Home » Eclipse Projects » Eclipse 4 » Inject values into fields when class instantiated in my code(Dependency Injection question)
Inject values into fields when class instantiated in my code [message #1752661] Wed, 25 January 2017 16:34 Go to next message
I'm trying to figure out how to correctly inject values into a handler when it is created in my own custom code. Here is the handler code:
public class OpenProjectComponentHandler {
	@Inject
	private MApplication application;
	@Inject
	private EModelService modelService;
	@Execute
	public Object execute(@Named(IServiceConstants.ACTIVE_SELECTION) ISelection sel) {
		/* Code that uses modelService and application here */
		return null;
	@CanExecute
	public boolean canExecute() {
		return true;
Now, when a menu item click triggers the call to this handler, application and modelService are injected as I'd expect. But, I also want to call this handler from other custom code like this:
OpenProjectComponentHandler handle = new OpenProjectComponentHandler();
			handle.execute(new StructuredSelection(o));
When I call the handler using my own code, the fields have nothing injected into them.
Re: Inject values into fields when class instantiated in my code [message #1752669 is a reply to message #1752661] Wed, 25 January 2017 16:50 Go to previous messageGo to next message
That is possible using
IEclipseContext context = ...;
handler = ContextInjectionFactory.make(OpenProjectComponentHandler.class, eclipseContext);
ContextInjectionFactory.invoke(handler, Execute.class, eclipseContext);
But, I think, it would be better to extract the executed logic into a utility method that you can call outside DI and just delegat to within DI.
Ken Keefe wrote on Wed, 25 January 2017 22:34
	@Inject
	@Inject
	@Execute
		return null;
	@CanExecute
		return true;
Re: Inject values into fields when class instantiated in my code [message #1752672 is a reply to message #1752661] Wed, 25 January 2017 16:56 Go to previous messageGo to next message
Well, the good people on the freenode irc solved this for me.
OpenProjectComponentHandler handle = ContextInjectionFactory.make(OpenProjectComponentHandler.class, context);
And, the context variable in that code fragment was injected in the class that this code is contained in. I don't know if I'll ever need to make a call like this from an object that was not created by the context injection factory.
Re: Inject values into fields when class instantiated in my code [message #1752673 is a reply to message #1752661] Wed, 25 January 2017 16:57 Go to previous message
I generally avoid field injection, because I can not easily predict the values of the injected fields.
I tend to use injected constructors and injected methods in general, as I find more predictable the way I can obtain values injecting parameters.
In the code snippet below, you can see how I transformed your initial code snippet in a way that is easier to use and less prone to errors. In particular, note that:
1. I injected the needed parameters in the @Execute method. So doing, Eclipse injects the actual instances for "IEclipseContext ", "EModelService" and "MApplication" each time the method is called.
2. I added another method where @Optional @Named(IServiceConstants.ACTIVE_SELECTION) is injected. This means that this method is automagically executed each time the ACTIVE_SELECTION changes.
	private StructuredSelection selection;
	@Execute
	public Object execute(IEclipseContext context, EModelService modelService, MApplication application) {
		// you can keep references to the injected objects
		this.application = application;
		this.modelService = modelService;
		// execute code using modelService application and context
		return null;
	@CanExecute
		return true;
	@Inject
	@Optional
	public void executeOnSelection(
					@Optional @Named(IServiceConstants.ACTIVE_SELECTION) StructuredSelection selection) {
		// you can keep reference to the injected object
		this.selection = selection;
		// here you execute your code when the selection changes
In case you need more information, please read about dependency injection in Eclipse 4, and about the difference between field injection and parameter injection.
- as an example: http://eclipsesource.com/blogs/tutorials/eclipse-4-e4-tutorial-part-4-dependency-injection-basics/
Also, you can check for one of the many tutorials available on the web.
Kind Regards,
Ing. Patrik Suzzi
Consultant Software Engineer,
Eclipse Platform Committer
https://about.me/psuzzi
[Updated on: Thu, 26 January 2017 17:55] by Moderator
Previous Topic:Dynamic toolbar contributions
Next Topic:Open PartDescriptor on Application Startup
Current Time: Sat Jul 26 02:33:21 EDT 2025
Powered by FUDForum. Page generated in 0.04966 seconds
