Home » Modeling » EMF » Java to Ecore using annotation(I'm getting errors using @model annotation using wizard. Also is there a way to automate this?)
Java to Ecore using annotation [message #1752623] Wed, 25 January 2017 10:53 Go to next message
I'm trying to transform Java code into ecore model but failed untill now with error:
"Errors were detected while resolving names or processing @model annotation" Details -> "No model elements were found in Java source: check for '@model' on interfaces and classes"
This is how code looks like for instance:
import javax.xml.bind.annotation.XmlAccessType;
import javax.xml.bind.annotation.XmlAccessorType;
import javax.xml.bind.annotation.XmlType;
@XmlAccessorType(XmlAccessType.FIELD)
@XmlType(name = "ClassARequest")
 * @model
public class ClassA implements java.io.Serializable {
	 * @model
  private String myAttribute;
  public ClassA() {
   * @model
  public String getMyAttribute() {
    return apotekId;
   * @model
  public void setMyAttribute(String attribute) {
    this.myAttribute = attribute;
I have lots of classes so I'm looking for automating this someway later.
Note that I'm having big difficulties in finding good EMF documentation/tutorials that helps understand what to do covering more the details of EMF. Even the @model annotation, I did'nt find examples on using it except one so I knew I have to surround it with /** as I did in code. You recommended me looking into code and debug when I have questions but is that really the only way to get information on how to use EMF? Or just hoping someone posted similar question here or at stackoverflow and someone had an answer?
Please help, thanks!
[Updated on: Wed, 25 January 2017 10:57] by Moderator
Re: Java to Ecore using annotation [message #1752642 is a reply to message #1752623] Wed, 25 January 2017 12:30 Go to previous messageGo to next message
There is the EMF book that documents this in detail and of course many things in great detail.
Re: Java to Ecore using annotation [message #1752706 is a reply to message #1752642] Thu, 26 January 2017 07:02 Go to previous messageGo to next message
I managed to get the .ecore and .modelgernerator generated using the @model annotation. I have a problem though that all attributes generated seems to get one type in ecore regardless what type its defined with in the class. All attributes are turned to be numbers. I tried to add few attributes as shown in the book to enforce type conversion but failed. below a snippet of code example and what ecore I get. Note that I tried combination of Strings,Estrings,etc and played around with attributes but nothing changed in output. Also the second problem was the default value I get for these attributes which are set to 0, then 1, then 2 and 3. I tried also with other attributes as in the book "default-value" but it didn't help.
 * @model
public class Person {
	 * @model data-type="String"
	String id;
	 * @model
	String name;
	 * @model
	int age;
	 * @model data-type="String" containment="true"
	List books;
	 * @model
	public String getId() {
		return id;
	 * @model
	public String getName() {
		return name;
	 * @model
	public int getAge() {
		return age;
	 * @model
	public List getBooks() {
		return books;
And here is the Ecore
<ecore:EPackage xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
    xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="converter" nsURI="http:///converter.ecore"
    nsPrefix="converter">
  <eClassifiers xsi:type="ecore:EEnum" name="Person">
    <eLiterals name="id"/>
    <eLiterals name="name" value="1"/>
    <eLiterals name="age" value="2"/>
    <eLiterals name="books" value="3"/>
  </eClassifiers>
</ecore:EPackage>
[Updated on: Thu, 26 January 2017 07:06] by Moderator
Re: Java to Ecore using annotation [message #1752889 is a reply to message #1752706] Mon, 30 January 2017 06:19 Go to previous message
The Java to Ecore converter expects annotations on things that look like the things EMF would generate. EMF generates interfaces and implementation classes. The only class with variables it generates is for enumerations so that why you see an EEnum as the result.
I'd suggest you look at what's generated for some sample *.ecore models and looking at the generated @model annotations in the interfaces for those samples.
Previous Topic:EMF Forms, load persisted model problem
Next Topic:ECrossreferenceAdapter and removing elements from content tree
Current Time: Wed Jul 23 16:09:47 EDT 2025
Powered by FUDForum. Page generated in 0.12638 seconds
