Inject values into fields when class instantiated in my code [message #1752661] |
Wed, 25 January 2017 16:34  |
I'm trying to figure out how to correctly inject values into a handler when it is created in my own custom code. Here is the handler code:
public class OpenProjectComponentHandler {
@Inject
private MApplication application;
@Inject
private EModelService modelService;
@Execute
public Object execute(@Named(IServiceConstants.ACTIVE_SELECTION) ISelection sel) {
/* Code that uses modelService and application here */
return null;
@CanExecute
public boolean canExecute() {
return true;
Now, when a menu item click triggers the call to this handler, application and modelService are injected as I'd expect. But, I also want to call this handler from other custom code like this:
OpenProjectComponentHandler handle = new OpenProjectComponentHandler();
handle.execute(new StructuredSelection(o));
When I call the handler using my own code, the fields have nothing injected into them.
Re: Inject values into fields when class instantiated in my code [message #1752669 is a reply to message #1752661] |
Wed, 25 January 2017 16:50   |
That is possible using
IEclipseContext context = ...;
handler = ContextInjectionFactory.make(OpenProjectComponentHandler.class, eclipseContext);
ContextInjectionFactory.invoke(handler, Execute.class, eclipseContext);
But, I think, it would be better to extract the executed logic into a utility method that you can call outside DI and just delegat to within DI.
Ken Keefe wrote on Wed, 25 January 2017 22:34I'm trying to figure out how to correctly inject values into a handler when it is created in my own custom code. Here is the handler code:
@Inject
@Inject
@Execute
return null;
@CanExecute
return true;
Re: Inject values into fields when class instantiated in my code [message #1752673 is a reply to message #1752661] |
Wed, 25 January 2017 16:57  |
I generally avoid field injection, because I can not easily predict the values of the injected fields.
I tend to use injected constructors and injected methods in general, as I find more predictable the way I can obtain values injecting parameters.
In the code snippet below, you can see how I transformed your initial code snippet in a way that is easier to use and less prone to errors. In particular, note that:
1. I injected the needed parameters in the @Execute method. So doing, Eclipse injects the actual instances for "IEclipseContext ", "EModelService" and "MApplication" each time the method is called.
2. I added another method where @Optional @Named(IServiceConstants.ACTIVE_SELECTION) is injected. This means that this method is automagically executed each time the ACTIVE_SELECTION changes.
private StructuredSelection selection;
@Execute
public Object execute(IEclipseContext context, EModelService modelService, MApplication application) {
// you can keep references to the injected objects
this.application = application;
this.modelService = modelService;
// execute code using modelService application and context
return null;
@CanExecute
return true;
@Inject
@Optional
public void executeOnSelection(
@Optional @Named(IServiceConstants.ACTIVE_SELECTION) StructuredSelection selection) {
// you can keep reference to the injected object
this.selection = selection;
// here you execute your code when the selection changes
In case you need more information, please read about dependency injection in Eclipse 4, and about the difference between field injection and parameter injection.
- as an example: http://eclipsesource.com/blogs/tutorials/eclipse-4-e4-tutorial-part-4-dependency-injection-basics/
Also, you can check for one of the many tutorials available on the web.
Kind Regards,
Ing. Patrik Suzzi
Consultant Software Engineer,
Eclipse Platform Committer
https://about.me/psuzzi
[Updated on: Thu, 26 January 2017 17:55] by Moderator
FUDForum. Page generated in 0.04087 seconds
