is defined in the product setup file and has the value of "${company.install.root/tools/eclipse}" and the "company.install.root" variable is defined in the root setup file with the value "${user.home/company}".
I presume that the evaluation of the variables has an issue on "install.root" because of the variable within variable, that breaks the evaluation of "scope.product.name".
Could you please give me some suggestion of some break point that I can use to see what is actually happening in the code?
Thank you,
Samarghitan Catalin
Re: Issue with evaluation of a variable within a variable [message #1752457 is a reply to message #1752430] Tue, 24 January 2017 00:10 Go to previous messageGo to next message
There is special handling in org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.filter(String, String) and yes this indirection through other variables is likely the issue.
Re: Issue with evaluation of a variable within a variable [message #1752683 is a reply to message #1752457] Thu, 26 January 2017 02:46 Go to previous messageGo to next message
You were right, in the filter method the install.root is still in the unresolvedVariables because of the variable within variable, so the filter is not able to determine the uniqueInstallationID.
Should I open bug or this behavior is not supported?
Catalin
PS: I've uploaded some sample files to reproduce the problem.
Re: Issue with evaluation of a variable within a variable [message #1752890 is a reply to message #1752683] Mon, 30 January 2017 06:21 Go to previous messageGo to next message
You could open an enhancement request, but as you can see, this is special case logic for a tricky case, so it's not clear to what extent this could be generalized...
Re: Issue with evaluation of a variable within a variable [message #1754814 is a reply to message #1752890] Wed, 22 February 2017 11:22 Go to previous messageGo to next message
Hi Ed,
After some debugging I was able to find a solution to my problem by changing the code in SetupTaskPerformer for the method:
private void expandVariableTaskValue(Set<String> keys, EObject eObject)
In short, when a newValue is found I add it to the SetupTaskPerformer and remove it from unresolvedSettings.
I've attached the new version of the file. If you prefer I can try to do a pull request on git.
Catalin
Re: Issue with evaluation of a variable within a variable [message #1754818 is a reply to message #1754814] Wed, 22 February 2017 12:31 Go to previous message
The preferred method of contributing changes is to use Gerrit. Alternatively, a patch would be good too. Or I can figure out the diff from the full version of your file, but in any case, please open a Bugzilla, for the Gerrit commit, the patch, or for the new version of the file with your changes.
Previous Topic:Update Maven Project
Next Topic:Eclipse crashes occasionally with "Eclipse stopped working"
Current Time: Thu Sep 18 20:02:40 EDT 2025
Powered by FUDForum. Page generated in 0.03644 seconds
