How to setup dialog_settings.xml via Oomph user.setup? [message #1752503] |
Tue, 24 January 2017 09:39  |
Hi all,
I am trying to setup Package Explorer settings using the Oomph user.setup.
I am editing the user.setup in Eclipse.
I know you can use profiles for this, but in our team everybody wants to have their own way of setting up the Package Explorer, so we decided to set things up in the user settings.
As I saw in examples it's possible to add a "Resource Creation" task to write the dialog_settings.xml into the workspace.
When I configure the Resource Creation entry with a file "my_dialog_settings.xml", the file is written successfully.
I imagine that the actual file dialog_settings.xml is also written - but invoking "Perform Setup Tasks..." has no effect in Eclipse.
My Question:
Is setting up the Package Explorer settings this way even possible?
The PE settings are stored via mementos in dialog_settings.xml. But apparently that file is read before Eclipse comes up and written when Eclipse shuts down (at least that's what appears to happen).
If that is true, maybe changing the dialog_settings file has no effect in Eclipse at all...
Is there a way to setup the Package Explorer's configuration via Oomph user settings?
Ingo
FUDForum. Page generated in 0.05143 seconds
